Testing injectors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BTLowry, Jun 4, 2014.
  1. Jun 4, 2014 at 7:37 PM
    BTLowry
    BTLowry [OP] Well-Known Member
    Texas
    99 SR5 4x4 xcab
  2. Jun 5, 2014 at 8:34 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    First thing,I am not a pro! Have been down this road though.Did you unplug and reattach each injector plug? Check all wires related for bad ground?clean air intake system good?Clean throttle body good? So you can start the engine and take a long screwdriver and put tip against injector body. Press ear against screwdriver and listen for clicking sound. If they all don't sound the same could be faulty injector. Before replacing you have to check electrical connectors.There is a light think it is called "noid" that you plug into each injector plug.If it blinks then it has proper voltage. Can also use an ohmmeter to measure resistance with engine off.
  3. Jun 5, 2014 at 5:27 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    You use the screw driver as a stethoscope. Get a long screw driver and put the blade end on top of the injector with your ear on the handle end. You should be able to hear a series of clicking as the injectors open and close to shoot fuel into the cylinders.
  4. Jun 5, 2014 at 6:22 PM
    BTLowry
    Texas
    99 SR5 4x4 xcab
    Thanks
    Freaking come and go issue with no code is driving me nuts
    Not sure what to make of problem but thought I might as well check injectors
