Testing piston rings with water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 26, 2021.
Thread Status:
Not open for further replies.
  1. Dec 27, 2021 at 12:12 PM
    #81
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Maybe you're just a moron who pulls opinions out of his ass
  2. Dec 27, 2021 at 12:12 PM
    #82
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I believe in a post earlier you said you did the cylinder head overhaul 6 years ago( if the same truck) now we know why. Good luck.
  3. Dec 27, 2021 at 12:18 PM
    #83
    foampile
    Mid-Atlantic
    You don't know why. You're speculating to a self-serving theory. To be an asshole.
    Dickheads like you, to promote going to a mechanic, or going to a contractor, or even going to a doctor, have been discouraging my DIY for years... I go out and get my shit done anyway.
    With all due respect, fuck you
  4. Dec 27, 2021 at 12:22 PM
    #84
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    actually will tell U Nothing
    have used kerosene or wd40..................yet ANY liquid will have DIFFERENT Viscosity
    past the piston rings inside o cylinders.....................TELLS U NOTHNG
    rings are design to work properly against chamber pressures
    chamber friction
    chamber Temps
    chamber gases
    draining water tells U Nothing
    a cold compression test + a cold ‘ Leak Down ‘ test tells U more
    heads already off the block tells U nothing
  5. Dec 27, 2021 at 12:23 PM
    #85
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    This is coming from the guy who is doing a compression test by pouring water into his engine...HAHA.
    JerZ1980, DES2009, b_r_o and 2 others like this.
  6. Dec 27, 2021 at 12:26 PM
    #86
    fourfourone
    Just because you are some half-assed engineer, doesn't mean you have to get all pissed off when people tell you that you are wrong. You clearly have no business working on cars... SO YES BRING IT TO A MEACHINIC.
    gotoman1969 and burrito782 like this.
  7. Dec 27, 2021 at 12:35 PM
    #87
    ROAD DOG
    FEW
    first o ALL
    Use the CORRECT nominclature
    from the phot point o view .................You ARE NOT LOOKIN AT Valve Seals
    No less U cant possibly be looking at Valve SEATS !!!!
    so if U truly want CORRECT Info / Help
    U MUST use CORRECT terms !!!
    from the photos presented that engine was TOAST
    EACH cylinder showing very negative issues
    requiring a standard engine rebuild
  8. Dec 27, 2021 at 2:00 PM
    #88
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    and I repeat .
    Ya know, earlier in this post I said I was out because of the initial dumb ass question.
    I have to jump back in and say this is not going to turn out on any side of good. These questions being thought and asked are pointing to a disaster. I do wish you all the luck with this.
    DES2009 and burrito782 like this.
Thread Status:
