Testing vapor pressure sensor question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 2, 2022.
  1. Sep 2, 2022 at 10:52 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I have a cel - P0450 - Evaporative Emission Control System Pressure Sensor Malfunction
    This is the procedure for testing the 5fvze from the '01 manual
    Along with the corresponding schematic & there is a R-Y & a LG wire for the sensor connector itself
    Engine room #'s E5-17, E2-18
    My color wire for E5-17 is R-Y
    Then I saw this - It states PTNK, yet uses a different color wire R-G & BR
    It has the same engine room # for PTNK E5-17
    Am I missing something here? I do not pass the first test procedure, however want to make sure I am covering the bases before I start hunting for a replacement.
  2. Sep 2, 2022 at 11:53 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your overthinking things again!!
    The sensor was your first test and it failed? The sensor is good now your checking the wiring to the ECM did that ring out??
    If all the above is good then check the voltage at the ECM the ECM pin outs
  3. Sep 2, 2022 at 12:50 PM
    Kristi with a K
    Western MA
    vc/e2 - 4.9 (at ecm)
    Ptnk (r-y)/e2 - 4.9 (at ecm) sensor not connected. I also get this when testing the harness connector itself. Tells me I am getting the correct voltage from the ecm.... My take on it anyway.
    Ptnk/e2 - connected, vacuum hose unplugged - 3.2v - this is good
    Vacuum applied - it goes up - 4.9v - this is not good. Supposed to go down - .5 or less. Whoops! I didn’t get that part in the first pic.
    I am taking it that the sensor is not good. What threw me off was the last pic in which it has a different setup for the PTNK wiring. Same manual.
  4. Sep 2, 2022 at 12:50 PM
    Kristi with a K
    Western MA
  5. Sep 2, 2022 at 1:42 PM
    Bivouac
    How were you applying Vacuum??
  6. Sep 2, 2022 at 5:49 PM
    Kristi with a K
    Western MA
    Sorry. I got waylaid. I was using a pump. I had cleaned the connector yesterday. Didn't seem bad at all. I tested it again for ha-ha's & now it passes. Seems weird though that the little bit that I picked up with a q-tip would make all that much dif. I can't clear the code to recheck it yet because I sent the TB to Maxbore.
    Bivouac[QUOTED] likes this.
  7. Sep 2, 2022 at 5:54 PM
    Aircates
    Aircates Well-Known Member
    Texas
    1997 Tacoma lowboy
    PTNK stands for Pressure TaNK..
  8. Sep 2, 2022 at 5:57 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Toyota has some strange translations
    Bivouac and Kristi with a K[OP] like this.
  9. Sep 2, 2022 at 6:07 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Your Ptnk /E2- 4.9v is a ghost voltage because it is not connected to anything. Sort of like deadhead voltage. You are correct in that it is a correct reading.
  10. Sep 2, 2022 at 6:09 PM
    Kristi with a K
    Western MA
    Thank you. I like the learning. My confusion still is that PTNK is referred to as R-Y & R-G, yet each are designated as E5-17.
    Aircates[QUOTED] likes this.
  11. Sep 2, 2022 at 6:14 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    The Ptnk/
    lol… Welcome to Toyota service manuals… They are notorious for this. They would send out updates to correct mislabeled wiring and components.
    Bivouac likes this.
  12. Sep 2, 2022 at 6:14 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    You kind of have to take them with a grain of salt.
  13. Sep 2, 2022 at 6:16 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    You never went by color alone and sometimes you couldn’t trust the pin locations either….
    Kristi with a K[OP] likes this.
  14. Sep 2, 2022 at 6:17 PM
    Kristi with a K
    Western MA
    Is there a set voltage for the vsv's? I am getting 2.5 for the vsv for vapor pressure & 3 for the vsv for EVAP. I do realize there are resistance tests & checking the valves. Wondering about the voltage itself or is it irrelevant as long as they pass the other tests.
  15. Sep 2, 2022 at 6:19 PM
    Kristi with a K
    Western MA
    Ha-ha! Great!
  16. Sep 2, 2022 at 6:22 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    The Ptnk/E2- connected but no vacuum reading is correct at 3.2 volts. That is the “at rest” voltage, since it is atmospheric. However, as you observed, the voltage should have dropped when you applied vacuum. Not gone up. Since it went up (remember open circuit voltage is 4.9) that is a good indicator of a bad sensor.
  17. Sep 2, 2022 at 6:29 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    VSV (vacuum switching valves) were normally 12 volts on one side and Toyota would pulse the ground side. Was your multi-meter set up with the red on the positive side of the vsv and the negative on the “trigger” side (pulsed ground)? And was the vsv clicking?
  18. Sep 2, 2022 at 6:29 PM
    Kristi with a K
    Western MA
    I cleaned the connector & retested. It passed, however there wasn't much dirt at all. Making me wonder now that you just taught me the 4.9 was indicative of an open circuit if there's actually something up with the sensor plug itself.
  19. Sep 2, 2022 at 6:32 PM
    Aircates
    Texas
    1997 Tacoma lowboy
    Loose pin fit could cause it. What you can do is the male terminal pins in the vapor sensor can be slightly bent to make better contact.
  20. Sep 2, 2022 at 6:44 PM
    Kristi with a K
    Western MA
    I was just checking the next thing down from the VPS. I unplugged it to check the harness for wire color & condition. Decided to check voltage. The 12v was good. Got curious about the ground side & saw it was 2.5. Wondered if this was ok seeing's how the other vsv was 3v. Then I got sidetracked by my neighbor who needed a hand.
    So with a pulse ground it would be random?
