Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Mar 22, 2013 at 11:27 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Well me and Alex got the OME struts and 886s on my truck tonight.
    The alignment is off that bad surprisingly, although it does have quite a bit of caster...
    UCAs might be in the future, we will see. Hit some curbs at speed and didnt feel anything rubbing.
    Truck feels way better with this suspension set up
    And Zech that we ended up getting that bolt loose. We just had to take off the skid plate and get at it from the other side, cane off really easy actually...
    Broke one socket tonight, and I am super impressed with my craftsman wrenches. In our attempt to get that stubborn nut loose we tried pushing up on the wrench with a 3 ton jack. We started lifting the truck up off of the jack stands with that wrench and it didn't break, bend or anything!
    And I introduced Alex into the awesomeness that is know as Snap On ratchets..
  2. Mar 23, 2013 at 8:17 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Meh, should have gone with PRK instead. ;)
  3. Mar 23, 2013 at 9:08 AM
    achirdo
    Adam
    North DFW
    Good luck!
  4. Mar 23, 2013 at 9:17 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    The skid plate? :confused: I wonder kind of magic difference that made.
  5. Mar 23, 2013 at 9:46 AM
    achirdo
    Adam
    North DFW
    The other side of the bolt was blocked by the skid plate
  6. Mar 23, 2013 at 11:15 AM
    tx_shooter
    The skid plate was blocking the bolt from rotating? :confused:
  7. Mar 23, 2013 at 11:37 AM
    achirdo
    Adam
    North DFW
    No no. We were trying to turn the nut at first. Then we figured we would try turning the bolt instead thinking maybe that would be easier to turn. So the skid plate had to be removed to get to it.
  8. Mar 23, 2013 at 12:29 PM
    tx_shooter
    How much did you two have to drink?
  9. Mar 23, 2013 at 2:49 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    I still don't know why you had to remove the skid plate for the struts to be swapped. You can get to the alignment bolts to loosen the LCA with out taking off the skid.
  10. Mar 23, 2013 at 3:13 PM
    tx_shooter
    We didn't remove the LCA to swap your coils. Not that I remember at least.
  11. Mar 23, 2013 at 4:01 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    Nothing. :(
  12. Mar 23, 2013 at 4:43 PM
    tex
    Fort Worth, TX
    They can be loosened to make it easier to move the LCA. It's the way I have done mine the last 2 times.
  13. Mar 23, 2013 at 5:02 PM
    achirdo
    Adam
    North DFW
    ONE OF THE ALIGNMENT BOLT NUTS WOULD NOT BUDGE AND SEEMED TO BE SEIZED IN PLACE.
  14. Mar 23, 2013 at 5:12 PM
    tx_shooter
    Why the yelling?
  15. Mar 23, 2013 at 9:48 PM
    tx_shooter
    Kind of quiet in here today. Maybe tomorrow Keith will post with his 20/20 vision. I wonder if Adam was able to get his truck to a shop to get the front end aligned.
  16. Mar 23, 2013 at 10:06 PM
    blu xr
    blu xr Well-Known Member
    robert
    orbiting caprica
    2005 swb x-runner 2019 cavalry blue dcsb trd sport (b/o) 1995 mkiv supra (h/t)
    air freshiners
    xr has been in the shop for a week cause of the golf ball to baseball size hail that hit the palo pinto county area. anyone else get any damage?
  17. Mar 23, 2013 at 10:15 PM
    tx_shooter
    Yep, my truck took a beating on I-20. I was coming back from West Texas and I drove right into that storm. I have not been able to get it into the local body shop because they keep M-F 8-5 hours (lucky F*ers).
  18. Mar 23, 2013 at 10:20 PM
    blu xr
    robert
    orbiting caprica
    air freshiners
    better get that taken care of quickly.
    my wife was driving down 281, got pelted. the road got quickly covered in sleet & tiny hail stones and she slid off the road. damaged the rear bumper & ground effects. total so far is over $7k.
  19. Mar 23, 2013 at 10:34 PM
    tx_shooter
    I just had a couple grand in hail damage. The insurance already cut me a check; now I am just trying to get into the shop.
  20. Mar 23, 2013 at 11:47 PM
    achirdo
    Adam
    North DFW
    Alignment actually wasn't that bad... Well it was, but driving on it wasn't. Got it taken care of today though. I'll post a pic of the specs.
