Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Aug 25, 2013 at 1:28 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    The bumper itself is not difficult. You will need a hand to get the new bumper mounted since the winch will need to be mounted in the bumper first.
    The hardest part I had with mine was relocating the winch solenoid under the hood and making a bracket to hold it. Depending where yours is going can make your install easier.
    Light bar is easy. Wire the relay to a switch, then to power and let there be light. Skids should be easy as well, and I'm sure a helping hand would be a huge time saver to get them mounted.
  2. Aug 25, 2013 at 1:31 PM
    tex
    Fort Worth, TX
    One other thing. I would not pay a shop to instal those items. They are all fairly easy items to do but the whole job will be time consuming to do it all right.
  3. Aug 25, 2013 at 1:38 PM
    MWM BAJA 12
    MWM BAJA 12 Well-Known Member
    Micah
    Dallas
    2012 "Baja" Edition BLACK
    see my build page
    The bumper swap looks "simple" enough but its the wiring that worries me. I have a blue sea 100 amp breaker and blue sea 12 spot fuse box.
  4. Aug 25, 2013 at 2:01 PM
    tex
    Fort Worth, TX
    How are you mounting your solenoid for the winch? Even with that blue sea box for accesories the power wire for the winch really needs to go right to the battery.
    I just got 3 wires to go from the winch to the solenoid box. I hooked them up to the same contact points when it was mounted to the winch. Then ground the winch to the frame(I grounded to a bumper mount) and then run the power wire to the frame.
    Your light bar is easy to do.
    Switch will have a ground wire and a power wire going to the relay. Then the relay will have a power wire to the battery and then hook up the power wire from the light. Last will be to ground the light as well.
  5. Aug 25, 2013 at 2:05 PM
    tex
    Fort Worth, TX
    The 100 amp breaker is probably not enough for the winch. I have popped a 100 amp fuse the first time using the winch. It came with a 160 amp fuse but used a different one and running a 150 amp fuse. I have a 200 as back up incase I need it.
  6. Aug 25, 2013 at 2:13 PM
    tex
    Fort Worth, TX
    Very true. I sure hope its already painted or powder coated. That was a chore to do mine.
  7. Aug 25, 2013 at 4:23 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    im only running light bar and fog lights for now off of the blue sea set up. Im going to run warn m8000-s winch directly off of the battery. I have a heavy duty cherry picker I can use to help with the bumper and yeah its already powder coated and ready to bolt on. Just going to take me some time to run all the wires and set every up.
    Do you think I can run a ARB compressor for air off of the blue sea set up or will I have to run it to the battery also?
  8. Aug 25, 2013 at 4:52 PM
    tex
    Fort Worth, TX
    I'm not sure about the compressor. Depending on the size of power wire you have going to the fuse block and if it will hold a large enough amp fuse will be your determining factors.
  9. Aug 25, 2013 at 6:18 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I use a 30 amp fuse for my compressor. But its not a ARB so I'm not much help :p
  10. Aug 25, 2013 at 7:04 PM
    tex
    Fort Worth, TX
    I did a little searching and it appears the ARB should use a 30amp fuse or really close to it. I would say if you at least 4 gauge wire to your fuse block and it can hold the correct size fuse then you are set. I thought they would take a much larger fuse than 30 but I guess I was wrong.
    I might be able to help with your bumper install in a week or 2 but can't commit to anything yet.
  11. Aug 25, 2013 at 8:49 PM
    achirdo
    Adam
    North DFW
    Start my welding classes tomorrow.
  12. Aug 26, 2013 at 12:55 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    What's going on folks. Figured I'd drop a line or two here since I will be relocating in a couple months from AZ. Moving to the Roanoke area. Anyone know of any places that are hiring? I will have my associates from Universal Tech. Institute (doesn't mean much these days unfortunately, but it's a start). I am looking for anything really, but mostly interested in something to do with turning a wrench, and yes I was turning wrenches before the school. Anyways, I look forward to getting to know a new crowd and thanks for any leads in advance.
  13. Aug 26, 2013 at 4:22 AM
    achirdo
    Adam
    North DFW
    I don't remember the last time I was up this early...I hope everybody feels bad for me and shows me sympathy
  14. Aug 26, 2013 at 5:08 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    I am up to get my rear brakes changed this morning, I hate waking up at 6.
  15. Aug 26, 2013 at 6:04 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Been getting up at 5:30 last couple days So I can carpool with the wife. And that's sleeping in compared to normal...
  16. Aug 26, 2013 at 6:14 AM
    achirdo
    Adam
    North DFW
    Why?!
  17. Aug 26, 2013 at 8:56 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    truck still making noise and cant find where its coming from ugh
  18. Aug 26, 2013 at 9:38 AM
    Large
    Large Red
    Some winches under 80-90% load can exceed 300 amps, the best bet is to make a kill switch for the controls. I've tried to find a 350A solenoid to mount under the hood and use 12V to close it with a switch so the winch is dead until I want to run it but I got tired of looking and said F it heh.
  19. Aug 26, 2013 at 12:13 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Tex, if I don't get my bumper on n the next few week ill take you up on your offer if it still stands
  20. Aug 26, 2013 at 1:41 PM
    tex
    Fort Worth, TX
    Let me know in a few weeks and we will see how my schedule looks.
