Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Feb 23, 2014 at 4:31 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Thanks; I am looking forward to seeing how these upgrades effect it. Wish I could keep it a little lower than it is; but I am still looking into that.
  2. Feb 23, 2014 at 8:43 AM
    tx_shooter
    Not even worth measuring right now until I get the new rear leafs installed to level it out right.
  3. Feb 23, 2014 at 11:39 AM
    skb7527
    skb7527 Well-Known Member
    Scott
    McKinney, Texas
    2012 Pyrite Mica 4X4
    Goodyear Wrangler UltraTerrain AT tires with America Outlaw Sheriff wheels, Bilstein 5100s all the way around, OME coils, Toytech ICONS HD leafs, debadged, removed pin stipe, chopped tail pipe, weather tech floor mats, Leer color match topper, Toyota bed mat, homemade eight ball gear shifter and 4XInnovations weld on sliders
    No, I sure don't. I had a three way call with the body shop and the salvage company so I could verbally release it and really didnt care who they were.
    I could find out if you need me to....
  4. Feb 23, 2014 at 2:53 PM
    fsbrain03
    fsbrain03 Well-Known Member
    Tell us where you wanna go. I'll follow you around and pull you out after you get stuck.
  5. Feb 23, 2014 at 3:09 PM
    fsbrain03
    I'm not planning on any far away places until Jambo.
  6. Feb 23, 2014 at 3:18 PM
    tx_shooter
    I'm hoping to be in shape to hit Tolar by mid-March as a shake down run.
  7. Feb 23, 2014 at 4:16 PM
    fsbrain03
    I've been wanting to go back to Tolar. So get it done by the 22nd!
  8. Feb 23, 2014 at 5:42 PM
    tx_shooter
    I jacked the backend up to work on the shocks today. I also measured the frame height on the front. Under the rear shackle hole is ~26", the bottom of the front diff is ~10" and the bottom of the axle is ~13". I need to double check those with a flashlight once I finish up the shocks and rear diff armor.
    Starting to look like a rig. :D
  9. Feb 23, 2014 at 5:43 PM
    tx_shooter
    That is just a month away; shouldn't be too bad. I just have to finish the leafs, 4.7 install, and figure out a solution for the front driveshaft.
  10. Feb 26, 2014 at 5:37 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  11. Feb 26, 2014 at 1:54 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    Does not look lifted or to have oversized tires.
  12. Feb 26, 2014 at 6:10 PM
    tx_shooter
    About as accurate as the media gets. Have you seen them identify firearms? I'm surprised they have not started claiming the robber used an M16 yet.
  13. Feb 26, 2014 at 6:15 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    An automatic assault rifle m16 with a 30 caliber clip with ability to disperse in 1.5 s
  14. Feb 26, 2014 at 6:24 PM
    tx_shooter
    Lucky everyone in that town didn't die from it.
  15. Feb 26, 2014 at 6:26 PM
    tex
    Fort Worth, TX
    It was because it was not a ghost gun. Those are the ones you have to watch out for.
  16. Feb 26, 2014 at 8:28 PM
    achirdo
    Adam
    North DFW
    And it wasn't carried by a tea party terrorist
  17. Feb 26, 2014 at 10:37 PM
    achirdo
    Adam
    North DFW
  18. Feb 26, 2014 at 10:48 PM
    jimbo33l
    jimbo33l Tacodile.... Supreme
    Jimmy
    Baytown, TX
    12 DC Off Rd 4x4
    Are those propane cylinders?
  19. Feb 27, 2014 at 6:54 AM
    achirdo
    Adam
    North DFW
    Probably acetylene and oxygen
  20. Feb 27, 2014 at 7:02 AM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Cool as shit. Hope the driver got out. Looks like he ran away towards the left from the truck as soon as it stopped.
