Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Mar 5, 2015 at 8:01 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    :thumbsup:
  2. Mar 5, 2015 at 9:55 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Not a bad gig though; at least we get to save the gas of a commute. I'm working on the new web filter for a customer from home.
  3. Mar 7, 2015 at 11:42 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm clean and sat outside for lunch. Liking TX again. ImageUploadedByTapatalk1425757285.081102.jpg
  4. Mar 7, 2015 at 4:22 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Nice. Great weather today!
  5. Mar 8, 2015 at 6:56 AM
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Now, not so much.
  6. Mar 8, 2015 at 6:59 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Steady rain and we need it
  7. Mar 8, 2015 at 7:02 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I think we're going to get 3+ inches from today and Monday.
    :rain:
  8. Mar 8, 2015 at 7:10 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    X2
    Nice to see green grass instead of dirt.
  9. Mar 8, 2015 at 7:44 AM
    fsbrain03
    fsbrain03 Well-Known Member
    I need the grass to come in, so everytime my dogs come inside, it doesn't look like they just had a mud wrestling match.
  10. Mar 8, 2015 at 8:05 AM
    ThomasMore66
    Well, it was fun while it lasted.
  11. Mar 8, 2015 at 8:18 AM
    ThomasMore66
  12. Mar 8, 2015 at 11:05 AM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Been a while since I checked in. Glad to see this thread has come back alive. Update on the Dodge, if she doesn't start to behave I'm gonna push her off a cliff. #4 fuel injector line, and a transmission in the past month. My key was acting up yesterday but after I disconnected both batteries and set it sit, it managed to fix itself.
    Smarty Touch will be installed next week. Hello 500rwhp :D
  13. Mar 8, 2015 at 11:06 AM
    achirdo
    Adam
    North DFW
    And having 4wd is amazing. Makes ice driving and ripping around in the mud a little easier
  14. Mar 8, 2015 at 11:13 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    At least it was just your injector line and not your injectors :rolleyes: That was a hard check to write.
  15. Mar 8, 2015 at 11:18 AM
    achirdo
    Adam
    North DFW
    I'm sure that will come eventually... Maybe I'll build the motor up a little when they go. I've got the Transmission to hold it now. Triple disk torque converter, performance valve body, Billet input shaft, Billet Flex Plate, shit ton more clutches on each gear, and bunch of other Billet parts. Builder said he's got guys pushing 1000hp through the same transmission.
  16. Mar 8, 2015 at 11:27 AM
    Balockay
    Blake
    Cleburne, TX
    Can you do 500hp on stock injectors? I don't remember their limit off the top of my head. What part of your trans let go?
  17. Mar 8, 2015 at 12:01 PM
    achirdo
    Adam
    North DFW
    Yeah, you can do right around 500-530 on all factory motor.
    And im not entirely sure which part of the tranny let go. It was shifting erratically before it warmed up. I'm 98% sure the transmission shop just hosed me for a new one when it was probably just a sensor... But I wanted this truck to be able to hold some power and I had my excuse to do it. Now I shouldn't ever have to worry about transmission issues.
  18. Mar 8, 2015 at 12:05 PM
    fsbrain03
    Yay for Dodge!
  19. Mar 8, 2015 at 12:18 PM
    ThomasMore66
    I got your name from this thread. We're going to get those sliders done yet.
  20. Mar 8, 2015 at 9:11 PM
    achirdo
    Adam
    North DFW
    Pm sent
