Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Nov 27, 2015 at 5:41 PM
    RogueFuel
    RogueFuel Well-Known Member
    Its all good, right now I'm satisfied with my purchase.
  2. Nov 27, 2015 at 6:20 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Dakars FTW! And a little squeaking...
  3. Nov 27, 2015 at 8:49 PM
    Kfletch
    Kfletch Well-Known Member
    Kyle
    Rockwall, TX
    2016 Tundra Crewmax TSS Off-road
    Dang, I'm trying to stay as budget as possible...can't go dropping $1k on the lift alone.
  4. Nov 27, 2015 at 9:46 PM
    djniere
    djniere Well-Known Member
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    Or a spindle lift with an AAL wouldnt be a bad idea... If your 2wd
    Nvm. Just checked. Your 4x4
  5. Nov 28, 2015 at 7:34 AM
    jason_210
    jason_210 Well-Known Member
    Weatherford, TX
    2021 Barcelona red Tacoma
    Speaking of lifts... Will 5100's lift the truck alone or are Spacers still required?
  6. Nov 28, 2015 at 8:57 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    As for the spacers, all shops tell you different because they get a better deal with different manufactures. I'd grab the cheapest one, they are all the same.
    5100s like Braeden said are 0-2.5 to the best of my memory
  7. Nov 28, 2015 at 12:16 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    5100's have lift settings for the front, and they can be used with stock coils. They have an adjustment for stock height, 1.25" lift (I think), and then 2.5" lift. It will ride rougher the higher you set them though. As for the rear, the 5100's will not provide lift on their own. You'll have to get new leaf packs (best option), an AAL, blocks (I wouldn't recommend), or do a shackle flip (since you're second gen) and lift shackle. If money is an obstacle, I'd say go with the AAL.
    Someone correct me if I'm wrong about the shackle flip. I'm not entirely sure about that as it isn't a first gen issue.
  8. Nov 28, 2015 at 4:37 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    @ramonortiz55 @MatthewMay1 I had the Hankook ATMs and like them a lot on my Tundra. I've heard they have pretty weak sidewalls though. But since I didn't wheel the Tundra, I don't have any experience with that. I don't have any experience at all with their AT.
  9. Nov 28, 2015 at 4:40 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Im more inclined towards the coopers, but all these hankook commercials are catching my attention
    those maxxis boghorns are sexy.. @MatthewMay1 how are they on road in regards tonroad noise? Ive heard theyre great offroad
  10. Nov 28, 2015 at 4:41 PM
    Balockay
    Blake
    Cleburne, TX
    @weldertaco has the Bighorns I believe. Maybe he can chime in.
  11. Nov 28, 2015 at 4:54 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Not sure, I would assume them to be as loud as you might expect them to be.
  12. Nov 28, 2015 at 7:12 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I'm thinking the MTR's are calling my name
    richardbui23 likes this.
  13. Nov 28, 2015 at 7:20 PM
    ramonortiz55
    Ramon
    Texas
    stock
    he wont
  14. Nov 28, 2015 at 7:23 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Cutting fenders and CMC and beating pinch weld don't bother me. Having to move my firewall back does
  15. Nov 28, 2015 at 7:26 PM
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
  16. Nov 28, 2015 at 7:32 PM
    Balockay
    Blake
    Cleburne, TX
    We can make quick work of all of the above. I have the tools.
  17. Nov 28, 2015 at 7:35 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Oh I've got the tools as well
    Hammer
    8 Ib sledge
    Welder
    12 Ib sledge
    Air hammer
    MatthewMay1 likes this.
  18. Nov 28, 2015 at 7:39 PM
    Balockay
    Blake
    Cleburne, TX
    I was thinking plasma cutter...
  19. Nov 28, 2015 at 7:48 PM
    ramonortiz55
    Ramon
    Texas
    stock
    flame thrower
  20. Nov 28, 2015 at 7:49 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    My life isn't perfect, hammers let the anger out. Plasma does sound tempting though.
