Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Apr 4, 2016 at 2:57 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Which coils though?
  2. Apr 4, 2016 at 2:59 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Hmn, now I'm wondering about removing mine.
  3. Apr 4, 2016 at 3:53 PM
    RickS
    RickS New Old Stock
    Rick
    DFW'ish, Texas
    '22 Tundra Limited
    Bobbles and trinkets
  4. Apr 4, 2016 at 5:49 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Ok Mechanic Types. I need a consult....
    Front brake lines on my 07, the fitting on the caliper end of the rubber line is seized up. I hit it with PB Blaster, and used the proper flared end wrench. Still took all the corners off the nut.
    How do I fix this? Is the easiest solution to get a new line from the caliper up to where the hose attaches, or am I overlooking another easy solution?
  5. Apr 4, 2016 at 7:21 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Clean up all the lube, torch, then vice grips. Should come right off. You can use the vice grips to put em back on as well. I don't recall the torque spec being very high on those brake lines, so just snug em. If you are able to get new lines, do it, just remember, very little torque to tighten, or you'll run in to the same problem again.
  6. Apr 4, 2016 at 7:27 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    Yes.
  7. Apr 4, 2016 at 7:57 PM
    Dajeepman
    Dajeepman Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    Bilstein 6112 shocks/ coil over.. I guess it will only give me 2.5" lift.. I might have to use a 1" strut spacer to get more lift.
  8. Apr 5, 2016 at 11:50 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Assuming y'all are talking sway bars (I'm not going back to re-read everything)
    I'm running no sway bar on bilstein 5100's set at the highest on stock coils and I drive like an ass hat and haven't rolled my truck yet. Just feels sketch but works fine. Do have in my garage some 885's I need to put on
  9. Apr 6, 2016 at 12:26 PM
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
  10. Apr 6, 2016 at 4:27 PM
    hoarder23
    Shay
    NJ
    Scratches
    elgringoloco likes this.
  11. Apr 6, 2016 at 8:21 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
  12. Apr 6, 2016 at 8:26 PM
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
  13. Apr 8, 2016 at 8:21 PM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    So who are the best vendors to use? Wheelers? Headstrong? I'm still a noob here...going to be doing an icon setup soon.
  14. Apr 8, 2016 at 8:26 PM
    hoarder23
    Shay
    NJ
    Scratches
    I have ordered from Wheelers, Headstrong, Downsouth, and TRDParts4U. Had good experiences with all, I'd focus on price first then company. With TRDParts4U theres tax but no shipping. With the others there's shipping but no taxes.
  15. Apr 8, 2016 at 8:32 PM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Trdparts4u is dallas based, isn't it?
    MatthewMay1 likes this.
  16. Apr 8, 2016 at 8:33 PM
    hoarder23
    Shay
    NJ
    Scratches
    Yeah, Toyota of Dallas
  17. Apr 8, 2016 at 8:35 PM
    Gingerbeard Man
    Jared
    North Dallas
    They are high at the dealer. I went there first as we bought the truck there. I won't do any business with them any more after my experience with the service department.
  18. Apr 8, 2016 at 8:35 PM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Do they do will call, or do they have to ship everything?
  19. Apr 8, 2016 at 8:45 PM
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    Have you heard of @ramonortiz55 ? He's quite the group buy vendor. And as a matter of fact, has an Icon group buy going on right now. 10% off retail, plus free shipping.
  20. Apr 8, 2016 at 8:53 PM
    hoarder23
    Shay
    NJ
    Scratches
    You should be able to pick up straight from them but some of the stuff may be drop shipped, you'd have to call them.
