Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Oct 4, 2016 at 9:23 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Dude, i would be really pissed. Good luck man
  2. Oct 4, 2016 at 9:50 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Which one have you been using? Mckinney Denton and Plano are all about the same distance from me.
    ChadsPride likes this.
  3. Oct 4, 2016 at 1:30 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I go to either Plano, Sport City, or Dallas
  4. Oct 4, 2016 at 3:20 PM
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Mckinney as they are the closest, Denton is a little further away, and then Plano/Richardson
    I'll post pics in a bit
  5. Oct 4, 2016 at 3:25 PM
    Gingerbeard Man
    Jared
    North Dallas
    Sport City and Dallas are far as fuck just for an oil change, I'll do it myself from now on before driving nearly an hour away. Plano is about 45 minutes. Richardson is about the same. Mckinney is about 20, and Denton is about 30
  6. Oct 4, 2016 at 3:35 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Only reason I'd ever take my truck to a dealer for an oil change is if they'd do it for free
  7. Oct 4, 2016 at 8:45 PM
    Gingerbeard Man
    Jared
    North Dallas
    They're free. The truck is less than a year old. IMG_4436.jpgIMG_4438.jpg IMG_4434.jpgIMG_4437.jpg
  8. Oct 4, 2016 at 9:13 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Your truck is older than you are, I wouldn't pay dealer labor either. Turds still have ToyotaCare
  9. Oct 4, 2016 at 9:14 PM
    hoarder23
    Shay
    NJ
    Scratches
    How did they even manage that?
  10. Oct 4, 2016 at 9:16 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Doh. Didn't realize you had a 3rd gen
    I may be the baby of TW, but I am still older than my truck!
  11. Oct 5, 2016 at 3:41 AM
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Good lord, that's not even close to trying.
  12. Oct 6, 2016 at 2:54 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    Just dropped off my new addition at Tandem Auto to get the full check up.
  13. Oct 6, 2016 at 5:57 PM
    ChadsPride
    Damn!!!! That thing looks clean!
  14. Oct 6, 2016 at 6:06 PM
    ThomasMore66
    1994 with 94.5k miles.
    All original.
  15. Oct 6, 2016 at 6:09 PM
    ChadsPride
    What a great find!!! That driver seat barely looks sat in for 100k!!
  16. Oct 6, 2016 at 6:26 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    It's even got a tape deck!
  17. Oct 6, 2016 at 7:52 PM
    djniere
    djniere Well-Known Member
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    Any of yall have problems with the stock uca hitting toytec springs on 5100s? When i lowered my 5100s to the lower clip with my jba UCAs my caster numbers are way to high now and may put the stocks back on. My numbers are almost to 6 degrees
  18. Oct 6, 2016 at 8:03 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Sorry to hear that bro. Which dealer did you take it to? 45 mins to Plano? Where do you live?
    Well, his are free for the first two years, so....
  19. Oct 6, 2016 at 8:04 PM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I've heard under 2" you should be able to get decent numbers with stock UCA's. I bet it's those JBA's causing the issue.
  20. Oct 6, 2016 at 8:12 PM
    ThomasMore66
    I don't even own a cassette. I'm curious though.
    Original air clearer wing nut.
