Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Dec 3, 2018 at 3:41 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And their emissions check is insane. I’d fail.
    MattCowsmasher likes this.
  2. Dec 3, 2018 at 4:43 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Worth it
  3. Dec 11, 2018 at 7:30 PM
    djniere
    djniere Well-Known Member
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    I meannnnnn. This is a bs thread.... 2” lift, 15x7 Motegis, and 235/75 wildpeaks finally installed todayE2DA37EA-2FE0-4E5D-9594-5852560BB6F3.jpg
  4. Dec 11, 2018 at 7:33 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Um...that’s only 40% a Toyota.
    But lifted...looks more like 60%. That’s a good height for that.
    Now you need lower body vinyl to protect from scratches.
    MattCowsmasher and ChadsPride like this.
  5. Dec 11, 2018 at 8:30 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    What lift?
    because_wumbo-truck likes this.
  6. Dec 12, 2018 at 8:56 AM
    djniere
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    Readylift SST 2”. Went with a spacer since no one seems to have a progressive spring lift out yet. Plus the most I carry is 2 bikes with gear.
    gulzeb[QUOTED] and ChadsPride like this.
  7. Dec 12, 2018 at 8:57 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Came out sweet dude!!!
    BassAckwards and MattCowsmasher like this.
  8. Dec 12, 2018 at 9:05 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    DIY? How easy/difficult?
  9. Dec 12, 2018 at 9:44 AM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Didn’t realize they made a headlight update on new crosstreks. Looks great btw
  10. Dec 12, 2018 at 6:03 PM
    djniere
    David
    Temple, TX
    2016 RAM 2500
    Stock boi
    Did it at a friends shop on a lift which made it alot easier. I wouldve paid someone to install if I didnt have access to one for the fact of how low it is compared to my tacoma. The actual install was not hard and took about 3 hours including trimming and clearance testing. The hardest part was the alignment honestly, the eccentric bolts for the Mcpherson struts was a pain as well. But Even after trimming the edge of the tires rub my mudflaps and the back fenderwell (front tire) by just a hair, seems that people are having clearance issues with the wildpeaks vs the k02s. Driving from burnet to CP i averaged 27.2.
    BassAckwards and gulzeb[QUOTED] like this.
  11. Dec 24, 2018 at 7:38 AM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
  12. Dec 24, 2018 at 7:55 AM
    ChadsPride
    :hattip:
    Sixt8kupe likes this.
  13. Dec 28, 2018 at 6:14 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Just make sure you know the rules and dont be the guy that wears a felt hat year round.
    Wear straw cowboy hats Memorial Day through Labor Day and felt cowboy hats Labor Day through Memorial Day. Basically straw for summer cause it cooler and felt in winter cause its warmer.
    Sixt8kupe and ChadsPride[QUOTED] like this.
  14. Dec 28, 2018 at 6:21 AM
    ChadsPride
    Sounds about right!
  15. Dec 28, 2018 at 7:23 AM
    Mitch76
    Mitch
    San Angelo, TX
    HAHA my mom still gripes at me when i put my cap on the bed. She grew up in a farming and ranching family and you always followed the rules of wearing a hat.
    Sixt8kupe[QUOTED] and ChadsPride like this.
  16. Dec 28, 2018 at 2:52 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    My rule of hat: if you wear a hat all day even though you spend all day indoors, you might be special
    Kolunatic, Sixt8kupe and 05prerun82 like this.
  17. Dec 28, 2018 at 9:23 PM
    ElSultan
    ElSultan Member
    2017 BBP Limited
    Thanks for the tags!
    ChadsPride and Sixt8kupe[QUOTED] like this.
  18. Dec 29, 2018 at 7:00 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    You called ???
    Sixt8kupe[QUOTED] likes this.
  19. Dec 29, 2018 at 1:18 PM
    ChadsPride
    8° last night driving into Santa Fe in a little 2wd Chevy car.
    I25 was icy and many many vehicles were sliding off into the ditches.
    Made it here about 11pm after driving slow af from Albuquerque
  20. Dec 29, 2018 at 1:25 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    I might be headed to NM too, but to Alamogordo (who came up with this name...). I’ll be in an AWD Outback though. Too bad white sands national monument is closed.
