Texas BS Thread
Discussion in 'Texas' started by achirdo, Jan 30, 2011.
  1. Nov 7, 2019 at 4:54 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The one in Llano is good? The original in the Fort Worth stockyards is just OK.
  2. Nov 7, 2019 at 5:12 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Yeah the one in llano is bomb. Better than salt lick and blacks ez. It used to be my go to hidden falls meal before I started wheeling so crossed I’ll tip yet truck yet be more concerned about my fireball red bull spilling
    The one in SA area is ass
  3. Nov 7, 2019 at 5:17 PM
    hoarder23
    Shay
    NJ
    Scratches
    I found Salt Lick to be overrated, pretty location but the meat was overhyped.
    CedarPark[QUOTED] likes this.
  4. Nov 7, 2019 at 5:20 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Agreed. It’s definitely better than your standard chain like Rudy’s but it’s more about the nice Texas vibe local
    Beretta4x4 likes this.
  5. Nov 13, 2019 at 9:38 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
  6. Nov 13, 2019 at 10:23 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    p1zombiekiller likes this.
  7. Nov 13, 2019 at 10:45 AM
    p1zombiekiller
    p1zombiekiller Well-Known Member
    Wes
    DFW
    2009 4x4 Access cab (Chocolate Taco)
  8. Nov 14, 2019 at 9:09 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Can the negative wire and chassis ground wire be run together to the battery? Im making my diesel transfer tank (with electric pump) mobile and want to run alligator clamps to the battery so i can use the power (battery) from whatever equipment im filling up. It has 3 wires: positive, negative, and chassis ground. Should be able to just run the negative and ground wire together on one clamp, right?
    ChadsPride likes this.
  9. Nov 14, 2019 at 9:12 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    I dont know but I think I missed your Bday. Happy late Bday brother!
    :cheers:
    Kolunatic likes this.
  10. Nov 14, 2019 at 9:13 AM
    Mitch76
    Mitch
    San Angelo, TX
    Thanks man! I appreciate that!
    Im going to throw my electrical question over in your build/BS thread (if you dont mind). Seems a little more active than this one :D
    Kolunatic and ChadsPride[QUOTED] like this.
  11. Nov 14, 2019 at 9:18 AM
    ChadsPride
    You bet! You're welcome anytime. Also, the TTC thread might get some good responses as well.
    :thumbsup:
    Beretta4x4 and Mitch76[QUOTED] like this.
  12. Nov 14, 2019 at 9:47 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Reason for 2 grounds is the one for the battery ensures that the max amount of voltage and amperage can be supplied without interruption. Chassis ground is to dissipate static electricity to mitigate explosion.
  13. Nov 14, 2019 at 9:52 AM
    Mitch76
    Mitch
    San Angelo, TX
    Since the tank and pump will just be mounted to a pallet and therefore mobile (via forklift), will i need to put a clamp on each wire or where do i need to run the ground wire? Can the ground and negative be run together to one clamp? Or will it work just using the pos and neg wires and not using the ground at all?
  14. Nov 14, 2019 at 12:30 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    You have three wires.
    Positive will of course got to battery positive.
    Negative of course will go to battery negative.
    Chassis ground stays seperate from negative and runs to a metal spot on the chassis to dissipate static electricity.
    You can't run the neg and chassis if they are already seperate.
  15. Nov 15, 2019 at 5:32 AM
    Mitch76
    Mitch
    San Angelo, TX
    I ended up running them together to one clamp that connects to the neg terminal. It worked, but is that a bad idea?
  16. Nov 15, 2019 at 5:58 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Static electricity can cause spontaneous combustion.
  17. Nov 15, 2019 at 6:00 AM
    Mitch76
    Mitch
    San Angelo, TX
    Well shit! Guess i need to find a place to ground that damn wire. Dont need my diesel tank going up in flames.
  18. Nov 18, 2019 at 9:30 AM
    Mitch76
    Mitch
    San Angelo, TX
    Well the black wire turned out to be negative and the white positive. To my surprise the little pump WILL run in reverse and i nearly blew the cap off of cause it was pumping air into the tank. :rofl:
  19. Nov 18, 2019 at 9:44 AM
    p1zombiekiller
    Wes
    DFW
    WELL CRAP!!!!! Now I am going to have to start reading the instructions on all my stuff.... You just blew it for me @Mitch7
    I had a whole weekend full of IKEA products to assemble, and now I need to spend the rest of the week reading.
  20. Nov 18, 2019 at 10:21 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Fyi, 12vdc, black is always ground/negative. Toyota is white wire with black stripe.
