Texas Classifieds 2.0 - Read Post #1!
Discussion in 'Texas' started by SuperBad, Jul 21, 2019.
  1. Jun 14, 2025 at 12:47 PM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Hello TW, I am selling my MaxTrac spindles that provide 4" of lift. These are in great condition with no bends or cracks. They have mostly been driven on pavement. You will need to purchase new hardware and extended brake lines. Here is a link to all the hardware needed. 706840EDITED13118-1.pdf. Local pickup in Houston TX
    MaxTrac Spindles - $350
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Jun 14, 2025 at 12:48 PM
    TheBlueBeast15
    Kevin
    H-Town
    Hello TW I have some stock TRD Offroad shocks for sale. The front suspension is off of a 2016 TRD Offroad with about 30k miles on them. The rear shocks are off my 2015 TRD Offroad with about 67k miles on them. All shocks don't have any leaks and are still in functional condition. Local pickup in Houston Texas
    Front shocks - $75
    Rear shocks - $50
    Everything - $100
    [​IMG][​IMG][​IMG]
  3. Jun 14, 2025 at 1:18 PM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Did you get these rebuilt local in Houston? If so who did the work ?
  4. Jun 14, 2025 at 2:46 PM
    TheBlueBeast15
    Kevin
    H-Town
    No I got them rebuilt in SoCal my a local member over there.
  5. Jun 15, 2025 at 7:13 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Subbed.
  6. Jun 15, 2025 at 3:06 PM
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    SOLD
    I purchased this vehicle new in 2013. At 1200 miles, I had a reputable local off-road shop install the Fabtech drop bracket lift. I also had our local audio shop install JL Audio components, including all door speakers, and added a 5-channel amp and subwoofer. I also had a remote start intalled while at thier shop. Since then, I have personally completed the following work with the help of my GT Freinds...
    • BlueSea two-battery system. The first battery, located under the hood, is new (about 6 months old) and powers the winch and starter, while the second battery, which is dead and needs to be replaced. The battery runs the fridge, multiple power outlets, stereo system, and extra lighting.
    • ARB onboard air compressor mounted under the hood on the p/s.
    • ARB fridge with homemade slide-out.
    • ARB front air locker with switches located in front of the cup holders below the stereo mounted to a custom plate from a TW member (can't remember their name :confused:)
    • Chevy 14 bolt rear axle with Grizzly limited slip locker. There has been about 1K miles driven since the rear axle was installed. One offroad trip and back & forth to work to keep it moving.
    • Decked system in the bed. The left drawer is stained with rust, due to it being left open during a car wash, and was not checked for some time. The spring that holds that drawer closed rusted also, and now does not stay shut.. I just place a chock block between it and the tailgate to keep it closed now. Unfortunately, all my tools rusted. :(
    • Leitner bed rack system with one regular GearPOD, one XL GearPOD, one universal mounting plate with two ROTOPAX 2-gallon fuel cans & mounts, one extra load bar, HI-lift brackets and a flagpole bracket (not mounted).
    • Bed stiffeners.
    • Prinsu roof rack with a Heritic light bar.
    • Fabtech 6 in drop bracket lift, with blocks in the rear and top hats up front. Rear shocks are Dirt Logic Fabtech's.
    • SPC upper control arms.
    • 17" Fuel wheels (I have a set of 5) but currently am running ProComp beadlocks on the rear 14 bolt.
    • Tires are Nitto Ridge Grapplers up front (37x13.5R 17LT) and Maxxis Trepadors on the rear (37x12.5 17LT). I have a full set (4) of each.
    • Cab mount chop to clear the tires.
    • Old Man Emu springs with an additional helper spring.
    • Custom made skid plates.
    • BMAF sliders.
    • SSO front winch bumper.
    • Smitybilt 10K synthetic winch.
    • Allpro rear bumper customized with a rear swingout spare tire carrier.
    • Relocated rear camera into trailer hitch.
    • Ditch lights with brackets (never ran wires).
    • Midland MTX100 two way radio w/RoadPro external speaker.
    • Cobra 29LTD CB w/Highgear external speaker.
    • Custom gear shift knob from CBoy808.
    • Custom climate control knobs.
    • Meso dual (red/white) map lights.
    • Color matched front grill.
    • Custom rear taillights color matched (completed by a TW member. I can't recall their name :confused:)
    • Ultraguage
    • Tekonsha break controller.
    • Dynamat along the back of the cab to reduce road noise.
    • Custom bed decals (created by TW member. I cant recall their name either :confused:)
    However, it needs the following repairs...
    • Replacing the second battery.
    • Replacing the A/C compressor (pulled vacuum and is holding, so no leaks).
    • Replacing the speed sensor on the rear axle (switching out the rear axle has eliminated the speedometer and turned on the ABS and Traction Control lights.
    • The front right CVC axle is also broken, but I have another one available.
    • P/S mirror was broken on the trail but I was able to replace the lens with a universal one from Autozone and it still functions correctly.
    • No rear seats.
    • No rear P/S seatbelt. (was removed to replace my sons in his truck to keep my grandson safe :).
    • Plenty of bumps and scrapes from the trails ;).
    I'm sure I'm missing something but am trying to be as honest and transparent about my rig. I built this truck to be a street legal rock crawler, my bug out truck to go anyhwere I needed. Only reason I am selling is that I have taken over my wifes 19' 4Runner as she is incapable of climbing in and out of the truck after her back surgery. I would love to see this go to someone who appreciates it for what it is. The Book of Faces does not fair well for this kind of vehicle.
    I am the original owner, and I have a clear blue Texas title in hands.
    I am also open to trades of equal value or trades plus cash.
    If interested in the original installation of the Decked System click HERE.
  7. Jun 15, 2025 at 6:42 PM
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    When will you be in Austin?
  8. Jun 16, 2025 at 4:08 PM
    Zack
    Austin, Texas
    SOLD
    On Marketplace
  9. Jun 16, 2025 at 4:54 PM
    ozzytoyota
    ozzytoyota Well-Known Member
    ossie
    2017 Tacoma TRD Pro
    I will be in Austin next weekend.
  10. Jun 19, 2025 at 10:46 PM
    SA4runner
    SA4runner Well-Known Member
    Jesse
    2018 Cement DCSB OR 4x4
    For Sale: Ranch Sierra Truck Cap – Fits 3rd Gen Toyota Tacoma (6-Foot Bed)
    Price: $650 OBO
    Selling a Ranch Sierra truck cap that fits a 3rd gen Toyota Tacoma with a 6-foot bed.
    This cap is painted Cement Gray (Paint Code: 1H5) to perfectly match factory paint.
    Features:
    Factory Paint Match
    Fully Carpeted Headliner
    12V LED Dome Light
    Tinted Windows
    Two Sliding Side Windows with Pet Screens – great for ventilation and furry friends
    Sleek, Low-Profile Design
    Condition:
    Overall in great shape and fully functional.
    Note: The passenger side strut bracket needs replacement – the strut itself is fine, just the bracket.
    Optional Add-on:
    Also selling a BedRug bed liner with matching tailgate rug – $100 (separately or bundle with cap for a deal).
    Located in San Antonio
    Let me know if you want to come check it out or need more photos!
    $1,000 OBO – motivated to sell.
  11. Jun 20, 2025 at 5:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is the console vault still available
  12. Jun 23, 2025 at 5:47 AM
    ozzytoyota
    ossie
    2017 Tacoma TRD Pro
    Anyone local to Austin, Houston, Dallas or Oklahoma.
    I have HARDWARE ONLY for Softopper Tacoma 05-22 5' Bed. I say local cause the cost of shipping is pretty high. Asking $100 or OBO or Trades(s).
  13. Jun 25, 2025 at 10:57 AM
    ETBA
    ETBA Well-Known Member
    Erik
    Texas
    2021 TRD Off-Road
    Cleaning out the garage and I need this stuff gone. Saw and Wrench set are brand new, duplicates of tools I already own.
    Prices are OBO. If interested, shoot me a message and we’ll work out a deal. Located in Ft Worth
    Milwaukee Circular Saw - $75
    Milwaukee 3/8 M12 ratchet w/battery - Sold
    Husky 20pc Ratcheting Wrench set - $70
    BassAckwards likes this.
  14. Jun 28, 2025 at 4:04 PM
    SA4runner
    Jesse
    Bump for price drop.
  15. Jun 30, 2025 at 8:27 AM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Random things for sale.
    Headlights off a 2014 TRD Offroad
    $250.00 - Shipped
    Desert Does It Seat Jackers - Need to find the extra bolts for them, so not pictured.
    $60.00 - Shipped
    Warn Winch Fairlead
    $30.00 - Shipped
    Bed Tied Downs
    $50.00 - Shipped
    Located in Tyler, can bring to DFW if heading that way.
    Hattr1ck and Deathdealer like this.
  16. Jul 3, 2025 at 10:25 AM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    ISO: factory fender flares for a 2nd gen tacoma. Color doesnt matter. Im located in SA.
  17. Jul 4, 2025 at 6:04 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I have a pair of wheel spacers in San Marcos. $100 OBO.
  18. Jul 4, 2025 at 2:33 PM
    MohoMan
    MohoMan TTC #0165
    Sean
    Austin
    99 Limited
    TTC badging
    ISO: 3rd gen trd wheel takeoffs with good tread. Located N Austin
  19. Jul 4, 2025 at 7:09 PM
    ETBA
    Erik
    Texas
    2021 TRD Off-Road
    ratchet sold
  20. Jul 5, 2025 at 9:20 PM
    Chairmanmeow66
    Chairmanmeow66 Well-Known Member
    2020 Tacoma TRD off road
    For sale
    All stock parts from trd off road
    -Coilovers
    -uca
    -ubolts and brackets
    -leaf springs
    $350 for everything
    Houston area
