Texas Gun Sticky
Discussion in 'Texas' started by Sleipnir, Feb 21, 2018.
  1. Jun 12, 2019 at 8:23 PM
    #641
    tex.proud
    tex.proud Jesus Christ It's Midnight!
    Huntsville, TX
    2018 White SR5 4X4
    3" OME lift with SPC UCA's HD Dakars Decked bed system KO2's 165/75/16 CaliRaisedLED mount for Everhardt CB Antenna President Bill FCC CB Kenwood TM-D710GA HAM radio and Larsen antenna through roof. TVD Vinyl Decals for the tailgate (Black Reflective) and U.S. Flag decals SofTopper (Black) Empyre Offroad Grill Blacked out badges (PlastiDip)
    That lever works well on most AR's. I've heard of some dremel polishing things for smoother operation. Getting rid of burs and such. Your mileage may vary. I realize it's a VERY SIMPLE thing, but some people on forums get ANAL! go figure.
    CedarPark likes this.
  2. Jun 12, 2019 at 9:18 PM
    #642
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers
    Yeah a lot of people on gun forums seem like snobs, think i'll stick here. When I get it gonna strip down the AR and do some cleaning. Anything I should look out for? About 300 rounds into it now
    Also, I wanted a CZ but I think my next purchase might be building a 9mm AR just because 300 blackout is so god damn expensive
  3. Jun 12, 2019 at 9:40 PM
    #643
    tex.proud
    Huntsville, TX
    2018 White SR5 4X4
    Yeah, that 300 Blackout is out of my budget. If it runs smoothe then leave it alone. I would, however look through the upper and lower receivers with your fingertips, or Q-tips. You can easily feel snags/burs from machining. These can, over time be a bad thing. Even if only scratching your mag catch as you release them. The barrel and chamber will be fine, that's a precision crafted part. It's the not so precision parts that you want to look at. Most likely you wont have any concerns, but there is the occasional oops from any manufacturer. If you're nuts about knowing your firearms as I am, then knowing every aspect of it from top to bottom is of concern. If I have a failure with any of my firearms, I know exactly what it is...because I know them down to the very last part and surface. It's a thing. I don't own a firearm that I am not "Intimate" with, if that makes sense. (Not a sexual innuendo, but a serious detail). I'm anal about my guns, but not a snob of forum legend!
  4. Jun 13, 2019 at 8:17 AM
    #644
    Sleipnir
    Sleipnir [OP] Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd F150 Ecoboost
    Build a 9mm upper unless you really want to build another. If you build the upper you can use Endomags with a Foxtrot Mike bolt and will have no issues. I would recommend a heavier spring and buffer because I tested my upper last week and had some FTF with some good primer strikes:notsure:
