Texas Taco Tire Tale
Discussion in 'New Members' started by 0007tacoluvr, Sep 10, 2019.
  1. Sep 10, 2019 at 7:25 PM
    0007tacoluvr
    0007tacoluvr [OP] Well-Known Member
    James
    2016 Tacoma2.7L 4x2 AT Large Cab SR-5, GLX
    Thanks for the add guys. I am looking for advice on changing my wheels from the 17" TRD SEMA wheels (weighing 24.8 lbs.) to the 16" TRD beadlock style wheels (weighing 23.7 lbs.). I initially meant to decrease the weight of my wheel/tire setup which consisted of factory base steelies that weighed 61 lbs. together. I ended up purchasing the 17" TRD SEMA wheels with Nitto Terra Grappler A/T after seeing them on the truck. They really changed the stance and overall look. I am about to make a drive to Pennsylvania and I would like to resort back to my original plan of lightening the wheel with the 16" TRD beadlocker and a factory tire. I should be able to achieve a 52.7 lb. rotational mass weight with this setup. What do you guys think?
    Bigdaddy4760 and Taco critter like this.
  2. Sep 10, 2019 at 7:30 PM
    1&3-TACOMA
    1&3-TACOMA Well-Known Member
    TX
    1998 & 2019 TACO
    1998 stock 4x4 2019 trd off road: Trd wheels TRD Pro grille Led headlights, reverse, license and interior
    If you get the beadlock and I speak from experience the ring must be as centered as possible other wise the balance will be terrible. But overall both end up looking badass on the truck. I have the headlocks on mine and my dad has the sema wheels. Oddly enough my truck rides way smoother but it’s likely a bad balance job.
    Taco critter likes this.
  3. Sep 10, 2019 at 7:56 PM
    0007tacoluvr
    James
    I do like the look of both wheels, though my Tacoma is a 2.7L I4 so I would like to do what I can to reduce the rotational weight of the wheels. I should have done this in the beginning and I would have shed 8 lbs. per wheel, rather I gained nearly 8 lbs.
  4. Sep 11, 2019 at 5:18 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  5. Sep 11, 2019 at 10:30 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  6. Sep 12, 2019 at 6:13 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
