TG for Tacoma World
Discussion in 'New Members' started by Food forester, Aug 22, 2023.
  1. Aug 22, 2023 at 6:09 PM
    Food forester
    Food forester [OP] Member
    05 Tacoma 2.7 Liter
    Aloha from Hawaii,
    I've been cruising the Tacoma World forums for years to work on my 05 Tacoma 2.7 Liter.
    It's been great to learn from other people's experiences.
    Finally hitting a headwall after replacing the crankshaft position sensor after getting the PO335 code since my truck still won't start.
    Hoping to get guidance for checking the wiring, appropriate fuse, and plates for which I can't find any info anywhere.
    Good luck to you all,
    Food Forester
    HondaGM and buckhuntin-tacoma like this.
  2. Aug 22, 2023 at 6:11 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  3. Aug 22, 2023 at 6:19 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome aboard!
    Food forester[OP] and HondaGM like this.
  4. Aug 22, 2023 at 6:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm assuming the engine cranks over but doesn't fire?
  5. Aug 22, 2023 at 7:32 PM
    Food forester
    05 Tacoma 2.7 Liter
    Correct. I have gone thru the troubleshooting steps and now need to check the crankshaft plate next.
  6. Aug 22, 2023 at 7:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    By far the best way to check a crank and/or cam sensor signal is with an oscilloscope, there's not really any other way to properly check the signal itself. The circuit can be checked with a meter.
    What led up to the truck not starting?
    TnShooter and HondaGM like this.
  7. Aug 22, 2023 at 8:09 PM
    Food forester
    05 Tacoma 2.7 Liter
    The truck was driving fine and then it just died while driving.
    Cranks but doesn't start.
    Unfortunately, I don't have an oscilloscope.
    Thanks for the file. I just found that earlier today.
  8. Aug 22, 2023 at 8:15 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean if wiring between the sensor and the PCM checks good and isn't shorted to ground there's not much else you can do besides check the signal with a scope.
  9. Aug 22, 2023 at 8:34 PM
    Food forester
    05 Tacoma 2.7 Liter
  10. Aug 22, 2023 at 8:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's to re-sync the PCM and immobilizer, US 2.7L trucks don't have an immobilizer.
  11. Aug 22, 2023 at 9:05 PM
    Food forester
    05 Tacoma 2.7 Liter
    You called it. The "reset" didn't make a difference.
  12. Aug 22, 2023 at 9:09 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's not going to run without a crank sensor signal, are you sure you got a good sensor and it's seated properly?
    Food forester[OP] likes this.
  13. Aug 22, 2023 at 10:57 PM
    Food forester
    05 Tacoma 2.7 Liter
    I picked up the only sensor on the island and double checked it was seated right.
    Tested the resistance on the sensor and it was fine.
    I think I may try swapping the ECM with a friend's Tacoma that is the same make and model to see if it is the ECM and then if necessary check the teeth visibly.
    Thanks for your input, makes a difference out in the middle of nowhere.
    Steves104x4 likes this.
  14. Aug 22, 2023 at 11:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the truck and how old is the battery?
  15. Aug 23, 2023 at 9:13 AM
    Food forester
    05 Tacoma 2.7 Liter
    186k miles. Battery is 2 years old and holds a charge.
  16. Aug 24, 2023 at 2:28 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Have you ever replaced the valve cover and spark plug tube gaskets? When the truck is idling, is the tachometer needle steady or does it bounce around? Edit: pop out the number 4 coil (because it’s easiest to access) and see if the tip where it goes around the plug is oil coated (it should be dry)
  17. Aug 24, 2023 at 2:31 PM
    Food forester
    05 Tacoma 2.7 Liter
    Never replaced valve cover. Just replaced the coils a couple years ago, will check them.
    It was running fine and then just died while driving. Got PO335 code when I checked it.
  18. Aug 24, 2023 at 2:41 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I’d try another battery for shits and giggles.
