Thanks for having me!
Discussion in 'New Members' started by Aqyassaran, Nov 24, 2020.
  1. Nov 24, 2020 at 2:49 PM
    Aqyassaran
    Aqyassaran [OP] New Member
    2017 Toyota Tacoma TRD Sport
    I have to say. I ran into a few bumps hunting this year. And having a bad issue with abs trac brake light. Dash lights on does not want to go into 4x4 and my bam dont work. With no check eng.. so I have a decent diag scanner that is able to read the codes how ever. Gave me a big fu. No connection but I can see all the osb2 info.. So I checked all my fuses. All have power.. has anyone had this issue with the lights on or lack of communication from abs mode? I can put it in 4x4 if i put it in 4x4 put in N. Turn off truck turn back on she will go in 4x4.. i am assuming the is a abs sensor but not able to pull the codes to confirm... PS. MIL light has never came on . I did have just a track light on but I reset the steering angle sensor and it went a away. For about 2 weeks than this happend driving low speed on a gravel road doing 60klm in 4 high.. Any input would help of you had a similar issue
    wilcam47 and Black DOG Lila like this.
  2. Nov 24, 2020 at 2:50 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Nov 24, 2020 at 3:35 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Aqyassaran[OP] likes this.
  4. Nov 25, 2020 at 9:39 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  5. Nov 27, 2020 at 2:03 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  6. Nov 27, 2020 at 8:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Your OBD2 scanner will not read ABS codes, need a different ($better$) scanner for that
    OBD2 is only concerned with things that will make the emissions get worse (tail-pipe emissions, evap, etc)
  7. Nov 27, 2020 at 8:36 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Welcome!
