= => Thanks YOSH! My Version of the "RETRO" BHLM <= =
Discussion in 'Lighting' started by RAD, Aug 21, 2010.
  1. Aug 22, 2010 at 1:00 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    FX-R's w/Phillip Bulbs.
  2. Aug 22, 2010 at 1:06 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    are you going to 3M or laminex them to protect the investment?
  3. Aug 22, 2010 at 1:10 PM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    good choice :)
  4. Aug 22, 2010 at 1:14 PM
    RAD
    Rad
    LAX & LOGAN
    ^ I heard its a pretty nice set up. =)
    I'll Clear 3M them to protect the outer shell
  5. Aug 22, 2010 at 1:30 PM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    they look awesome. all my stuff is still sitting in the boxes:( all i have done is holesaw and dremel the reflector bowls but one ill get them finished up. where did you get the sealant at if you dont mind me askin?
  6. Aug 22, 2010 at 1:31 PM
    RAD
    Rad
    LAX & LOGAN
    3M Windshield Butyl Sealant. Works wonders!
  7. Aug 22, 2010 at 2:33 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Same stuff I use! I thought you got the Nissan OEM stuff.
  8. Aug 22, 2010 at 2:42 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    when you guys use sealant to put these things back together do you heat them up again to try to get as much of the old stuff out or do you just put the new stuff over the old and put them back together that way?
  9. Aug 22, 2010 at 3:31 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    I leave the stock stuff in there. Just push them back in the channel as much as you can when it is warm after you pulled it apart. Then, use the new. You want to stretch it and put it in the channel all the way around it.
    The first set of headlights I did with this stuff, I didn't stretch the sealant, so the headlight could not close all the way.
  10. Aug 22, 2010 at 3:40 PM
    jasona250
    jasona250 Well-Known Member
    jason
    ventura california
    07 double cab prerunner trd offroad
    dam those look good!
  11. Aug 22, 2010 at 3:50 PM
    IamTacO
    adam
    QC az
    i reuse the oem sealant as well. i did it with my wrx and i did it with my current retro with no issues. i left my truck outside during a heavy rain last night and i have zero fogging or water inside.
  12. Aug 22, 2010 at 4:53 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    Damn, those things look legit!
  13. Aug 22, 2010 at 4:57 PM
    outlaw7
    Brandon
    PacNorWest
    2010 trd sport
    thanks for the heads up
  14. Aug 22, 2010 at 6:29 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    wait are you guys talking about putting 3m over the headlights housing lense?
  15. Aug 24, 2010 at 12:35 AM
    #35
    RAD
    Rad
    LAX & LOGAN
    Ran Out to take a few Pictures of it Complete. :D
  16. Aug 24, 2010 at 7:42 AM
    #36
    IamTacO
    adam
    QC az
    do you have fx-r's in your fogs??
  17. Aug 24, 2010 at 7:48 AM
    #37
    RAD
    Rad
    LAX & LOGAN
    Naw....Its in my headlights. My HID fogs get trapped inside the Retros output. I wasnt on the most level angle surface as it was ackward
  18. Aug 24, 2010 at 8:06 AM
    #38
    IamTacO
    adam
    QC az
    ok, was just commenting on the color, they look very yellowish, like a 3000k fog light or something.
  19. Aug 24, 2010 at 8:06 AM
    #39
    RAD
    Rad
    LAX & LOGAN
    ^ Yeah its the 3k HIDs in the Fogs. . . My lights are real bright. The HID and RETRO combo:eek:
  20. Aug 24, 2010 at 8:07 AM
    #40
    IamTacO
    adam
    QC az
    :Dahhhh, very nice setup you have there. glad you got them wired up and working.
