That crazy third brake light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cheaterpipe, Jan 6, 2013.
  1. Jan 6, 2013 at 10:06 AM
    cheaterpipe
    cheaterpipe [OP] Member
    First off, my truck is an 09 DCSB TRD Sport. I am the second owner and as far as I can tell, the only after market accessory added from the previous owner might be the side steps.
    Since I have had the truck I have shut off the factory key less entry beeps and the seat belt chimes. I also spliced in a switch for the Day time Running Lights and left them off.
    My question is; why is my third brake light flashing 3 times before remaining constantly on when the brakes are being applied?
    I realize it's good to have for safety reasons (if that's the case), but I have been behind a many Tacoma's and have never noticed the flashing third light before.
  2. Jan 6, 2013 at 10:21 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Someone has added a brake light flasher module. I have seen one on a Tacoma once before. I believe the manufacturers of those modules recommend not to put it on the main brake lights because it confuses driver's, as they may mistake it for turn signals even though both sides would flash. I put one on my motorcycle too. Added bonus for you.
  3. Jan 6, 2013 at 11:00 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I always wondered about those lights!
  4. Jan 6, 2013 at 2:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Some vehicles get the flashers from the factory, as a "test". From what I have been able to gather. Some blink constantly, some blink between 3 and 12 times before going solid. I had one on my 2000 Tacoma.
  5. Jan 6, 2013 at 3:58 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    I had to go out to the garage to check after reading this.
    I'm safe, steady third brake light, whew! :)
  6. Jan 6, 2013 at 4:07 PM
    Vstrom30
    Midwest
    I see it as an added safety feature. I would leave it on there.
  7. Jan 6, 2013 at 4:16 PM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Never seen one on a taco. Saw one on a motorcycle and it was irritating as hell.
  8. Jan 6, 2013 at 4:21 PM
    Vstrom30
    Midwest
    I hope the one on my bike is irritating. That means it is visible.
  9. Jan 7, 2013 at 8:39 AM
    cheaterpipe
    I'll go with it being added as a safety feature, and I'll leave it there. My first thought was I had cut something by mistake, or I might have a bulb out. Now that it has been mentioned, I have seen motorcycle brake lights flashing. If it helps by keeping morons from reshaping my bumper then it will stay.
    Thanks for the replies and the laugh.
  10. Jan 7, 2013 at 8:46 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I have one on my motorcycle and that's the point. If it's irritating, that means it's noticable so the person behind me notices that I am stopping instead of running me over. :)
  11. Jan 7, 2013 at 9:10 AM
    pbm317
    pbm317 Well-Known Member
    It would be helpful if there was some sort of industry standard that allowed the blinking to indicate a panic-type stop, more than 80% of max pressure applied, etc. to help for some differentiation between braking efforts.
