That darn dome light!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Why Kyle, Jan 5, 2013.
  1. Jan 5, 2013 at 8:45 PM
    Why Kyle
    Why Kyle [OP] New Member
    Kyle
    Seattle
    All guys and gals-
    I've googled this, and searched here. I can't find my answer though. I am adding some light strips from SuperbrightLEDs, and I want them wired in with the dome light. Only I can't trace the pink/blue/black-white wire to anywhere. Not too sure where it ends up under the dash, the a pillar, or in the door sill. it's a simple install, if I can find the wire. Fire away...
    Thanks
    Kyle
  2. Jan 5, 2013 at 8:49 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    Are you gonna run the LEDs off the dome light circuit or through a relay?
  3. Jan 5, 2013 at 8:55 PM
    Why Kyle
    Kyle
    Seattle
    Just off the circuit. I guess I should have specified that. Also, it's a 2012 TRD.
  4. Jan 5, 2013 at 10:58 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    Well you could just run a hot from the dome light itself, and pick up a ground.
  5. Jan 5, 2013 at 11:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Nope.
    Dome light gets a hot 24/7 directly from the fuse box.
    The ECU applies a ground to it through the blue wire when the door is opened.
    Aux lights would have to be wired the same... Power going to the "+" side of the aux lights, and the "-" side going to the blue wire.
    Someone tried a relay and it didn't work... just chattered when the ECU dimmed the dome light.
    Need to keep the total draw down. Replace the original dome light with LED, and at that point, you can safely drive about 5-7 watts worth of LEDs (including the replacement dome)
    Blue wire should be in the bundle in the A-pillar.
  6. Jan 5, 2013 at 11:32 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    fuse panel beside the steering wheel there are two connectors on the left as shown in diagram below:
    the bottom connector has a white wire (pin 2) that is the positive and a blue wire (pin 9) which is the ground
  7. Jan 5, 2013 at 11:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Perfect!
