That darn fuel pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dubblejab, Apr 8, 2025.
  1. Apr 8, 2025 at 3:09 PM
    Dubblejab
    Dubblejab [OP] New Member
    Bought a used 2018 tacoma trd off road in May 2024. It had not had the fuel pump recall done yet so I had the dealer swap the high p fuel pump. Yesterday, 11 months later, the high p fuel pump died and a delphi one cost me $1100 plus labor. Not to mention being stranded. Is there a warranty on toyota recall work?
  2. Apr 8, 2025 at 3:55 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    That's a good question. I would think that there would be some level of warranty coverage on recall work involving the installation of new parts. But I doubt that warranty is long enough to do you any good with your situation but maybe I'm wrong. And in your case, you have already remedied the situation by doing the repair out of pocket versus letting Toyota address it.
    I did see that Toyota will reimburse if an owner had to pay out of pocket for a repair that is addressed by a recall or special service campaign. But in your case, the recall work was already done and 11 months later the replaced part shit the bed. Good luck with this one, but I think you might be hosed here. Good luck
    Here is a link to the thing I am talking about: What if you have previously paid for repairs to your vehicle for a specific condition outlined in a recall or special service campaign?
    4x4spiegel likes this.
  3. Apr 8, 2025 at 4:04 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    From Toyota website. Seems like you might have 12mo warranty.
    I had a part replaced at an authorized Toyota dealership that was not covered under warranty. What warranty coverage do I have for this part?
    The Toyota Service Part Warranty is in effect for 12 months, regardless of mileage, from the date...
    I had a part replaced at an authorized Toyota dealership under warranty. What warranty coverage do I have for this part?
  4. Apr 8, 2025 at 6:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think the recall was for the high pressure fuel pump.
    Chew likes this.
  5. Apr 8, 2025 at 6:10 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The fuel pump recall is for the low pressure fuel pump in the tank.
    The high pressure fuel pump has a warranty enhancement program for fuel odor under the hood and a TSB to replace chirping high pressure fuel pumps that chirp while under warranty.
    The recall should not have touched your HPFP. Also, how does a HPFP go “bad?” It’s mechanical and has very few things on it to go bad…I would think it it went bad it might wipe the cam lobe that drives the pump.
    shakerhood and Chew like this.
