That gimmick called Crawl Control...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RESQMAN, May 7, 2018.
  1. Jul 18, 2019 at 4:21 PM
    #101
    ryan760
    ryan760 Well-Known Member
    Not close at all.
    The only thing close to CC on the SR5 Tacos is TRAC, which can be used in 4HI.
    TRAC is similar in operation to ATRAC/MTS/CC except that it is less aggressive with the brake limited slip, and it cuts engine power in addition to applying brakes to spinning wheels (something you don't want when off roading). That being said, TRAC may be better than open diffs in some situations.
  2. Jul 18, 2019 at 5:28 PM
    #102
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Trac off In 4 low - tires spinning- light touch on brakes - won’t this move power to the non spinning wheel?
  3. Jul 18, 2019 at 5:33 PM
    #103
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Wait... Doesn't it have five wheels? Spare doesn't count? :bananadead:
    Cudgel[QUOTED] likes this.
  4. Jul 18, 2019 at 7:27 PM
    #104
    ryan760
    No because the brakes are applying equal force to both the left and right wheels, so there is no transfer of power to one side or the other.
  5. Jul 18, 2019 at 10:52 PM
    #105
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I have always seen the benefit of slow smooth gear changes as a function of an AT.
    Now I am not trying to start a debate AT vs MT, but anyone who has driven on soft sand in an MT appreciates the need for smooth shifts that take allot of skill vs being inherently there with AT.
    Well I see Crawl applications similarly. If your tires aren't hooking up on a steady uphill climb, the AT makes the job easier for anyone short of a MT shift master. The steeper the climb, the more you'll wish you had the low gear low speed torque of a MT.
    The MT gives you more instant power, but that can cause wheel spin, reduced traction etc.
    So my guess is that CC is AT specifically because it shines in areas where an AT would otherwise struggle or heat up etc. Specifically situations that call for slow and steady or mad skills.
    My FJ has a clutch overide that leverages the starter motor to crawl, but hike you use your feet to paddle gas and brake (I think, I never have used it).
  6. Jul 19, 2019 at 5:51 AM
    #106
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I find MTS more useful than crawl control personally. I’m surprised no one really talks about that
    snwbrdr852 and ryan760 like this.
  7. Jul 19, 2019 at 7:00 AM
    #107
    The_Devil
    E
    I have one 4x4 of each, and I have experienced the pros of each.
    The AT would be my choice for weekending nearby as the terrain is predictable but the other drivers not so much.
    If I am on a real expedition with life or death on the line, the MT has some reliability benefits.
    My opinion, my FJC MT 4x4 Full time vs. Tacoma AT with me driving vs an expert.
    Flat sand = AT
    Dunes = MT
    Rocky = AT
    Medium Mud = MT
    Thick Mud = winch
    Water crossing = AT
    Steep climbs = AT
    Ronny Dahl sums this up in a great video on Youtube.
    dfanonymous[QUOTED] likes this.
  8. Jul 19, 2019 at 7:05 AM
    #108
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    I regret not buying an OR over my Sport, although I added front and rear lockers on mine. I would definitely recommend getting an OR or PRO with crawl control over the other trims if someone was looking to get a Tacoma.
    Aldo98229 likes this.
  9. Jul 19, 2019 at 7:14 AM
    #109
    ryan760
    MTS is great. I'm still not exactly sure what the different settings do... I know they vary the amount of slip of the wheels or whatever, but am curious if that means the amount of rotation the wheel makes before the brakes grab, or how much clamping force the brakes apply to the wheels? Does anyone know?
  10. Jul 19, 2019 at 7:27 AM
    #110
    dfanonymous
    I use it in lieu of a front locker. So I’ve had my rear tire hanging and my opposite front tire not getting traction on loose rock/dirt. I just pop that thing on, and set it to almost max setting and my tires that did have good traction powered out. It’s not as effective as having a locker but a truck in general isn’t going to do what a Jeep does without heavy mods and even with that, there’s still a wheel base issue. Point being MTS works for what I need it for.
    ryan760[QUOTED] likes this.
  11. Jul 19, 2019 at 7:59 AM
    #111
    Alahawg
    Alahawg Active Member
    I think it depends what the terrain is where you off road at. Crawl control works great in rocky terrain and sand but poorly in mud. In mud you need to give it more throttle to clean some of the mud out of the threads to keep going. I've only seen crawl control used once on the mud and it got stuck when he got pulled out he went back through the same hole without crawl control and made it without to much trouble.
  12. Jul 20, 2019 at 8:04 PM
    #112
    jrain904
    jrain904 Well-Known Member
    I guess you changed your mind about CC? In my thread you basically sh*t on it the whole time lol.
    Jorge3098 likes this.
  13. Jul 20, 2019 at 8:20 PM
    #113
    aro
    aro Well-Known Member
    Orange County, CA
    2019 OR DCLB 4X4
    I never used CC for climbing, but I used it for going downhill on steep trails with big rocks. It's absolutely great! I used it a lot in my Wrangler, and I'm really happy my Taco has it as well.
    The Wrangler has a hill descent control only, nothing for going uphill. I actually find it more practical to control the vehicle myself when going uphill, in case I need to rock it over an obstacle, but that doesn't mean I won't experiment with it.
  14. Jul 20, 2019 at 8:35 PM
    #114
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I would rather Toyota put a locking diff on the front with a solid front axle option instead of the crawl control.
  15. Jul 20, 2019 at 9:20 PM
    #115
    dfanonymous
    I’m curious how that would work at 65 mph on the highway. Like legit curious. Because I’d imagine it’d be like driving a Jeep, where you feel like your driving partly sideways.
  16. Jul 20, 2019 at 9:27 PM
    #116
    jamestkirk
    jamestkirk Well-Known Member
    Moab Utah
    1999 Pre Runner 2017 TRD OR
    i never use CC. but the various MTS modes have gotten me out of a bunch of shit....kirk out
  17. Jul 20, 2019 at 9:50 PM
    #117
    slowtacotruck
    17 offroad
    stuff
    My f350 is fine with a solid front axle. I think the taco would be too.
  18. Jul 20, 2019 at 10:46 PM
    #118
    Jordan11586
    Jordan11586 Well-Known Member
    Jordan
    I have a manual transmission in my 2018 Offroad so mine didn’t come with crawl control but I have first gear and front and rear lockers which works much better.
  19. Jul 20, 2019 at 10:56 PM
    #119
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Definitely. It has its uses in the right situations. There are still times it does nothing but typically in those situations I need a new line.
    It’s fun to play with. Not sure I would ever rely on it.
    Aldo98229 and HighCountryTacoma like this.
  20. Jul 21, 2019 at 12:15 AM
    #120
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    That's what she said
    JoeCOVA[QUOTED] likes this.
