That gimmick called Crawl Control...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RESQMAN, May 7, 2018.
  1. Jul 21, 2019 at 1:16 AM
    #121
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Unless you are ascending or descending a steep ass hill and not in a parking lot with fake as moguls.
  2. Jul 21, 2019 at 2:21 AM
    #122
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Land Rover and even the new Ranger can be smooth why can't Toyota?
  3. Jul 21, 2019 at 5:27 AM
    #123
    jrain904
    jrain904 Well-Known Member
    Definitely agree never to rely on it. Just another tool in the shed. Cheers.
    JoeCOVA[QUOTED] likes this.
  4. Jul 21, 2019 at 7:45 AM
    #124
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Because Toyota is using a constant application of the ABS system to give you a feature that isn’t a gimmick, but a powerful tool.
    -The ranger ‘Trail Control’ rolls backwards every so often and makes you shit your pants on the way up steep stuff. Ford does not seem to be using the brake-indexing that is what makes Crawl Control such a safe system in very steep terrain.
    -The Land Rover system will work for 2 months then cost you $26,000 to fix, with a special wrench you need to order from the Ukraine.
    Bromano likes this.
  5. Jul 21, 2019 at 2:30 PM
    #125
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    Wrong
    You don't just have 580/1.
    That's just the largest reduction with all three transfer cases in low.
    You have 50 some gears, bro. Yes, one would be wise to select a gear that works well for the particular situation.
    Also, you're not likely to "granade" anything. Most likely thing that would happen is a spiral fracture of an axle.
  6. Jul 21, 2019 at 2:35 PM
    #126
    BillyToy
    PNW
    What kind of front locker did you install?
  7. Jul 21, 2019 at 3:52 PM
    #127
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    Regardless, the system functions smoother. It doesn't have to be jerky. Toyotas implementation at low speeds seem to be on or off the brake with no in between
  8. Jul 21, 2019 at 3:57 PM
    #128
    Stocklocker
    17TRDORDCSBAT
    Not when you are on steep terrain.
    Anyone using crawl control, at minimum speed, on level ground, doesn’t know what they are doing, and for sure should go trade in their Tacoma for a Landrover with 80 series tires on wheels you are not allowed to change.
  9. Jul 21, 2019 at 4:24 PM
    #129
    taco_feevuh
    taco_feevuh SUUUUUUUUUUUUP?!
    Merritt Island, FL
    2018 cement Tacoma TRD OR 4x4 DCSB
    Rci sliders, Trd pro grill, Fox 2.5 fronts, Fox 2.0 rears w/resi, SCS Ray 10’s, Cooper stt pros
    I honestly rarely use CC. When I do, it’s usually after I’ve already gotten past the obstacle(s) using other functions like the rear locker. Then I might go back and hit it with CC. There’s a lot to be said about a lil common sense and a rear locker. I’ve never had to really rely on CC yet but I’m sure that day will come, and it will be nice to have another trick up my sleeve to try
  10. Jul 21, 2019 at 4:42 PM
    #130
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    Because low traction scenarios only exist on steep terrain
  11. Jul 21, 2019 at 4:56 PM
    #131
    Stocklocker
    17TRDORDCSBAT
    Because you only want the brakes and the gas applied simultaneously in steep scenarios. Crawl control makes no sense on level ground. It does not increase traction, it indexes progress when wheel spin would cause undesired effects.
    If you find yourself needing additional traction on level ground, consider MTS, or maybe push the gas pedal a bit harder, or air down the tires.
  12. Jul 21, 2019 at 5:06 PM
    #132
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    Which isn't at all how it's marketed.
    I do agree, MTS is where it is as and always overlooked in favor of cc.
    Stocklocker likes this.
  13. Jul 21, 2019 at 5:58 PM
    #133
    Stocklocker
    17TRDORDCSBAT
    I agree.
    The marketing of crawl control is a fail. I feel it was aimed at new off-roaders worried about getting stuck. Crawl control does not get you unstuck. Stuck is stuck.
    The engineering behind the system is solid, which is why Toyota offers it on flagship products like LandCruiser. It’s just not really the system described in the Tacoma marketing.
    If you ever need it, you’ll be glad you’ve got it. It’s not a relaxing system to use, so it’s gotta be a “crawl control or death” situation before I think to turn it on.
    ninernation[QUOTED] likes this.
  14. Jul 21, 2019 at 6:44 PM
    #134
    Jordan11586
    Jordan11586 Well-Known Member
    Jordan
    2018 Tacoma TRD Off-Road
    ARB with an ARB twin air compressor, the largest one they make.
    BillyToy[QUOTED] likes this.
  15. Jul 21, 2019 at 6:54 PM
    #135
    Not_Sure
    Not_Sure Well-Known Member
    J
    NC
    2019 Model 7545 in Silver Sky
    Bike rack
    Drive a 20+ year old 80 series Land Cruiser. Smooth and straight.
  16. Jul 21, 2019 at 6:57 PM
    #136
    Stocklocker
    17TRDORDCSBAT
    That’s because they only do 30MPH.
    Not_Sure[QUOTED] likes this.
