That sound when you start your truck cold..
Discussion in '4 Cylinder' started by Forster46, May 16, 2011.
  1. May 16, 2011 at 8:35 PM
    Forster46
    Forster46 [OP] Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    You guys know that sound when you start your truck in the morning for the first time, and you hit the gas and get that loud raspy sound?
    Does anyone know of the best way to get this sound with a muffler?
  2. May 17, 2011 at 5:32 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    So what you're saying is you WANT that sound..?
    When I got my magnaflow type muffler it did it alot when going down hills but now not so much.
  3. May 17, 2011 at 10:10 PM
    Forster46
    Nick
    Mount Vernon, WA
    Yeah I was thinking magnaflow would be the closest option.
  4. May 17, 2011 at 11:05 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Well Idk how to get that sound. But I can tell you revving a cold engine is bad! You have to let the oil get around everywhere and let it warm up before you rev up. ;)
  5. May 17, 2011 at 11:37 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    2x.
    Unless you feel like paying for a ring job.
    I don't know if the 4cyl is the same, but the v6 has steel sleeves that can't be bored. If the 4cyl is the same, once the engine block is gone, its gone.
    That being said, you might want to be nice to the cylinders. Don't skip on oil changes. Don't let the engine over heat. Don't rev the engine when its cold...
    Just my .02
  6. May 18, 2011 at 6:39 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    The computer already revs my engine up to ~2100 rpm's for 5-15 seconds on a cold start, no matter the temperature outside. Dealership says it's normal, even though they tried to prove it by starting a new 2.7L on the lot and it only revved up to 1500 rpms max. My air injection blower runs on every single cold start, thus driving the rpm's high until it shuts off.
    The spark plugs are new, air filter is new, throttle body was cleaned, MAF sensor was cleaned, and there are no vacuum leaks.
    Hopefully 2100 rpm's on a cold start is not damaging the engine block. I only have 21,000 miles on the truck.
  7. May 18, 2011 at 9:14 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    Thats different... All engines are designed to do that.
  8. May 18, 2011 at 9:16 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You're fine, mine goes up to around 1800 every time and 170k miles later it runs perfect.
  9. May 18, 2011 at 10:42 PM
    Forster46
    Nick
    Mount Vernon, WA
    The 4 cyl revs high when starts on purpose. I think it heats everything up faster that way. I read that in a thread on here somewhere i think.
    Also, i don't rev my engine right when i start it haha. I know its bad. But back when i first got it, i did a few times, and the sound is just really cool. Even if i let it warm up a couple minutes, then go down the road, it makes that same sound when you step on it, and its awesome.
  10. Jun 1, 2011 at 3:37 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    I heard that the high rev on cold start is for emissions reasons -- the higher rpms (and advanced spark?) burn the rich cold fuel mix more efficiently until the metal surfaces get a bit warm then the rpms come down after 20-30 seconds. So yeah it's OK to rev it a little (under 2.5-3k) while driving during warm up, people are just saying don't get on the gas too hard it until it's fully warmed. I live around the corner from an on-ramp that I take every morning and I gently get up to speed going 60mph well before it's anywhere near warm, but I barely break 2k rpm in the process. No problems with this truck whatsoever, 60k miles. I might not feel as comfortable if my first few miles of driving were steep hills.
  11. Jun 1, 2011 at 3:49 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    ^^ wtf does that actually happen?
  12. Jun 1, 2011 at 3:49 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Track pipe. Cat delete.
  13. Jun 1, 2011 at 3:52 PM
    DGXR
    Friend
    Sacramento, CA
    Exactly. And that is not the sound the OP is talking about.
  14. Jun 1, 2011 at 4:06 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    oh ok, that would be an issue if it did that on a cold start, thats definately not good for a cold motor....dumbass
