that ticking issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The_Hodge, May 4, 2007.
  1. Sep 14, 2007 at 10:44 PM
    #61
    Jimbo
    Jimbo Well-Known Member
    North Louisiana
    07_4x4_Access Cab_V-6_Manual-6_Silver Mica
    None yet
    Hey guys, I have the rather annoying infamous engine tick comming from most noticeably the driver side of engine. Seems to get louder after warmed up. I don't notice the ticking at all while driving though, unless next to a wall or sound reflecting surface. Then I hear it a bit. Mostly at idle and from the outside of the truck. I have not taken it back to dealer yet or tried isolating an emmision valve on the head and near the oil filter? I hope this ticking can be quieted. I only got 1100 miles on her, it's a July 2007 build date. Is there a 2007 TSB for this or a fix other than trying the emmission o-ring? Other than the ticking, it's awesome! I love my truck! :confused:
  2. Sep 15, 2007 at 12:43 PM
    #62
    Raptor
    Raptor New Member
    07 Double Cab TRD Sport w/ Towing
    Block Heater
    I also hear the 'ticking' noise on my 2007 Tacoma TRD Sport V6 when the engine is warm and idling (or low rpm). I have approximately 20,000 kms on the truck but noticed this problem with extremely low mileage.
    I've had the dealership look at the truck 3 different times and although I've had them admit to hearing the noise ONCE they claim there are no problems. It definitely sounds like a valve problem - I've tried several different grades of gasoline from different stations with no solid impact on what I'm hearing.
    The 'tick' is very noticeable for both myself and my spouse when we listen (outside) while the truck is idling without having to press our ear to the body.
    This is concerning that others have verified the same problem with the 2007 models and the fact that the only remedy seems to be a tear down and rebuild of the engine to fix the valves or whatever makes me wonder if the life span of the engine has been impacted.
    The only other beef I have about the truck is the body paint - it's EXTREMELY easy to scratch the paint with a finger nail or even a cardboard box.
  3. Sep 16, 2007 at 7:36 PM
    #63
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    It's two plastic pieces that work along with the timing chain, it will not do any harm.
  4. Sep 17, 2007 at 9:06 AM
    #64
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I'll second raptors complaint about the paint. i have several small scratches in my paint, seems to be very easy to scratch.
  5. Sep 28, 2007 at 9:52 PM
    #65
    aaronb43
    aaronb43 Well-Known Member
    Edmonton AB Canada
    07 SR5
    Can anybody else confirm that it is a timing chain issue? I also have a 2007 Tacoma 4 litre, and I also have the tick.
  6. Sep 29, 2007 at 11:56 AM
    #66
    GMG3
    GMG3 Carolina Alliance: Golden State Division
    Hawthorne, CA
    07 Access 4X4 SR5 TRD Off Rd Manual 6 Tow Spd
    Well, when ya'll back into a tree, ya gotta expect a couple a scratches:D
  7. Oct 1, 2007 at 10:00 AM
    #67
    nd
    Nate
    Greenville, SC
    For the record, i didnt hit the tree, the tree hit me
  8. Oct 2, 2007 at 7:13 AM
    #68
    Deezz22
    Deezz22 Member
    Chattanooga,TN
    TRD Sport 4x4
    so how did you go about getting this done? did you print off the TSB and take it to the dealer and no questions asked fixed it? How long did that ordeal take to get done? thanks in advance
  9. Oct 2, 2007 at 6:07 PM
    #69
    kilo
    kilo Solo Member
    San Antonio, Texas
    I'm in a Toyota club here in the Dallas area and the task at hand was pulling the entire motor out of this old 4runner and the guy doing most of the work, works at Toyota of Dallas, told me it was the timing chain. That it wouldn't do any harm and if I remember right, that it would pretty much go away after about 10-15k miles.
  10. Oct 2, 2007 at 9:45 PM
    #70
    RockPig
    RockPig New Member
    2005 2wd Taco
    Hey guys/gals...I just bought a slightly used 05' 2wd 2.7 4cyl, does the 4cyl apply to this TSB? Also, how do you read the vin# on the TSB? I have a letter where the TSB shows a * then an X where the TSB shows a U. If I read this right my X comes after the U, so I'm ok???
  11. Mar 24, 2008 at 12:48 PM
    #71
    roquelopez
    roquelopez New Member
    Tijuana, Mexidco
    07 Prerunner TRD SPORT
    GT88
    Can You update on what happened with your Truck? Toyota gave you any kind of answer? I filed a complain with the Consumer Bureau and Toyota did not even showed up, they just decided to pay a 1,000 USD penalty for doing so. It is quite frustrating hearing that noise and the only answer toyota gives is that it is a normal noise for tacomas.
    I also have had an steering problem for over a year now, and the dealer just keeps saying that it was a missalignement and that is being corrected. My truck is a 4X2 but it appears to have the soul of a 4X4! it constantly goes to the left or to the right at speeds over 55mph.
    I think more people should complain about problems with tacomas. Toyota is not up to their "Legendary Quality".
    Have a good day.
  12. Mar 24, 2008 at 1:45 PM
    #72
    superlinerms
    superlinerms Member
    mississippi
    96 & 98 sr5 4x4 & 2x4
    1996 4x4, 3'' spacer lift and Baha Claws. Cold Air Intake and dual exhust. Power programmer. Billet Grille. also 98 4x2 lowerd 5'' TRD 4x4 front cap, custom interior,
    I used to work for toyota and Ive been working with toyota's for years. Everyone that i have ever worked on has had a tick.. we all call it the TOYOTA TICK. Some are louder then others but it is the design of the heads and how the valves are shimmed. no matter how you shim them and what kind of oil you put in them they are still going to tick... my 96 sounds just like a diesel and i drive it 100 miles everyday. It has 196,000 and counting I've never had any problems out of it.. when it breaks ill fix it.. lol.
  13. Mar 25, 2008 at 9:32 AM
    #73
    Jimbo
    North Louisiana
    None yet
    Thanks for that comment superlinerms. I now have over 10,000 miles on mine and have changed to Castrol Syntec full synthetic oil. Guess what? the tick is still there. I have grown very used to it and it doesn't bother me anymore. I never even hear it unless I'm outside of the truck while it's running. I've kind'a grown fond of it in a way.
    No one should let this bother them. The Toyota tick will be there from now till never, and so will your Taco. That's what counts! ;)
  14. Jun 21, 2009 at 3:45 PM
    #74
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I have the tick as well, I have tried the o rings and they didnt do anything. My truck sounds really bagged out too. I took it to the dealership in Canada where I live with an american TSB for the manifold replacement printed out. They found the canadian TSB that matched and will be replacing the manifolds when the parts arive. I will post back with my outcome after it is done.
  15. Jun 21, 2009 at 3:54 PM
    #75
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    #11 iamrayzian [​IMG]
    RADMOJO
    I have that tick on mines and was hoping i can take mine in. Do you think they'll give me "ISH" for my Dough Thorley ong Tube Headers?
    I need to take it in.:confused:
  16. May 10, 2010 at 3:01 PM
    #76
    tacotick
    tacotick New Member
    i have read about everything on this site about the ticking. I believe most of it is either on the driver side or passenger. When the window is down, driving up against a retaining wall or another vehicle for that matter, it is a very annoying ticking or dinging sound.
    Two dealerships could not fix this in a total of 8 working days.
    I finally decided to try to fix it myself. What I found was that the front calipers have two pad keeper pins with no bushings whatsoever. They flop around very badly.
    Temporarily, I put zip ties between the cotter pins and the caliper to reduce the play.
    This worked. I have found that there are suppose to be bushings and grease appied to these parts and that my brand new 2009 does not have either.
    I'm still trying to get my hands on the correct way to put this together.
  17. May 10, 2010 at 3:03 PM
    #77
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    that link dont work
  18. May 10, 2010 at 3:25 PM
    #78
    The_Hodge
    The_Hodge [OP] Volunteer Moderator
    SC
    well the thread is only 3 years old:rolleyes:
  19. May 10, 2010 at 8:23 PM
    #79
    johnw
    john
    orlando florida
    shoot i never look at dates. lol. guess i should now huh
  20. Jun 1, 2010 at 12:31 AM
    #80
    ianc
    ianc Well-Known Member
    ian
    mass
    tacoma sr5 trd
    My 2010 has the same ticking issues. Here it of walls when drivng by then. Very effen annoying.
