The “My Back Hurts” Thread
Discussion in 'Off-Topic Discussion' started by 1993t100, Jun 8, 2014.
  1. Jul 23, 2020 at 5:25 AM
    1993t100
    1993t100 [OP] I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Umm sir, that don’t look right.
    Oreo Cat[QUOTED] likes this.
  2. Jul 23, 2020 at 5:45 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Special mod for air flow
  3. Jul 23, 2020 at 11:30 PM
    Oreo Cat
    Might have a blown head gasket yaaaaay
    Matmo215 likes this.
  4. Jul 23, 2020 at 11:33 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    V8 swap time
  5. Jul 23, 2020 at 11:42 PM
    Oreo Cat
    I have tried to find out in the past if the 4.7 tundra uses the same trans and I think it does
  6. Jul 23, 2020 at 11:43 PM
    Oreo Cat
    I couldn’t do the wires i suck with that stuff
  7. Jul 24, 2020 at 12:08 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    2j bolts up to the r150 I think lol
  8. Jul 24, 2020 at 12:15 PM
    Oreo Cat
    I think it’s a a350 trans not whatever that one is for
  9. Jul 24, 2020 at 12:16 PM
    Oreo Cat
    No exhaust fumes in the coolant, going to Toyota to get looked at before I start ripping shit up
  10. Jul 24, 2020 at 12:21 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What makes you think it’s a blown head gasket?
  11. Jul 24, 2020 at 12:27 PM
    Oreo Cat
    It is an 06, seems to be a thing for 05/06. Mine also has 225k miles. Kinda got spooked when it happened because how many others there are with the problem
    PapaBear likes this.
  12. Jul 24, 2020 at 12:32 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Oh second gen...pos
  13. Jul 24, 2020 at 12:38 PM
    Oreo Cat
  14. Jul 24, 2020 at 12:45 PM
    95 taco
    95 taco Battle Born
    When what happened? Are you loosing coolant? Running hot? White smoke from exhaust?
  15. Jul 24, 2020 at 12:58 PM
    Oreo Cat
    Missing coolant then overheated when I stopped after a 3 hour drive
    95 taco likes this.
  16. Jul 24, 2020 at 1:03 PM
    95 taco
    95 taco Battle Born
    Interesting, have you done a pressure check on the coolant system? Top it off and do a pressure check, you’ll either visually see a leak of coolant or if you lose pressure without a visual leak it’s likely a head gasket failure.
  17. Jul 24, 2020 at 2:31 PM
    Oreo Cat
    It’s at Toyota right now getting a diagnosis so I’ll see what they have to say
  18. Jul 24, 2020 at 3:02 PM
    Oreo Cat
    I took it into Toyota for its appointment at 1pm, they said they would have an update around 5. Do y’all really think they need 4 hours to look over the cooling system or are the just bullshitin around?
  19. Jul 24, 2020 at 3:07 PM
    95 taco
    95 taco Battle Born
    To properly diagnose 2-3 hours wouldn’t be unheard of, it takes all of 5 minutes to do a coolant system pressure test and check for obvious leaks.
  20. Jul 24, 2020 at 4:29 PM
    Oreo Cat
    Water pump and thermostat. Big relief it’s not the head gasket
    95 taco likes this.
