The “My Back Hurts” Thread
Discussion in 'Off-Topic Discussion' started by 1993t100, Jun 8, 2014.
  1. Aug 5, 2014 at 2:25 PM
    #3321
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Ehh, not knocking the OEM stuff by any means, im just reporting my findings from crawling TW... for the most part these trucks are solid.. but everything wears out eventually.
    On another note, im convinced my trucks likes 93 Octane better than anything else, im getting WAY better mileage on 93, im looking at about 350 per tank compared to just over 200 on 87
  2. Aug 5, 2014 at 2:27 PM
    #3322
    1993t100
    1993t100 [OP] I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    I'll have to try 93 when I get my Ultragauage in. See what the MPG difference is.
  3. Aug 5, 2014 at 2:28 PM
    #3323
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I thought that 2nd gens are suppose to be 91 but can detune down to 87
  4. Aug 5, 2014 at 2:28 PM
    #3324
    Holy schmidt
    Wyatt
    Nebraska
    Ha ha ha! I can run 87 perfect
  5. Aug 5, 2014 at 2:28 PM
    #3325
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Its the ethanol. My truck hates it too. Thats why i run 89.
    If we had the internals of the earlier 4thgen 4runners (like we should, fuck you toyota!) we could run anything, even e85 and it would get good mileage.
    Tractorman likes this.
  6. Aug 5, 2014 at 2:29 PM
    #3326
    Gaunt596
    Matthew
    Central Maryland
    not sure, all that is available around me is 87, 89 and 93 with ethanol... i can get 93 without ethanol, but its from a race shop and runs about $6 a gallon, and i can only buy it in batches of 100 gallons at a time.... so far havent taken them up on that, no place to store that gas
  7. Aug 5, 2014 at 2:30 PM
    #3327
    AR15xAR10
    87 is the recommended minimum. 91 is what makes the v6 produce a few more HP (not noticeable without a dyno)
  8. Aug 5, 2014 at 2:30 PM
    #3328
    Gaunt596
    Matthew
    Central Maryland
    if the mounting is the same its should swap right in.
  9. Aug 5, 2014 at 2:31 PM
    #3329
    AR15xAR10
    You don't want to do that anyway. No way to keep it stable long enough. And transporting it/storing it is not worth it.
  10. Aug 5, 2014 at 2:31 PM
    #3330
    AR15xAR10
    I don't know what is different. My 04 4Runner could run e85 and its the same got damn engine :pout:
  11. Aug 5, 2014 at 2:33 PM
    #3331
    Gaunt596
    Matthew
    Central Maryland
    Thats what i figured
    Willing to bet its the Dual VVT-i compared to the single VVT-i in our 1-GR... so provided you can get an engine with an ECU you should be all set
  12. Aug 5, 2014 at 2:37 PM
    #3332
    AR15xAR10
    That 4Runner was rated at 254hp stock compared to the tacoma at 236hp so something was definitely different
  13. Aug 5, 2014 at 2:40 PM
    #3333
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I run the cheap shit. If I get that much more mpgs I'm gonna switch :popcorn:
  14. Aug 5, 2014 at 2:43 PM
    #3334
    AR15xAR10
    I think his truck is just afraid of ethanol like mine. I recommend anyone spend a few extra cents and just run 89. You don't want to jump to 93 and get the motor hooked on it. Then it will get lazy and hesitate any time you go back to 89 or 87.
    If you stay in the middle at 89, you can run any of the three through it. :D
  15. Aug 5, 2014 at 2:48 PM
    #3335
    Boogyman
    Phoenix
    Corpus Christi, TX
    When I worked at a performance shop we would reset the comp just by taking out the battery for 30 min and then use higher octane fuel. Especially for the race cars that were also DDs
  16. Aug 5, 2014 at 2:59 PM
    #3336
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I should do that sometime
  17. Aug 5, 2014 at 3:02 PM
    #3337
    Gaunt596
    Matthew
    Central Maryland
    Hey Boogyman, i saw earlier you were talking about getting a new bumper, what are the plans for the one you have now? i like the original style that eddy came up with, its different than all the other ones on the market, and a lot cheaper too.
  18. Aug 5, 2014 at 3:03 PM
    #3338
    Gaunt596
    Matthew
    Central Maryland
    kep in mind though the MPG will be garbage and it will take a good bit for the comp to relearn the maps
  19. Aug 5, 2014 at 3:05 PM
    #3339
    Holy schmidt
    Wyatt
    Nebraska
    its a tank or two to learn it right?
  20. Aug 5, 2014 at 3:07 PM
    #3340
    Gaunt596
    Matthew
    Central Maryland
    i think so, ive also heard it helps if you reset when the temperature and humidity arent outrageous either.
