The “My Back Hurts” Thread
Discussion in 'Off-Topic Discussion' started by 1993t100, Jun 8, 2014.
  1. Aug 19, 2014 at 3:08 PM
    #4321
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    there shouldnt really be any play at all. if there is, your alignment is probably out of whack and would cause vibes and whatnot
  2. Aug 19, 2014 at 3:11 PM
    #4322
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Do both tires need to be full droop or can I do one at a time?
  3. Aug 19, 2014 at 3:14 PM
    #4323
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Turn signal
  4. Aug 19, 2014 at 3:15 PM
    #4324
    1993t100
    1993t100 [OP] I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    I fuck bitches....
    Fuck u papa
    Fuck u papa
    Are you serious Jon? LOL
  5. Aug 19, 2014 at 3:16 PM
    #4325
    Konaborne
    Cody
    Kealakekua, Hawaii
    doesnt matter, you can do one at a time
  6. Aug 19, 2014 at 3:17 PM
    #4326
    1993t100
    Big Sexy
    Nebraska
    Is that what you say when you bring home two bitches in one night?
  7. Aug 19, 2014 at 4:03 PM
    #4327
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I bet they'll have play at 200+k. I had to replace on of mine. Do what is said, mine was bad it would move a good 2"s back and forth. It shouldn't really move much at all
  8. Aug 19, 2014 at 4:36 PM
    #4328
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    also check your upper bj's.
    this too
    make sure you switch to halogen fluid to get better mpgs
    its in the exhaust
    not really, they aren't too hard to replace.
    again.... not too bad
    doubt it
    any time....
    come at me bro!
    you know he is.....
  9. Aug 19, 2014 at 4:57 PM
    #4329
    Konaborne
    Cody
    Kealakekua, Hawaii
    check bj play by shaking the top and bottom of the wheel
    tie rods, side to side
  10. Aug 19, 2014 at 5:19 PM
    #4330
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    No top or bottom movement but both tires will wiggle to either side....just enough until the steering wheel hits its lock.
    Tractorman likes this.
  11. Aug 19, 2014 at 5:23 PM
    #4331
    Konaborne
    Cody
    Kealakekua, Hawaii
    to be sure, try take it to a good alignment place. a good shop will always check for play since too much play=useless alignment
    but sounds like you might need a new set
  12. Aug 19, 2014 at 5:32 PM
    #4332
    AR15xAR10
    I think its normal, just checked the same thing on a brand new 2014 4runner and it does the same thing. No more play in it than mine. I think it is just the natural/normal play that the steering wheel has when in the locked position. I can get in the truck (with the keys out of the ignition, ignition is locked) and wiggle the steering wheel (only about an inch or so) from stop to stop while looking down at my wheels moving just as much as the steering wheel....
  13. Aug 19, 2014 at 5:41 PM
    #4333
    Konaborne
    Cody
    Kealakekua, Hawaii
  14. Aug 19, 2014 at 5:43 PM
    #4334
    AR15xAR10
    Vidya no worky work
  15. Aug 19, 2014 at 5:43 PM
    #4335
    Papa Taco
    Jared
    Socal
    a loose control arm will will also cause shimmies
  16. Aug 19, 2014 at 5:43 PM
    #4336
    AR15xAR10
    Am i looking for play in the wheel or the tie rod itself?
  17. Aug 19, 2014 at 6:00 PM
    #4337
    Papa Taco
    Jared
    Socal
    funny story about fire.... this use to be how long my beard was.....
    then I jumped through a 7 foot tall bonfire.... burned up a big chunk of my beard.... now I am bad to the beginning and trying to grow my beard out...
    I know that has nothing to do with tierods but I got bored with that topic.
  18. Aug 19, 2014 at 6:01 PM
    #4338
    smmarine
    Melbourne FL
    The wheel shouldn't move when shaken side to side. If it does you have play in the tie rods
  19. Aug 19, 2014 at 6:02 PM
    #4339
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    either.
    But when I was working in the shop i just used to yank on the tie rod feeling for a little clunk type thing. Kinda the same as checking sway bar links
  20. Aug 19, 2014 at 6:03 PM
    #4340
    TacoMitch93
    Mitch
    09 Tacoma SR5
    When you shake the wheel and you feel the little clunk its usually a wheel bearing, a bad wheel bearing.
