The “My Back Hurts” Thread
Discussion in 'Off-Topic Discussion' started by 1993t100, Jun 8, 2014.
  1. Oct 12, 2014 at 9:07 PM
    #7881
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    or swim up to the surface and ride the wave to sweet victory!
  2. Oct 12, 2014 at 9:33 PM
    #7882
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I mean I was tryna bring in humor with race, but yeah I agree with Mr. Authority over here.
  3. Oct 12, 2014 at 9:34 PM
    #7883
    taco terror
    USA
    AR bring your crotch over to insta, we need you.
  4. Oct 12, 2014 at 9:36 PM
    #7884
    taco terror
    USA
    Well this is encouraging. So how hard is the working part after graduation? (If people have told you)
  5. Oct 12, 2014 at 9:41 PM
    #7885
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Ight. I got chu bruh.
    Tractorman likes this.
  6. Oct 12, 2014 at 9:43 PM
    #7886
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I need yall's thoughts on something. A fluid has been leaking around my drums and has got the drum completely wet on the back, and partly on the front. It has occurred on both sides of the axle. I've been checking the brake fluid in the reservoir and it is not showing lower than normal. I feel that if it was brake fluid, I would see a noticeable difference in the fluid level because it's A LOT that has been caked on the inside of the wheels and outside of the drums. I'll post some pictures tomorrow in the daylight. Any thoughts on my issue will be appreciated!
  7. Oct 12, 2014 at 9:43 PM
    #7887
    MatthewMay1
    Matthew
    Lone Star Republic
    :rofl:
  8. Oct 12, 2014 at 9:47 PM
    #7888
    taco terror
    USA
    AR leaked his fluid on the drums? This band was a failure from the start. :(
    But it could be your axle seals.
  9. Oct 12, 2014 at 9:49 PM
    #7889
    MatthewMay1
    Matthew
    Lone Star Republic
    Axle seals....would that be an urgent issue?
  10. Oct 12, 2014 at 9:52 PM
    #7890
    taco terror
    USA
    Check your diff fluid level, shine your phone take a pic. It should be close to the edge of the filler plug threads. If it's low then that's bad juju
  11. Oct 12, 2014 at 9:53 PM
    #7891
    taco terror
    USA
    Aka full up dat bisnitch so you don't splode yer gears outta that axle from o'erheatin
  12. Oct 12, 2014 at 9:55 PM
    #7892
    MatthewMay1
    Matthew
    Lone Star Republic
    I've never checked my diff fluid before..... Not sure how to do that :anonymous:
    PS: I'm going to sleep. I'll check back here tomorrow
  13. Oct 12, 2014 at 10:01 PM
    #7893
    taco terror
    USA
    Aight go outside and take off the filler cap. (Hint: it's the bolt on the upper half of the housing, not the lower one.) shine a light in there and see where the fluid level is at, take a pic of it maybe and post it here. But you should be able to feel the fluid with your finger right below if not even with the filler hole.
  14. Oct 12, 2014 at 10:02 PM
    #7894
    taco terror
    USA
    P.S. You can't bail on me!!!!
  15. Oct 12, 2014 at 10:10 PM
    #7895
    AR15xAR10
    Shhhhhh, mine leak too. But i ignore that issue as it hasn't gotten to the point of leaking into my drums yet.
    You pull the drum/hub assembly and install new seals, you'll also have to drain the diff fluid and replace it.
  16. Oct 12, 2014 at 10:14 PM
    #7896
    taco terror
    USA
    Smell those 2nd gen probs boys? Those plastic beds must be too much of a load for the axle. #bustinseals
  17. Oct 12, 2014 at 10:53 PM
    #7897
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    nothing is handed to you on a silver platter like it is in school. When you learn in school the information you need to solve problems is generally presented to you. Then you head out tp your first job and even that shit is work to find, then you have to rely on it and apply it...with real consequences that effect real things. Am I an engineer? No...but I honestly cant imagine the experience is much different than what I went through my first round of real work as an accountant.
    has it fanned out onto your wheel? with streaks running out from the hub?
  18. Oct 12, 2014 at 11:07 PM
    #7898
    taco terror
    USA
    ^^^can I go back to being a child again? :(
    But yeah haha I'll stick with it and see where I land a job. Make the best of it.
  19. Oct 12, 2014 at 11:07 PM
    #7899
    taco terror
    USA
    Guys I'm worried about my dogs willy. He has the ooze. :(
  20. Oct 12, 2014 at 11:19 PM
    #7900
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    What is "the ooze"?
