The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Aug 26, 2013 at 4:25 AM
    #2581
    Maineiack
    Maineiack Well-Known Member
    Maine
    2013 stock reg cab 4x4
    I would have given that Nancy a Phucking Good Kicking!!![​IMG]
  2. Aug 26, 2013 at 4:47 AM
    #2582
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    YEP!
  3. Aug 26, 2013 at 8:23 AM
    #2583
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    Ok I have a bit of a problem and I wanted to see if anyone else had it too. A couple days ago I went offroading and while I was on a hill my tacoma stopped going (2011 with 265/75/16). The truck stayed at 2000 rpms with my foot on the pedal and the pedal to the floor and no wheel spin or forward movement whatsoever even in 4wd. So my ? Is do I need to regear?
  4. Aug 26, 2013 at 10:36 AM
    #2584
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yep
  5. Aug 26, 2013 at 12:02 PM
    #2585
    RedTacoDriver
    RedTacoDriver Out of my mind....be back later.
    Dale
    Portland, OR
    2012 Tacoma Regular Cab 2.7L
    BakFlipG2, Westin Nerf Bars, Harbor Freight Bed Jacks, Flame Devil Horns, vinyl raven emblems, intermittent wiper switch swapout More to come.
    I can't decide if the tent is eating or humping that truck.
  6. Aug 26, 2013 at 1:40 PM
    #2586
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    ROFL
  7. Aug 26, 2013 at 1:51 PM
    #2587
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
  8. Aug 26, 2013 at 2:31 PM
    #2588
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    i'm not really mechanic savvy and dont really know the do's and don'ts when it comes to spraying under the hood. i wanna do a yearly under the hood cleaning and it's about that time. what is the best and safest way to clean? what can get wet and can't? any help is appreciated! :confused::notsure:
  9. Aug 26, 2013 at 2:43 PM
    #2589
    Maineiack
    Maine
    Just spray some degreaser on it and spray it. Don't have the motor running or it will suck up water and hydro lock your engine.
  10. Aug 26, 2013 at 2:45 PM
    #2590
    Millertime187
    David
    Clay City, KY
    1995 Taco
    And don't spray hard on your fuse boxes. Be easy around that and wiring plugs!
  11. Aug 26, 2013 at 3:25 PM
    #2591
    nettto
    nettto Active Member
    San Diego
    2013 Tacoma 2.7l
    Good thread on engine cleaning hot vs cold, some suggestions /comments on cleaners, one post said to cover the top of the alternator in aluminum foil...
    http://www.tacomaworld.com/forum/detailing/176335-engine-bay-cleaning-hot-cold.html
  12. Aug 26, 2013 at 4:04 PM
    #2592
    jobrien
    Josh
    Ontario California
    Did I mention its an automatic? Idk if it will make a difference
  13. Aug 26, 2013 at 5:35 PM
    #2593
    jobrien
    Josh
    Ontario California
    I've got 45k on it
  14. Aug 26, 2013 at 6:49 PM
    #2594
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    thanks! that thread helped a lot. just got back from napa, i went with gunk engine degreaser and a bottle of simple green and a few brushes for the hard to reach places.
    God Bless this forum!
  15. Aug 26, 2013 at 8:06 PM
    #2595
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Check your brake light switch.
    The floor mat recall patched the software so the ECU shuts the engine down to idle if the brake is applied while the throttle is over 25%.
    May or may not be what happened, but it seems too new of a truck to have the clutch take a dump unless you are really hard on it.
  16. Aug 26, 2013 at 8:16 PM
    #2596
    Rich91710
    Rich
    Los Angeles
    08 Base
    No, but if the switch is misadjusted, it can trigger the brake light, which is the only way the ECU knows the brake is applied.
    Had more than a few guys complain their cruise cuts out and it turned out to be a bad or misadjusted switch.
    But in his case, it doesn't sound like it because the reflash should cut the engine to idle, not to 2000. It sounds like it simply stalled out and the trans was slipping the TC.
    If the trans was slipping internally (the clutch packs) it should throw a CEL with an input/output speed mismatch code.
    If his tires are oversized, it might be time for a regear, or use of 4lo.
  17. Aug 26, 2013 at 8:17 PM
    #2597
    jobrien
    Josh
    Ontario California
    Na I wasn't on the brake
  18. Aug 26, 2013 at 8:20 PM
    #2598
    jobrien
    Josh
    Ontario California
    After that I rolled down the hill and I tried to throw it into 4lo but my truck threw the a/t temp high ligh and 4lo was just beeping and not engaging. So I moved on to the next bypass and it was fine. This was the second time it has happened to me. The first time I just thought the hill was too steep. Looks like ill have to pay the stealership a visit
  19. Aug 26, 2013 at 8:36 PM
    #2599
    jobrien
    Josh
    Ontario California
    That's what I thought, but wouldn't I just dig in like I did in every other hill that's been too steep?
  20. Aug 26, 2013 at 8:38 PM
    #2600
    Rich91710
    Rich
    Los Angeles
    08 Base
    AT Temp? Ya... the TC was stalled out.
    Get the fluid changed ASAP.
