The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Feb 13, 2014 at 5:06 PM
    #3621
    Maineiack
    Maineiack Well-Known Member
    Maine
    2013 stock reg cab 4x4
    Where did you get your new one?
  2. Feb 13, 2014 at 5:51 PM
    #3622
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
  3. Feb 13, 2014 at 8:11 PM
    #3623
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Grandma driving like a boss.:cool:
  4. Feb 14, 2014 at 12:43 PM
    #3624
    ctSD
    ctSD Active Member
    Did the tent come with your mounts or rackd u have installed ?
  5. Feb 14, 2014 at 1:21 PM
    #3625
    Winker
    Winker Well-Known Member
    Paul
    Kentucky
    2019 Subaru WRX
    I'm considering giving this a try. I wouldn't mind something to make the flares and bumpers a bit more glossier. I think it would look great with the Barcelona Red Metallic.
  6. Feb 14, 2014 at 1:40 PM
    #3626
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    PFT. you drive like a sissy then.
  7. Feb 14, 2014 at 5:07 PM
    #3627
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    im just giving you crap hahaha.
  8. Feb 14, 2014 at 5:30 PM
    #3628
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    get 35s when you LT it since youre going to get a regear eventually :p
    i plan on regearing for 37s :anonymous:
    damn thats sexy looking...
    i wish i had a bed tent think like that...
  9. Feb 15, 2014 at 8:37 PM
    #3629
    Maineiack
    Maine
    I think a nice set of color matched linebackers would look nice on your rig.
  10. Feb 17, 2014 at 10:56 AM
    #3630
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Any one put a mechanical LSD in a Taco with traction control?
  11. Feb 17, 2014 at 3:14 PM
    #3631
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Someone had their axle replaced and instead of the electronic LSD model the dealer installed a mechanical. Happened maybe a year ago or a little less? I thought it would be a problem, but everyone else was like "You scored dude!"
    Found it....
    http://www.tacomaworld.com/forum/2n...eplaced-lsd-mechanical-rear-differential.html
  12. Feb 18, 2014 at 6:22 AM
    #3632
    MikeCB600F
    Plainfield, IL.
    The traction control sucks in the snow. When I turn it completely off, the E LSD is off.
  13. Feb 19, 2014 at 9:00 AM
    #3633
    ctSD
    ctSD Active Member
    Fenders FTW!!
    Btw i really like the front end on that taco.
  14. Feb 19, 2014 at 12:54 PM
    #3634
    ortlie09
    ortlie09 Well-Known Member
    Eric
    Sacramento
    11 Reg Cab 4x4
    Debadged, took off front mud flaps, prevent tailgate theft mod, Magnaflow 18" muffler, Bilstein 5100s front and rear w/ front @1.75, wet okoles, plasi dipped front emblem, weathertechs, scangauge, toolbox, Bed pocket lights, BHLM, T1 eyelids, BAMF sliders, Bruteforce Fab rear bumper
    255s! I'll be getting mine soon hopefully...
  15. Feb 19, 2014 at 1:50 PM
    #3635
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    I cant wait till my 265's run out so I can get some 255's
  16. Feb 19, 2014 at 1:54 PM
    #3636
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    What are you going with? 4.56s or 4.88s?
  17. Feb 19, 2014 at 2:07 PM
    #3637
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Nice, when are you regearing? I'll be interested to hear your thoughts, especially when you decide which size tires to go with. If I remember correctly Especk ran 4.88s with 315s and said it was pretty well wound up on the highway but the low end grunt was great. Do you drive much highway?
  18. Feb 19, 2014 at 2:24 PM
    #3638
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Wow, not bad. If I was in your situation I'd also rather be potentially over geared than under geared. I want to regear sometime in the next year but I drive a lot of highway so I'll most likely try to keep my rpms a bit lower while still getting some power back. I may move to 35s next if I do bother regearing so may as well go all out.
    Tough to figure out what to do in order to only buy things once!
  19. Feb 19, 2014 at 2:39 PM
    #3639
    ortlie09
    Eric
    Sacramento
    11 Reg Cab 4x4
    X2. I'm going with 255s because I don't want to regear
    Although for your needs, I guess it doesn't sound terrible. It wouldn't work for those of us who drive more
  20. Feb 19, 2014 at 3:23 PM
    #3640
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I could be in on this, depending on the cost of course.
    To add my .02 in on your gear/tire conversation, I run 255's with stock 4.30 gears and have all right low end power and low RPM's on the freeway. That being said, when I finally find a good e-locked rear end I will be re-gearing to 4.56. I had that same combo on my 4runner and found it to be perfect for how I drive.
