The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Apr 3, 2014 at 11:06 AM
    #4121
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    He could fit 40s then.
    Putting the stock doors back on will be a pain to line up. When I took the doors off my el camino I drilled a hole through the hinge into the cab. The fenders were off though, really helps getting it lined back up. Those doors were heavy as hell too.
  2. Apr 3, 2014 at 11:08 AM
    #4122
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    I am not a fan of glass fenders. Id rather just keep chopping the stock ones up instead of paying to put something so fragile on.
  3. Apr 3, 2014 at 11:10 AM
    #4123
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Make em :cool:
  4. Apr 3, 2014 at 11:12 AM
    #4124
    toyodajeff
    jeff
    06 reg cab sr5
    U got a welder dont you?
  5. Apr 3, 2014 at 11:17 AM
    #4125
    BabyTaco
    Wyoming
    2011 RC Tacoma
    What would that matter?
  6. Apr 3, 2014 at 11:50 AM
    #4126
    toyodajeff
    jeff
    06 reg cab sr5
    Turn up the radio and just make them to cover the tires, problem solved.
    When I had 35s If I touched the gas in mud it would be splattering my hood haha.
    Im a prerunner with flares.
  7. Apr 3, 2014 at 11:53 AM
    #4127
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Do some awesome tube fenders :). And like he said^^ turn up the volume.
  8. Apr 3, 2014 at 11:56 AM
    #4128
    toyodajeff
    jeff
    06 reg cab sr5
    Is 13 cup holders not enough, Im pretty sure you have a center console.
  9. Apr 3, 2014 at 12:15 PM
    #4129
    toyodajeff
    jeff
    06 reg cab sr5
    Inner and outer most likely just have rods connecting the handles to the latch, just cut or bend the rods like you need. Might have to cut out the sheet metal around the outer handle to move it, if you dont I bet mounting it would be a pain.
    Trailer wiring plugs would work for the disconnects.
  10. Apr 3, 2014 at 12:19 PM
    #4130
    toyodajeff
    jeff
    06 reg cab sr5
    You could always do that molle or mole stuff on the inside.
  11. Apr 3, 2014 at 12:21 PM
    #4131
    toyodajeff
    jeff
    06 reg cab sr5
    Arent single cab doors a little different shaped then extended and 4 doors.
    if so they might be hard to sell to ppl that bought base model trucks anyways.
  12. Apr 3, 2014 at 4:27 PM
    #4132
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Do post a write up when you do yours. I'll be curious to see how it turns out, I'll also be doing some cutting when I get my new rear bumper.
  13. Apr 3, 2014 at 4:29 PM
    #4133
    BabyTaco
    Wyoming
    2011 RC Tacoma
    For sure. About to take a trip to the pressure washer and get all the mud and road grime out of my way. Then I am going to murder the cab mount and play with the sledge hammer some :).
  14. Apr 3, 2014 at 4:31 PM
    #4134
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Lol, enjoy! Sounds like a beer drinking session with the sledge... Don't get too carried away haha
  15. Apr 3, 2014 at 11:35 PM
    #4135
    BabyTaco
    Wyoming
    2011 RC Tacoma
    To bad you cut the shit out of it :).
    Got one side done! Just gotta cut the other side and bash the firewall some and go pick up the goodies :D. Felt a little weird bashing in the firewall and pretty sure I cracked it so now I need to get some RTV for safety measures and seal everything back up.
  16. Apr 4, 2014 at 4:04 AM
    #4136
    toyodajeff
    jeff
    06 reg cab sr5
    He could always lower it and still fit 22s
  17. Apr 4, 2014 at 5:16 AM
    #4137
    lennyk
    lennyk Well-Known Member
    Mountain Top, PA
    Magnetic Gray Metallic
    Mag Gray Metal 2014 from PA - Here
    just mounted 05-11 Silver Side Steps
  18. Apr 4, 2014 at 6:52 AM
    #4138
    669sprink
    669sprink Crazy Cracker
    Bobby
    San Diego
    08 pre runner tacoma
    1.5" Wheel spacers all around, 2.0 fox coil over with foxes in the back to match it up, add a leaf. 285/70/r16 general grabbers. my magnaflow exhaust k&n intake just threw in some maxtrac spindles. Total chaos UPA. Bunch of other little things
    I Learned how to use it in my scion super fun, in my lifted taco, fuuuuuck no super sketchy hahahahahha still really fun though in sand when frodin :cool:
  19. Apr 4, 2014 at 10:47 AM
    #4139
    BabyTaco
    Wyoming
    2011 RC Tacoma
    :rofl:...hatch.
  20. Apr 4, 2014 at 11:12 AM
    #4140
    toyodajeff
    jeff
    06 reg cab sr5
    Why not build some tube doors instead.
