The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Sep 24, 2014 at 1:32 PM
    #5561
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I think hes 4x4 and doesnt have a dust cap, the sliding thing is made into the shaft not the end.
    I have heard you can flip you drive shaft on a 4x4 and the noise will stop.
    I have blocks made with an angle and offset center pins to get mine back in spec.
  2. Sep 24, 2014 at 2:02 PM
    #5562
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    From what I've read on here, which is a decent amount because I researched this topic a lot before getting my lift, the extra height in the back is what causes the vibes. Toytec used to offer a 1.5' AAL with their lift kits now they only offer a 2 inch one or a 1.5 inch block. On my old truck I had a 2 inch block at first, got vibes, then went to a 1.5 inch AAL and had no more vibes. I actually preferred the ride quality with blocks but thats another conversation... maybe if you could find a smaller AAL or a 1.5 block it would help. That's kind of an expensive gamble to not know for sure though :notsure:
  3. Sep 24, 2014 at 7:19 PM
    #5563
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    What did you do exactly? I am having the same problem as fasttoyo is with the grinding noise.
  4. Sep 24, 2014 at 8:57 PM
    #5564
    toyodajeff
    jeff
    06 reg cab sr5
    Had vibes though from 3 inch add a leaf and 3 inch blocks. The blocks I had made were tapered and had offset centerpins to move the axle forward about an inch. Got rid of vibes, still makes noise.
  5. Sep 24, 2014 at 8:58 PM
    #5565
    toyodajeff
    jeff
    06 reg cab sr5
    Ive heard on the 4x4 models you can flip the driveshaft over since it bolts in on both sides and that will make the grinding noise go away. It is also free, zip, zero, nilch, nada
  6. Sep 25, 2014 at 2:55 PM
    #5566
    nickonfire700
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    I have no vibes, but just that grinding noise. I was planning on doing the driveshaft flip, but it seems to work for only a few thousand miles, or not at all. Thanks for getting back :thumbsup:.
    Also, BabyTaco, I finally installed my IronMan lift. It rides so much better with the lift kit than with the old worn out springs! :woot:
  7. Sep 25, 2014 at 4:00 PM
    #5567
    fasttoyo
    fasttoyo Well-Known Member
    Going to try out the flip, I'll report back.
  8. Sep 25, 2014 at 5:27 PM
    #5568
    toyodajeff
    jeff
    06 reg cab sr5
    Regular blocks move the axle down and away from it. These just move it closer to where it would be with just the addaleaf and also helps with the angles.
    I have about a 6 inch or so lift by the way.
  9. Sep 25, 2014 at 6:11 PM
    #5569
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Just got my ARE V-Series installed a few days ago. Looks way better than I thought it was going to. Looking to add a Surco Safari Basket to the factory-installed rails at some point.
    Fink
  10. Sep 25, 2014 at 8:12 PM
    #5570
    GEORGE STRAIT
    Da Magic City, AL
    Damn fink. That looks amazing. I've been thinking about trading my wheels for those
  11. Sep 25, 2014 at 8:19 PM
    #5571
    Fink
    Orlando, FL
    Thanks man! Ya know...I didn't expect them to look anything like this. They are like a charcoal gray almost. I didn't know that.
    I have to say, I didn't even intend for the truck to take shape like this. My wheels/tires were stolen a few months back so I ended up with these wheels over the stock steelies and then I had to get this cap for work stuff. Just randomly pieced together.
    I think your truck looks awesome the way it is! I wish I had gotten a cap sooner - I had no idea how awesome it was.
    Fink
  12. Sep 25, 2014 at 9:21 PM
    #5572
    bzzr2
    bzzr2 Well-Known Member
    for those getting the grinding driveshaft after lift this is a well known issue with these trucks. flipping it will maybe temporarily resolve your issue but i promise it will eventually come back. been there myself. you can do a few things;
    -live with it, but yes i know it's very annoying
    -if under warranty your dealer should replace (mine did), but the problem will likely come back anyway
    -grease the crap out of the slip yoke and this will keep it quiet for a while then repeat, pain in ass to take apart all the time though
    -somebody on here at one time installed a grease zerk if i recall correctly...
    -get a tom woods driveshaft and have a permanent fix
  13. Sep 27, 2014 at 6:30 AM
    #5573
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
  14. Sep 27, 2014 at 6:31 AM
    #5574
    Fink
    Orlando, FL
    :eek:
    Everybody ok?
    Fink
  15. Sep 27, 2014 at 6:32 AM
    #5575
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Yup, just me in the truck. Dodged a deer, found the trees :eek:
  16. Sep 27, 2014 at 6:33 AM
    #5576
    Fink
    Orlando, FL
    Geez dude. I'm sorry that happened but glad you're ok - clearly could have been worse!
    Fink
  17. Sep 27, 2014 at 8:40 AM
    #5577
    GEORGE STRAIT
    Da Magic City, AL
    It'll buff out
  18. Sep 27, 2014 at 10:17 AM
    #5578
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Lol, I'll keep ya posted ;)
  19. Sep 27, 2014 at 3:20 PM
    #5579
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    Damn that sucks your truck was looking pretty nice. Glad your ok
  20. Sep 27, 2014 at 3:29 PM
    #5580
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    So I guess the kick out didn't work?
