The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jul 8, 2012 at 7:51 PM
    #541
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Did that, didn slide right. Why I suggest not going that route.
  2. Jul 8, 2012 at 7:56 PM
    #542
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You sure about that? Mounts, latches, trim are all the same? just because one spot is the same doesn mean they all are. and was this interior dimensions or exterior?
    If that's the case you might already have a loom at both rocker panels. Random vehicles will have random harnesses. I.E. cruise on yota's some a pre wired and are plug and play while others need a wire or two ran from the main harness. But yes all you would need is main power on, ground, and turn on signal.
  3. Jul 8, 2012 at 8:03 PM
    #543
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Huh. Learn something new every day.
  4. Jul 8, 2012 at 8:09 PM
    #544
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ha your welcome
    Your not just talking fab here, your talking full body work. Lets say worst case door fits but mounts are all out of wak. You would have to remount and weld in threaded tabs from inside the A panel rocker area, you would also have to do the same for the door hinges and the same for the B pillar for the door latch which I dont even know if you could get in there to weld that without cutting out that section doing it then resectioning it which always leads to misalignments, air gaps, and a pain in the ass.
    I see where you are going with this, I too tried to go this route and to convert it to for power locks and windows, cost just doesn outweight the amount of work. Oooo and paint, lots of paint to match all welded area's and for those small area's you would still have to buy quite a bit of paint.
    Now I am pretty positive that the electric door locks will work and those you could wire up to a aftermarket popper or full alarm. The only reason that I am not 100% is because I looked this info up some 4 years ago when I first bought my taco.
  5. Jul 8, 2012 at 8:13 PM
    #545
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Im not trying to be mean bro, just trying to give you all the info on what it will take if that shit doesn line up. Worst is what I pointed out, at least with the door not even fitting your hopes dont get up. BTW you ever try lining up a door on a car before, not a simple task.
  6. Jul 8, 2012 at 8:19 PM
    #546
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    It's not even simple to line up the factory door after you remove it and try to reinstall it.
    Trying to line up the door from a different truck? Get it close, then spend a half day on the fenders to complete the job.
  7. Jul 8, 2012 at 8:22 PM
    #547
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Exactly, your looking at a lot of down time and a hell of lot of work just for power windows and locks. I wanted them as much as you do, even had a thread over on CT years back but gave up cuz it just aint worth it. Hence why Im in search of a different taco.
  8. Jul 9, 2012 at 5:31 PM
    #548
    shumate1819
    shumate1819 Member
    Thomaston GA
    Tacoma Regular Cab 4x4
    Bone Stock for now
    My 2012 Tacoma 4x4 Base MT, My first Taco. Already tinted the windows 5% and replaced the absolutely horrible factory speakers with JBLS. Im wanting to get a nicer wheels like a set of SR5 or TRD takeoffs with some all terrain tires. im ready for a dash kit to put in a head unit. I love my Tacoma but the power is taking a little to get used to. I traded an 04 F150 lariat 4x4 for it. Its definately a work in progress but i only had it 3 weeks. And does anybody know where the best place to get my hands on a black brush guard. Thanks
  9. Jul 9, 2012 at 6:28 PM
    #549
    Rich91710
    Rich
    Los Angeles
    08 Base
    Even the fucking FLOOR MATS!
    Bought a set from Titus-Will.
    They sent me a set from an AC (or maybe a DC, hard to tell from the size of the rear mats).
    Driver's side, one hook lines up. Passenger side, neither hook lines up.
  10. Jul 9, 2012 at 6:44 PM
    #550
    Phil Dammit
    Your Mom
    Tempe, Arizona
    ^TRUTH
    I told you Ry would back me up on Randy, dudes a fuckin genious over there. Wish he was over here sometimes. He's an oldtimer too. BTW way to go, takes talent to piss off Ry Ry.:cool:
    Aint that about a bitch....
  11. Jul 9, 2012 at 7:05 PM
    #551
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yet he is back, because he's Tdubs baller status.
  12. Jul 9, 2012 at 7:08 PM
    #552
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Your so hard bro, do you and Kody chill together? What steps should I take to be a interwebz gangsta?
  13. Jul 9, 2012 at 7:11 PM
    #553
    Phil Dammit
    Your Mom
    Tempe, Arizona
    just callin it like I see it, no angers bro man dude.
  14. Jul 9, 2012 at 7:12 PM
    #554
    Rich91710
    Rich
    Los Angeles
    08 Base
    This thread is going to be a few pages shorter after the mods finish cleaning it up.
    Get a fucking room kids.
  15. Jul 9, 2012 at 7:17 PM
    #555
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Awe, killin my fun Rich. Ok I'll back off the 12teen yearold.
  16. Jul 9, 2012 at 7:20 PM
    #556
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well when your done under my desk you can go back to regaining some of that and trying to swap doors that wont fit
  17. Jul 9, 2012 at 7:28 PM
    #557
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Bro, its not gay to get your dick sucked. No need to call no homo there. But back to topic.
    Anyone here having roof paint issues on their regular cab?
  18. Jul 9, 2012 at 7:34 PM
    #558
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
  19. Jul 9, 2012 at 8:07 PM
    #559
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Knock it off
    All of you
    And randy knows his shit...
  20. Jul 10, 2012 at 12:16 AM
    #560
    ortlie09
    ortlie09 Well-Known Member
    Eric
    Sacramento
    11 Reg Cab 4x4
    Debadged, took off front mud flaps, prevent tailgate theft mod, Magnaflow 18" muffler, Bilstein 5100s front and rear w/ front @1.75, wet okoles, plasi dipped front emblem, weathertechs, scangauge, toolbox, Bed pocket lights, BHLM, T1 eyelids, BAMF sliders, Bruteforce Fab rear bumper
    Unsubscribed due to dumbass arguements
