The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jul 10, 2012 at 9:05 AM
    #561
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It is if it isn't a woman that started out life as a woman doing the sucking..........:D
  2. Jul 10, 2012 at 1:09 PM
    #562
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    2010 and earlier, Regular cabs were available with SR5 option package.
    You could locate complete doors or door parts from one of those.
  3. Jul 10, 2012 at 5:31 PM
    #563
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    LOL
  4. Jul 10, 2012 at 8:53 PM
    #564
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    From the July/ Aug. edition of 4WD Toyota Owners magazine..
  5. Jul 12, 2012 at 6:49 PM
    #565
    SoCalGhost2
    SoCalGhost2 Well-Known Member
    San Diego, CA
    04 Prerunner White 4x2
    Total Chaos UCA's Fox 2.0 Coil-overs, All-Pro Off Road Rear Suspension Leaf Springs, Bilstien 5100's, All-Pro Off Road Front Winch Bumper and Rock Sliders, Hella lights, KC lights, Kenwood speakers, kicker amp and 10' polk audio sub with custom fit box, A.R.E. Shell and Carpet Kit, Fog light mod, K&N Cold Air Intake, Flowmaster Super 44.
    Here is my soon to be mid travel taco :)
    [​IMG][​IMG]
  6. Jul 13, 2012 at 11:26 AM
    #566
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    can anybody here estimate the loss in mpg by puttin on 5100s at 1.75 and doing an AAL?
  7. Jul 13, 2012 at 11:53 AM
    #567
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Less than one mpg probably. Going higher hurts a little, especially on the highway, but it's going to be what wheels and tires you choose that make or break you. Tread pattern and weight are just as important to consider as size, but sometimes overlooked
  8. Jul 13, 2012 at 4:33 PM
    #568
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup...
    Bit of an increase in wind resistance, but it's not majorly significant... I'd call it maybe 5-10% at worst (and don't freak, 10% is only around 2mpg)
  9. Jul 13, 2012 at 5:03 PM
    #569
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well I will say that my 2tr-fe has no carbon build up on it but I get somewhere around 16-18 mpgs with 4" of lift up front and 1.5-2 in the rear with 265/75/16 Duratracs on a 5spd.
  10. Jul 13, 2012 at 5:34 PM
    #570
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What do you get to a tank? I get 340ish to a tank, with a 5 lug..... that's why Im trying to figure out how all you fools are getting 20+.......
  11. Jul 13, 2012 at 5:45 PM
    #571
    Rich91710
    Rich
    Los Angeles
    08 Base
    http://www.fuelly.com/driver/rich91710/tacoma
    Dunno what I'm doing right....
    I don't generally drive like grandma, but I'm also not pulling jackrabbit starts and I watch traffic ahead and ease off so I'm not powering into a mess.
    At the same time, I don't have a problem putting the hammer down and punching it up to 90+ to hop around some idiot pulling the hypermiling bullshit and backing up traffic 2 miles behind him.
    It's fun to watch the Ultragauge.
    Morning commute average MPG for the tank will creep up to 26-27.
    Heavy traffic on the way home and it might be 23 when I pull into the driveway, might be 25... depends on traffic.
    Got this sweet shot a couple of weeks ago... then traffic home the next day blew it totally and it ended up being one of my worst tanks.
  12. Jul 13, 2012 at 5:48 PM
    #572
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Rich what are you getting to a tank? Somwhere in the mid to high 400's?
  13. Jul 13, 2012 at 5:55 PM
    #573
    Rich91710
    Rich
    Los Angeles
    08 Base
    I normally get gas at around 350-360, but I don't run it until the light comes on. My line of work, I can't go to bed without enough gas to get to work and back (45 miles each way), so I need to keep a 90 mile reserve.
    Average according to Fuelly is 24.5mpg, which translates to around 450 if I ride the needle to the E with the light on, but if I were to push it past "E" I could potentially get 500... problem is, if I am on a "bad" tank and only getting 23, then I'd be putting in 20 gallons at 460 miles.
  14. Jul 13, 2012 at 5:55 PM
    #574
    tango59
    tango59 Well-Known Member
    Memphis, TN
    07 Base 4X4
    My 07 5 spd. bought it last week.
  15. Jul 13, 2012 at 5:57 PM
    #575
    Phil Dammit
    Your Mom
    Tempe, Arizona
    At stock I was getting 460-80 per 19 gallons... not since the lift, tires, and wheels. Nothing changed with the highflow cat or exhaust.
  16. Jul 13, 2012 at 6:03 PM
    #576
    Rich91710
    Rich
    Los Angeles
    08 Base
    Have you confirmed your odometer error with the tires/wheels?
    If you've got a 5-lug and went to 31's, you're looking at an error of around 14%
    Two problems....
    Your speedo will be 14% slow, so 65 indicated is closer to 75. Wind resistance is an MPG killer.
    Your odometer will be 14% "slow", so an indicated 100 miles is actually 114... that means that if you get "300 miles" to a tank, you actually traveled 342 miles.
    You took 18 gallons? 300 miles was 16.7mpg. 342 miles was 19mpg
  17. Jul 13, 2012 at 6:22 PM
    #577
    Phil Dammit
    Your Mom
    Tempe, Arizona
    5 to maybe 7%. Speedo reads 65 but I do 71. And that is also dependent on the area's that I travel being that speedo inaccuracy changes as speed increases. Mathematical equations of circles blah blah blah. So yeah maybe 19 mpg's if accounting for inaccuracy but still aint no where near the 20+ everyone else reads.....
  18. Jul 13, 2012 at 6:39 PM
    #578
    Rich91710
    Rich
    Los Angeles
    08 Base
    Speedo inaccuracy increases with speed, but the percentage remains the same.
    But even if you recalibrated, the larger tires will impact MPG due to the change in the final drive ratio.
    You'd theoretically get smokin' mileage at a steady 65mph, but the problem is, it's like watching my Ultragauge on the way to Vegas....
    Leave home it's at 26.5
    Climb the first hill it's 22.9
    Down the back side and it's 26.3... and so on. You never gain back on the downhill what you lost on the uphill.
  19. Jul 13, 2012 at 6:42 PM
    #579
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Exactly but whitney looks way mo betta and goes deeper with the lift and tires. And soon I will have Ry Ry's old front end so I will have 10" of travel rather then lift! WIN!:D
  20. Jul 13, 2012 at 6:50 PM
    #580
    Rich91710
    Rich
    Los Angeles
    08 Base
    Oh absolutely...
    But like they say, ya wanna play, ya gotta pay ;)
    Just go full bore extreme and get an RC Base for a DD... then you still have a pickup and can go full LT on your rear without having to worry about the lack of a bed.
    Or get a Corolla for a DD and rent a UHaul for $30 when you need a pickup.
    Bonus: Owning the Corolla reduces the "Oh, Phil has a pickup, he'll help me move!"
