The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jul 14, 2012 at 4:37 PM
    #601
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    just use some PVC pipe then paint it with bed liner. I doubt its expensive at home depot. hahaha
  2. Jul 14, 2012 at 4:38 PM
    #602
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not only that... there's not even an OTC snorkel available for the 2nd Gen. What you see done are 1st Gen (or FJ?) mods.
  3. Jul 14, 2012 at 4:58 PM
    #603
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I know you can do the MT setup with out the fiberglass so that might be the route you wanna do, just be sure the tires you go with won't be rubbing on the fender wells under full compression
  4. Jul 14, 2012 at 5:02 PM
    #604
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    Truck looks good man hoping to get mine there within the next couple of months. Are those the factory leafs you have on? Or replacement stock leads? I have my stock leads and am thinking of replacing them cause they are shot and are making more of a wavy "W" the an arch but im wondering if the 3 leaf progressive pack with be good enough. Are you tires the authority a/t's? sorry for all the questions and talk it's rare for me to see another 95-97 reg cab and when I do I tend to ask shit tons of questions.
  5. Jul 14, 2012 at 5:34 PM
    #605
    Mexicant
    Mexicant Well-Known Member
    B
    Crawlerado
    Braap
    Yeah they're the factory leafs. I was wondering if the 3 leaf would be enough too, but it seems to do the trick for now. The wildernest shell weighs about 300lbs so the stockers were sagging with it installed. Tires are the walmart authority's, only put about 10k miles on them but they've been great so far.
  6. Jul 14, 2012 at 6:15 PM
    #606
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    I don't have a shell in the back to maybe that will do for the time being till I replace my leafs with aftermarket stock ones. My brother has those on his 2nd gen a lot of people think they aren't great cause they are Walmart tires but they have held their own when we've gone wheelin also a great tire in my opinion.
  7. Jul 14, 2012 at 8:11 PM
    #607
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    You talking about the black plastic pieces ? It's been done but it will expose a bunch of mounting holes.
  8. Jul 14, 2012 at 8:59 PM
    #608
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I'd leave the body as is. it looks real good to me
  9. Jul 15, 2012 at 8:53 AM
    #609
    Lebtucky
    Lebtucky New Member
    2012 4x4 2.7L
    New Truck ... 224 miles so far ... really enjoying it!
    Chris2009 likes this.
  10. Jul 15, 2012 at 9:04 AM
    #610
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    trip up to monatque for lunch then for flat rock for some water cross dusty as hell up there yesturday. testing out the new billies which i used to try to avoid bumps now i look for every bump in the road to hit rides so nice
  11. Jul 15, 2012 at 10:13 AM
    #611
    OldDog
    OldDog Well-Known Member
    w.mass
    2010 reg cab 4X4
    I like that color
  12. Jul 15, 2012 at 11:53 AM
    #612
    Rich91710
    Rich
    Los Angeles
    08 Base
    Love the old Ivan Stewart rims.
    Wish they made them in 5 lug!
  13. Jul 15, 2012 at 12:10 PM
    #613
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Only problem with manual locks was dropping the transfer in 4low then realizing after being buried halfway in a pit that "OOO shit did I lock the hubs?". Did that one too many times with my 90 6lug pretaco. Only down side to manual hubs....
  14. Jul 15, 2012 at 3:49 PM
    #614
    Phil Dammit
    Your Mom
    Tempe, Arizona
    ADD bro, I forget shit on the daily.
  15. Jul 15, 2012 at 6:32 PM
    #615
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Good color. And the dealer wheel/tire upgrades look good too. :thumbsup:
  16. Jul 16, 2012 at 4:45 AM
    #616
    Lebtucky
    Lebtucky New Member
    2012 4x4 2.7L
    I've been thinking about having the Ivan Stewart's powder coated satin black. Pyrite looks good with blacks ....
  17. Jul 16, 2012 at 10:08 AM
    #617
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Maybe. But if you keep 'em clean - those wheels are a good look as is.
  18. Jul 16, 2012 at 5:15 PM
    #618
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ditto.
    MAYBE PC the spokes in gunmetal or satin black, but the rim and center cap need to remain aluminum.
  19. Jul 16, 2012 at 9:14 PM
    #619
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  20. Jul 16, 2012 at 9:18 PM
    #620
    Rich91710
    Rich
    Los Angeles
    08 Base
    By themselves? Not much.
    But we all know we want them :D
