The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. May 6, 2015 at 8:03 AM
    #6801
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Thing is, I think my truck is worth between 19-20k. If I am gonna drop 5 grand on a super charger I might as well just trade my truck for a 24k v8 truck
  2. May 6, 2015 at 8:09 AM
    #6802
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Its a shame LCE doesn't offer a built drop in engine. Like a stroker 2.7 bored out to a 3.0 or something. Even if it cost $8-10k I think it'd be more cost effective and reliable than the $5k turbo kit
  3. May 6, 2015 at 8:23 AM
    #6803
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    Meh, I went through that though process as well. Not worth it for me. Trucks paid off and I would only get the SC if I had the money. No reason to get a big heavy gas guzzlin v8.
  4. May 6, 2015 at 10:07 AM
    #6804
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    i think most of us have 2.7 single cabs because of the price, not the size. that would be an even harder for urd to sell than the supercharger since its more than just a bolt on upgrade.
    but it would be awesome if they made that. you should pull your motor out and put some high compression pistons and big cams in it.
  5. May 6, 2015 at 10:13 AM
    #6805
    weldertaco
    texas
    TrailRunner
    I tried buying cams a month ago but nobody makes any...
  6. May 6, 2015 at 10:34 AM
    #6806
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I have my truck because it fit all my needs. I could have paid cash for an access cab with all the bells and whistles but that would be retarded. There was no need to get a 35-50k truck that guzzles gas, can go "fast", and haul unrealistic loads for the average person. I know I am in the minority when it comes to not buying more than you need but I think it is retarded to be in debt on a vehicle you don't even properly use. Same thing goes for houses. People build a house more than big enough for 5 people but only need it big enough for 3 or 4.
  7. May 6, 2015 at 10:43 AM
    #6807
    toyodajeff
    jeff
    06 reg cab sr5
    you can get cams custom made but i think you need to give them cores to use.
    just adding a bigger cam and doing nothing else would probably kill you low end. normally a bigger cam will raise the rpm where you hit peak torque and maybe even bump up youir max torque. but if you do something like raise your compression or stroke and add big cams youll keep your low end and still have top end.
    or just raise compression and stroke have a lot of low end.
  8. May 6, 2015 at 10:44 AM
    #6808
    toyodajeff
    jeff
    06 reg cab sr5
    most stock cams are ideal for low end torque. especially if the rest of the engine is stock.
    maybe going to a towing/camper cam grind would be good though.
  9. May 6, 2015 at 10:45 AM
    #6809
    toyodajeff
    jeff
    06 reg cab sr5
    i bought my truck because i wanted a tacoma but i was broke.
    Maineiack likes this.
  10. May 6, 2015 at 10:54 AM
    #6810
    weldertaco
    texas
    TrailRunner
    I wanted more mid range torque so when I do need more skinny pedal on the trail, it would have the power.
  11. May 6, 2015 at 11:04 AM
    #6811
    toyodajeff
    jeff
    06 reg cab sr5
    a bigger cam would help then.
  12. May 6, 2015 at 11:05 AM
    #6812
    toyodajeff
    jeff
    06 reg cab sr5
    maybe somebody should try to rig up an intake off a 2.7 venza and see if itll work on the tacoma. we have alotta space under the hood.
  13. May 11, 2015 at 11:37 AM
    #6813
    MRMOTO
    MRMOTO Well-Known Member
    Tucson, AZ
    ‘22 Lunar Rock Trail Edition
    Anybody know what I should be telling the alignment tech to shoot for for my reg cab with 884 springs, OME front and rear struts, dakar leaf pack, and 265.75.16 tires on pro comp wheels? I had an alignment done right after the lift, but on the highway I'm having to steer at a angle to the right just to keep it from pulling pretty hard to the left. Any help would be great!
  14. May 11, 2015 at 12:06 PM
    #6814
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Tell him to shoot for 0 toe, 0 camber and as much caster (positive) as he can get. Stock upper control arms? If so, you won't get more than 1.0-1.5.
  15. May 11, 2015 at 3:33 PM
    #6815
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Pics?
  16. May 12, 2015 at 7:16 PM
    #6816
    NmBeefTaco
    NmBeefTaco Well-Known Member
    Greg
    New Mexico
    18 TRD Off Road Access Cab
    Toytec Boss lift, AAL, Ride rite air bags, Daystar cradles, Total Chaos UCA, Icon 17 inch Rebounds, 285/70R17 BFG KO2s, Ruff country 30” LED light bar kit, ruff country tri fold bed cover. Interior LED lighting and lic./reverse LED lights.
    Line-X
    vrod671 likes this.
  17. May 12, 2015 at 8:27 PM
    #6817
    MRMOTO
    Tucson, AZ
    I'm going to try and get them tomorrow if I can get the Tepui tent on. Got my Allpro bedrack welded up and then I painted it today with bed liner and got it on. It's coming together…
  18. May 13, 2015 at 5:27 PM
    #6818
    MRMOTO
    Tucson, AZ
  19. May 13, 2015 at 5:32 PM
    #6819
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Truck looks great man!
  20. May 13, 2015 at 6:04 PM
    #6820
    MRMOTO
    Tucson, AZ
    Thanks man! I'm pretty happy with how it has turned out. I want to add an awning, and will probably go ARB since they are cheaper, and then just some other random stuff, but for the big stuff I think I'm done. For now at least haha.
