The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Aug 5, 2015 at 6:31 PM
    #7001
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    Lower it or upgrade drive shaft... I am going to eventually do the latter.
  2. Aug 16, 2015 at 8:51 AM
    #7002
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    looking to buy an a trailer hitch, which one do you guys recommend?
  3. Aug 16, 2015 at 9:01 AM
    #7003
    lagsalot2k
    lagsalot2k Well-Known Member
    Port Angeles, WA
    2013 RC 4x4
    If money isn't an issue or your willing to wait for one to pop up, the factory hitch is great. Built like a tank and hides quite well under the bumper
  4. Aug 16, 2015 at 5:21 PM
    #7004
    FSUtaco
    FSUtaco Well-Known Member
    Cody
    13 Reg Cab 4x4
    Eibachs, 5100s, 7089s and 265s
    Dalandser likes this.
  5. Aug 16, 2015 at 7:02 PM
    #7005
    tacoburrito
    boston
    2013 regular cab
    right on fsu! have you gone 285s yet? truck looks good!
  6. Aug 16, 2015 at 7:02 PM
    #7006
    tacoburrito
    boston
    2013 regular cab
    also what wiring harness did you buy?
  7. Aug 16, 2015 at 7:04 PM
    #7007
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    Willbeck and technolust like this.
  8. Aug 16, 2015 at 7:11 PM
    #7008
    tacoburrito
    boston
    2013 regular cab
  9. Aug 16, 2015 at 7:56 PM
    #7009
    FSUtaco
    Cody
    13 Reg Cab 4x4
    https://www.etrailer.com/p-118496.html
    Haven't moved up to 285s. Still have quite a bit of tread left on the 265s so it won't be happening for a while either.
  10. Aug 17, 2015 at 5:26 AM
    #7010
    cbrboy
    cbrboy Well-Known Member
    Bill
    Virginia
    2000 single cab 2.7 sas
    Here is my 2000.
    DesertDigger, 671taco and Yotabilly like this.
  11. Aug 17, 2015 at 5:36 AM
    #7011
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Damn thats high
  12. Aug 17, 2015 at 5:43 AM
    #7012
    cbrboy
    Bill
    Virginia
    Figured I'd be getting that response lol.yeah it's high as hell.the guy I bought it off of never used the truck so the springs are still stiff.I plan on removing the 5" springs and installing 3"springs soon as I can afford it.
  13. Aug 17, 2015 at 5:46 AM
    #7013
    toypower
    toypower Well-Known Member
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Sas swap, dana 44 high pinion front, Corporate 14 bolt locked, disc brake conversion. 8 inch superlift springs on 39.5 iroks, 5:38 front and rear. Hydraulic assist, 3 inch body lift, Yukon axles front/rear, bilstein shocks, CAI, rock ripper header.
    image.jpg Here's my 1998
  14. Aug 17, 2015 at 9:55 AM
    #7014
    toypower
    corey
    Niceville FL
    98 Reg Cab Tacoma
    I'm runnin a cai, header, and a throttle body spacer. I can tell a little difference, but not drastic. IMO I think that cai is better than factory regardless, but it's personal preference. I'd recommend doing it.
  15. Aug 23, 2015 at 10:04 PM
    #7015
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Back when I was lowered , I ran about 20 times at the drag strip with a K&N CAI and 20 times with a stock intake. 1/4mile times were faster with the stock intake by like .5 second consistently for what its worth.
  16. Aug 23, 2015 at 11:27 PM
    #7016
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    I have a k&n intake...nothing noticeable. I like the sound tho.
  17. Aug 25, 2015 at 12:32 PM
    #7017
    weldertaco
    texas
    TrailRunner
    The cold air intakes do give the truck a nice deeper growl. Its worth it to some. The power difference isn't really noticeable to the butt dyno.
    And no. The airbags won't work just plug and play. You're gonna have to do what that Ryan guy did (there's a write up on here somewhere ) and do some wiring work to get the airbags to work. Or just run without air bags.
  18. Aug 25, 2015 at 12:39 PM
    #7018
    weldertaco
    texas
    TrailRunner
    I'm unfamiliar with seats in access cabs so idk about that. I know (at least I think lol!) That the access cabs come prewired for fogs so you should have the little plug behind one of the blanks on the dash. To the left of the steering wheel.
  19. Aug 25, 2015 at 2:08 PM
    #7019
    weldertaco
    texas
    TrailRunner
    I'm 4wd so I only had one option for drop kits. Which was the Tundra Racing kit.
  20. Aug 25, 2015 at 2:55 PM
    #7020
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I tried the K&N...heatsoak. I tried the Volant...didn't like the unsupported tube that didn't provide mounting for the things on oem like K&N tube did and oem of course - dunno, some vacum deal. aFe were pricier and didn't look much different & no one was selling one used. So I used the supported intake tube that had mountings for everything like oem did, used the Volant filter box that breathes from fender like oem, & ordered up an aFe dry flow filter to use on it and made a clear lid for the aFe filter box. I ended up with a KVA intake...............
    I tried the snorkel for the aFe box, OK, scoop or whatever. It did not help anything except faster dust and bug buildup in the filter box. And the foam donut to fill in between the tube and opening on box has been installed inside the box around the tube and blocks out hot engine bay air much better if not completely now. Other than that it has been fine. Looks better and I have a washable non-oiled filter and maybe more noise. Dunno about any more hp or mpg...if so it is so little I can't tell. But I like it and it is staying. Certainly hasn't hurt anything.
