The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jan 28, 2016 at 10:36 AM
    #7641
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    So having the wrong pinion angle is OK then?
  2. Jan 28, 2016 at 10:52 AM
    #7642
    CHarrison32
    CHarrison32 Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
    From what I've read up on the axle shims their purpose is to reduce or get rid of vibes I'm not experiencing any vibes at all just a roaring sound. But who am I to say anything against them I've never tried I just want something reliable
  3. Jan 28, 2016 at 11:32 AM
    #7643
    beanulous128
    beanulous128 Well-Known Member
    zach
    Yellville
    2012 TRD Sport DCSB
    where did you get those light mounts? or are they custom
  4. Jan 28, 2016 at 12:12 PM
    #7644
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Look at cbi off-road , they are called ditch lights
    beanulous128[QUOTED] likes this.
  5. Jan 28, 2016 at 12:23 PM
    #7645
    beanulous128
    zach
    Yellville
    2012 TRD Sport DCSB
  6. Jan 28, 2016 at 5:16 PM
    #7646
    Bennoclarke
    Bennoclarke Well-Known Member
    Ben
    Stockbridge, GA
    2007 Tacoma 2.7 Regular Cab
    I actually posted my old switch here for sale. What a stupid waste of time
  7. Jan 28, 2016 at 5:28 PM
    #7647
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    It's the rear drive shaft. Lift really screws with these reg cabs...anyway word on the street is a double cardan joint drive shaft is the fix, which requires the third member pinion pointing at the t-case output.[​IMG]
    Owall83 and CHarrison32[QUOTED] like this.
  8. Jan 29, 2016 at 11:53 AM
    #7648
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
  9. Jan 29, 2016 at 1:04 PM
    #7649
    weldertaco
    texas
    TrailRunner
    Well... broke the clock spring lol so no horn :( but the taco lives!
    vrod671 likes this.
  10. Jan 29, 2016 at 5:21 PM
    #7650
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    2tr-fe guts! Figured I would drop this in here since not may will ever need/get to see the innards.
    The two orange links in the chain line up with a mark on each sprocket. At the bottom of the engine is a yellow link that lines up with another mark. Cylinder 1 should be TDC. For those with the 2tr-fe, you can easily do this to check your timing. Use a cheap endoscope to check the yellow link at the bottom to avoid pulling the timing cover off. I haven't done that but seen videos of it being done on other vehicles and see no reason it wouldn't work for us.
    The bolt on the black sprocket is the evil bastard holding me up. Should find something to make it work in a few and complete the job tomorrow.
    Also, I will link the light I am using in the final write up for replacing valve seals. After fumbling with a different shop light I purchased it for round two . It hangs off the hood and makes things sooooo much easier.
    vrod671, CHarrison32, TRoss and 2 others like this.
  11. Jan 30, 2016 at 12:02 AM
    #7651
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Man, I normally get drunk in my own build thread but tonight I want to say GO REG CABS! There is a few of us. Even fewer that heavily mod our trucks. Gotta love that! I have learned a ton through TW and hope I can contribute a portion of what I have learned here. Seriously.
  12. Jan 30, 2016 at 12:08 AM
    #7652
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    are you able to re gear your difs and install lockers in both?
  13. Jan 30, 2016 at 1:37 AM
    #7653
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I regeared to 4.88's? If thats what you are asking? I opted for the arb air locker in to rear but the front is still open.
    mahaloTaco[QUOTED] likes this.
  14. Jan 30, 2016 at 6:51 AM
    #7654
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    There's a tsb for that.
  15. Jan 30, 2016 at 6:54 AM
    #7655
    weldertaco
    texas
    TrailRunner
    Yea but my warranty is beyond voided. This was my fault and was a known risk when i got the steering rack back in. The steering wheel was secured 'straight' before I pulled the old rack out but the rack mustve been so messed up from the accident that the wheel was 360 degrees off.
  16. Jan 30, 2016 at 7:05 AM
    #7656
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    Yep, I love my Reg Cab too! Wouldn't trade it for any vehicle that I know of. I guess mine's not "heavily modded" though. :D Just slightly modded with 5100's, OME 884s, LR UCAs, 285s, color-matched grill, black taillights, LCE header, AFE filter, custom badges, Wet Okoles, Weathertechs, and soon to have 4.88s and lockers. Just simple stuff.
    technolust, vrod671 and BabyTaco[OP] like this.
  17. Jan 30, 2016 at 7:06 AM
    #7657
    toyodajeff
    jeff
    06 reg cab sr5
    Sucks, I checked on getting mine fixed before the tsb happened it would cost a 200 at least for the part. I think Toyota calls it a clock spring or something.
    You like them maxxis tires don't you, how many miles did you get outta the last set?
  18. Jan 30, 2016 at 7:27 AM
    #7658
    weldertaco
    texas
    TrailRunner
    I usually get new tires once a year which is about 35k miles. When the tread gets around 20% is when I order new ones. I do love them simply because they are a really rigid tire, relatively light, and really quiet for a really aggressive tread.
  19. Jan 30, 2016 at 9:40 AM
    #7659
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    How do you like the air locker? How easy is the install? And how well does it work?
  20. Jan 30, 2016 at 6:41 PM
    #7660
    technolust
    technolust Erudite Polymath
    Zack
    Lehigh Valley, PA
    2016 Black Tacoma Off-Road
    315 Maxxis RAZR, SCS F5, Bilstein 8112, Dakar Leafs, Tepui Tent, Leitner Design Rack
    I am actually hammered too right now and I totally concur with your input! Gotta love Sat night date night lol
