The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Mar 24, 2016 at 5:06 PM
    #8161
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    I don't know why. I pulled them from the same fb page.
    :notsure:
  2. Mar 24, 2016 at 5:26 PM
    #8162
    northwoodsr
    northwoodsr Member
    Vermont
    2004 Tacoma SR5
    OME 881s 5100s
    5100s all around, 2 inch block rear on general grabber 265/75
  3. Mar 24, 2016 at 6:17 PM
    #8163
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    you can actually see a related video where he does a hill climb. truck looks mean! did he lose his front wheel fender?
  4. Mar 24, 2016 at 6:20 PM
    #8164
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Probably just removed it.
    tacoburrito likes this.
  5. Mar 24, 2016 at 6:21 PM
    #8165
    tacoburrito
    boston
    2013 regular cab
    haha nice. is he on tacomaworld?
  6. Mar 24, 2016 at 6:26 PM
    #8166
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    I don't think think so.
  7. Mar 25, 2016 at 8:12 PM
    #8167
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    Hey guys, been on here a while but not in this thread. I'm looking for a little help. I just did the urd fuel pump up grade, thoroughly cleaned the maf, cleaned the throttle body and still have the same issue. I can't maintain 70mph decently, have no throttle response when over 65mph and can't make a hill to save my life with out being at 45mph in 4th gear. Is anyone else having this issue? I'm heavily modified but I'm running 4.88 r/p with 33 inch wheels, I should be smoking tires and have lots of power but it's struggling bad. Any ideas? Thanks in advance
    vrod671 likes this.
  8. Mar 25, 2016 at 8:22 PM
    #8168
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    @Mothman, not to scare you, but if you have time take off your intake hose that connects to the throttle body. Make sure it isn't dirty.
    Mothman likes this.
  9. Mar 25, 2016 at 8:31 PM
    #8169
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Thanks for the heads up and I definitely will. Need to clean my tb and do spark plugs soon anyway
  10. Mar 25, 2016 at 8:54 PM
    #8170
    BabyTaco
    Wyoming
    2011 RC Tacoma
    We looked at my intake and its caked with dirt. This pretty much means it was bypassing the stock air filters too.
    Mothman likes this.
  11. Mar 26, 2016 at 6:22 PM
    #8171
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
  12. Mar 26, 2016 at 6:31 PM
    #8172
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Not sure what your problem is. 4.88's with 33's should be able to pull you through most things. What elevation are you at? I guess you could do a compression test on your engine and make sure everything is running top notch on the inside?
  13. Mar 26, 2016 at 7:16 PM
    #8173
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Agreed, I've kinda narrowed it to with o2 sensors or bad cats. Dropping the pipe from the header to see if it's better or worse
  14. Mar 27, 2016 at 5:57 PM
    #8174
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Don't drop the pipe from the header. It will run like complete dog shit. Trust me lol. I clogged my cats and muffler after sitting in a mud hole for 6 hours and the truck would barely run 60 in 3rd gear to the floor lol it was horrible.
    Took the downpipe off and was loud as fuck. But the truck would barely move. Our engines need the back pressure.
    I took it to a local muffler shop where they drilled a small hole in the cats to check them and turns out they were stuffed full of mud.
    More than likely sounds like your cats are bad and a muffler shop can check them for like $30 and then your truck is already there if you need to fix em.
    Just my .02!
  15. Mar 27, 2016 at 6:18 PM
    #8175
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Interesting, so with them clogged up it had massive power loss? We're your Rpms up high at 60?
    mahaloTaco likes this.
  16. Mar 27, 2016 at 6:24 PM
    #8176
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Did your truck fall under the cat recall from a few months ago?
  17. Mar 27, 2016 at 6:27 PM
    #8177
    Mothman
    Advance
    single cab
    Toyota will replace a cat on recall..
  18. Mar 27, 2016 at 6:28 PM
    #8178
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    I still need to drop mine off to be replaced.
  19. Mar 27, 2016 at 6:28 PM
    #8179
    Mothman
    Advance
    single cab
    Yeah I did mine. Didn't take long.
    vrod671[QUOTED] likes this.
  20. Mar 27, 2016 at 7:05 PM
    #8180
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    What were the qualifications?
