The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jun 9, 2016 at 7:22 PM
    #8681
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    how has your MPG been?
  2. Jun 9, 2016 at 7:44 PM
    #8682
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    I'm usually around 20, give or take a little
  3. Jun 9, 2016 at 8:34 PM
    #8683
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    That's actually not that bad.
  4. Jun 9, 2016 at 8:40 PM
    #8684
    Mothman
    Advance
    single cab
    Yeah, if I'm hauling heavy stuff or towing it goes down a little but not that much, lowest i remember calculating was like 16 or 17
  5. Jun 9, 2016 at 8:49 PM
    #8685
    bdbrown528
    bdbrown528 Well-Known Member
    Ben
    Anchorage, AK
    2023 TRD OR LR 6MT
    Any good recommendations for a 3in lift? I'm hoping to find a decent one under $500. Also what're some must haves for a standard cab?
  6. Jun 9, 2016 at 9:38 PM
    #8686
    stlntaco
    stlntaco Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    "Decent lift" and "under $500" don't go in the same sentence:D I say save up a little more and just do it right the first time. I bought a $250 dollar spacer lift and I hated it so much I spent around $3000 on suspension later. Now I'm stuck trying to sell a cheap lift.
  7. Jun 10, 2016 at 2:17 AM
    #8687
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    OFF TOPIC:
    Anybody's Regular Cab come pre wired with the 14 pin connector above the microphone in the ceiling?
    If I can find the wiring harness without tearing up my roof liner, I can wire a back up camera!
  8. Jun 10, 2016 at 3:17 AM
    #8688
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    From what I understand this is the case. I've read on here somewhere someone discovered it was there when they were installing a head unit. Much like my tailgate has the camera wiring, by no camera.
  9. Jun 10, 2016 at 7:17 AM
    #8689
    Toyko Joe
    Toyko Joe Here for the pictures
    I got a Recall Notice last night asking me if my Tacoma had TRD Wheels further recall information will come. Anyone else get one of these?
  10. Jun 10, 2016 at 10:02 AM
    #8690
    mahaloTaco
    Max
    Los Angeles
    So you heard it was behind the radio?
  11. Jun 10, 2016 at 10:44 AM
    #8691
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Well, let me back up. Do you see the little square piece of plastic in your ceiling? It'll be rather noticeable.
    mahaloTaco[QUOTED] likes this.
  12. Jun 10, 2016 at 11:21 AM
    #8692
    mahaloTaco
    Max
    Los Angeles
    Yes. The microphone.
    Awesome Picture Btw.
  13. Jun 10, 2016 at 11:24 AM
    #8693
    Hondah
    Newnan, Ga
    '13 RC 4x4
    In that case yes, it's back there some where. If my memory serves me correctly it runs down the passenger pillar into the dash. Where it's found after that, I dunno.
    And thanks!
  14. Jun 10, 2016 at 11:32 AM
    #8694
    mahaloTaco
    Max
    Los Angeles
    I appreciate the help!
    Did you wire a backup camera?
    Do you suggest I pull the headliner down and begin my quest or should I check out the A Pillar and behind the radio?
  15. Jun 10, 2016 at 11:40 AM
    #8695
    Hondah
    Newnan, Ga
    '13 RC 4x4
    I'd check that pillar first. Behind that dash would be pretty tough trying to figure out. But, at some point you'll have to figure it out where it ties into the harness.
  16. Jun 10, 2016 at 11:41 AM
    #8696
    Hondah
    Newnan, Ga
    '13 RC 4x4
    And I haven't wired up a camera yet. OEM ones are so expensive.
  17. Jun 10, 2016 at 11:48 AM
    #8697
    Toyko Joe
    Look into Rostra.com (also on Amazon.com) they have some clean kits for that OEM feel. I used them for my backup camera and love it!
    mahaloTaco likes this.
  18. Jun 10, 2016 at 11:51 AM
    #8698
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Are these the type that I've seen people make work? Or are they direct placement?
  19. Jun 10, 2016 at 11:55 AM
    #8699
    Toyko Joe
    Semi-direct placement. If your truck is not pre-wired direct placement wont ever work, mine required the harness but used OEM connectors. Very good instructions.
    P.S. I also used them for my cruise control.
  20. Jun 10, 2016 at 11:58 AM
    #8700
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    In case we drive off a cliff.
    TRoss[QUOTED] and mahaloTaco like this.
