The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Nov 5, 2016 at 7:56 PM
    #9281
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I know you didn't ask me, but I'll answer because I had the same set-up.
    In flat country, where I live, it wasn't too bad in town and not terrible on trips, but you can't be shy on the gas pedal. It was hard to maintain speed on any incline, like overpasses.
    4.88s solved it all and are fantastic with the 4cyl, auto trans, and 285s.
    stlntaco[QUOTED] and jeff b like this.
  2. Nov 5, 2016 at 8:06 PM
    #9282
    stlntaco
    stlntaco Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    I only have 12k on the truck:D I dont drive much either! Also.. when you say hard to maintain speed on inclines are we talking about 65 mph to 50 mph or are we talking 65 mph to 20mph! I notice that even with my 265s I have a hard time mainting speed on inclines...
    jeff b[QUOTED] likes this.
  3. Nov 5, 2016 at 8:09 PM
    #9283
    stlntaco
    Jake
    California
    My issue is that I want 295s, but if I did, I would regear, but since im in the axles i might as well put some sort of limited slip/ locker in as well. And if im doing that. Why not go with 305s!
  4. Nov 5, 2016 at 8:10 PM
    #9284
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    or 315's :spy:
  5. Nov 5, 2016 at 8:14 PM
    #9285
    stlntaco
    Jake
    California
    Exactly, and if I cut for 35s...why not cut for 37s. Then the 37s wouldn't do it for me and next thing you know I'm on solid axles with 40s. I dont care how well it would climb, it wouldnt be able to climb me out of the debt I would be in!
    Dalandser[QUOTED] likes this.
  6. Nov 5, 2016 at 8:16 PM
    #9286
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It could climb you into Mexico... where no one could ever find you again...
  7. Nov 5, 2016 at 8:18 PM
    #9287
    stlntaco
    Jake
    California
    That is true...but I have grown quite fond of clean clothes and running water...so I should probably just do my regear and axle work with the 295s!
  8. Nov 5, 2016 at 10:32 PM
    #9288
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    Same thing as this guy. Perfect combo man! Stick with the OEM filter. See my build thread for specific info
    Willbeck[QUOTED] and tacoburrito like this.
  9. Nov 5, 2016 at 10:46 PM
    #9289
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    ...First World problems. That said after three days camping in the desert without talking to anyone I was ready to go home and watch my favorite show on my computer lol - 295's it is. Planning on 4.56's?
  10. Nov 6, 2016 at 6:57 AM
    #9290
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    19k on mine...15k with 285s and 2k with 285s and 4.88s.
    stlntaco and jeff b like this.
  11. Nov 6, 2016 at 1:48 PM
    #9291
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    Got the goods. Do I really need a filter wrench or can I just use my hand to thread it
  12. Nov 6, 2016 at 2:58 PM
    #9292
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    only use a wrench to take filter off, never use one to put it on...don't want to risk punching a hole in the filter
  13. Nov 6, 2016 at 3:11 PM
    #9293
    tacoburrito
    boston
    2013 regular cab
    but will i be able to take it off by hand or will it be too snug to do so?
  14. Nov 6, 2016 at 3:21 PM
    #9294
    markm0311
    2000 Toyota RAV4
    On the 2.7 if you can't budge it by hand you can get channel locks up in there to get it started moving. Don't go out and buy a filter wrench
    tacoburrito likes this.
  15. Nov 6, 2016 at 3:26 PM
    #9295
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    whatever works, filter pliers are like $5. Works on any and all size filter (similar to channel locks as mentioned above).
    don't forget to fill your filter up with oil prior to install, always a nice precaution
    Ritchie and tacoburrito like this.
  16. Nov 6, 2016 at 3:29 PM
    #9296
    tacoburrito
    boston
    2013 regular cab
    thanks! I've got a few different sized channel locks so ill make something work. and yeah this will be my first time ever doing an oil change so any pointers are much appreciated.
    markm0311 likes this.
  17. Nov 6, 2016 at 4:19 PM
    #9297
    markm0311
    2000 Toyota RAV4
    I always grab a handful of those metal/felt (or whatever material they are) washers from the dealer to replace the old one on the drain plug. They give them to you for free at any toyota dealer.
    Mothman and 802coma like this.
  18. Nov 8, 2016 at 7:40 PM
    #9298
    stlntaco
    Jake
    California
    Rock lights....underglow...same thing, right?
    Dalandser and CHarrison32 like this.
  19. Nov 8, 2016 at 8:04 PM
    #9299
    stlntaco
    Jake
    California
    I used a led concepts grille light kit with 2 extra led strips. So it is 2, 24 inch led light strips in the grille and 2, 24 inch led light strips underneath the cab. I have their biggest controller that can run a TON of led strips. They also adjust to every color in the spectrum:bowdown:
  20. Nov 9, 2016 at 7:22 AM
    #9300
    CHarrison32
    CHarrison32 Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
    Do you have a shot of your truck from the side with the new bumper?
