The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Sep 27, 2012 at 7:15 PM
    #981
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Mine are fine.
    Wife's '04 Rav4 has a brand new one.
    But she pulls her's down multiple times daily to hold one of those windshield sunvisor things.
  2. Sep 27, 2012 at 7:17 PM
    #982
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i'm getting real worried about my stock clutch now... some days its perfectly fine, other days it lets out clear at the top, real jerky take offs etc... 92.5K on the truck, but i've owned it since 39K. i have no idea how the previous owner drove it. its ESPECIALLY bad when its raining out.
  3. Sep 27, 2012 at 7:31 PM
    #983
    bzwarts
    bzwarts Well-Known Member
    brad
    ontario
    01 tacoma trd 5 speed fully loaded w sunroof
    my truck does the grinding noise under the same circumstances. would love to know whatthat noise is as well any info is appreciated
    oh and its not the one in the profile pic, it is my fathers reg cab 07
  4. Sep 27, 2012 at 7:35 PM
    #984
    bzwarts
    brad
    ontario
    oh and does anyone else have trouble shifting into first while coasting? after changing the oil in it, it will NOT go into first. stick will break before going. he has to be completeley stopped to go into first.
  5. Sep 27, 2012 at 7:44 PM
    #985
    bzwarts
    brad
    ontario
    im talking to him and he says his will start to chug and go on (not enough torque )at 10 or 15mph in second gear and it wont let him down shift. i dont know why as i can get my 01 v6 down to like 5 to 10 no prob and still be able to pick up again
    oh and hes at 70,000
    miles
  6. Sep 27, 2012 at 7:57 PM
    #986
    bzwarts
    brad
    ontario
    thanks for the hlp. hes going to try giving it gas during the shift to get the syncronizers going a little faster. maybe that will help . thanks again and will throw results on here tomorrow.
  7. Sep 28, 2012 at 9:10 PM
    #987
    Rich91710
    Rich
    Los Angeles
    08 Base
    5w30 for me (2.7)
  8. Sep 28, 2012 at 9:15 PM
    #988
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hot weather in SoCal, would rather have the added protection of the heavier oil.
    The fuel savings between 20 and 30wt are minimal and only help Toyota to meet CAFE standards.
    If I lived in a colder climate, I'd be using a lighter oil to get better protection when the engine is cold, but when the coldest I ever start my truck is 50 degrees, Mobil-1 5w30 protects just fine.
  9. Sep 29, 2012 at 4:24 AM
    #989
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    It's my understand the first number only applies for winter time (hence the W after it). The second number is the warm weather rating. So, for SoCal, you should be the same with either one.
  10. Sep 29, 2012 at 6:25 AM
    #990
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    I wish I had some great success story from this morning after taking my truck in for the grinding noise, but all I came out of there 30 minutes later with was one about how they lost my business. I was screwed from the minute I walked in, the service advisor immediately was pissed that they scheduled me on a Saturday, and was critical of my complaint and the lift tires etc.
    He walked of to get a tech to ride with me, and I could tell right away that the tech was pretty much told that there wasn't an issue. The ride along was him hearing it but saying that the tire noise and wind noise were too loud and there wasn't anything unusual there. And I flat out asked him if it was worth my time to leave it there and he more or less said no.
    The weather didn't help me much either though, there was a cold snap and it was 39* this morning so it didn't get really warmed up an loud.
    Short story is they are essentially refusing to diagnose/fix the problem until I completely return my truck to stock, tires, suspension etc.
  11. Sep 29, 2012 at 7:23 AM
    #991
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    W stands for weight
    I agree with the tech I dont want to be chasing a noise when you have the added effect of tire noise and lift.
    I run 5w-30 synthetic down here in Phoenix. Have ran this since I bought the truck back in 07.
    Yeup just a slight pop on the pedal will line the syncros up better. It will be a little tight but should pop in. If my girl can do it he can do it.:cool:
  12. Sep 29, 2012 at 7:50 AM
    #992
    swendling12
    Sean
    Nebraska
    I don't disagree necessarily with the fact that my setup would make it more difficult or may even be causing the complaint etc. I took issue with their behavior and lack of customer service. Even if I had to shell out cash it would have been nice to know what it is and to rectify the problem. They never even tried to give it an effort. The last two companies I've worked for were all about customer service, maybe that's why I gave them the benefit of the doubt.
  13. Sep 29, 2012 at 8:02 AM
    #993
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I do agree with you with the service advisor being an asshat. But you can give the credit to the tech for tellin you not to leave it on a saturday he saved you some money. That kind of a complaint is for a monday appointment. Give the tech a full day to chase your vibration/noise issue.
  14. Sep 29, 2012 at 8:26 AM
    #994
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    if any of you are looking for a mt front set up take a look at my sig
  15. Sep 29, 2012 at 5:58 PM
    #995
    90YotaPU
    Union County, NJ
  16. Oct 1, 2012 at 7:32 PM
    #996
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
  17. Oct 2, 2012 at 4:11 AM
    #997
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    My 2012 RC calls for zero weight, even has a sticker reminding me of it. Now I don't know but I am sure the dealer put it there and it's in the owners manual.
    And I live in the Western North Carolina Mountains,
  18. Oct 2, 2012 at 6:45 AM
    #998
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    x2
  19. Oct 2, 2012 at 7:36 AM
    #999
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    2.7 requires 0w20 synthetic. The mobile one eco 0w20 is cheap at walmart, and it does make a difference.
  20. Oct 2, 2012 at 8:34 AM
    #1000
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    unless you're towing and or racing in the desert i would use 0w-20. if so use 5w-20 or 5w-30 for extreme uses. Like really extreme.
