The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Jan 20, 2018 at 12:51 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I am out cruising the fields looking for hogs. I feel like this thread needs a good flatbed flex picture. Stand by
    tacoburrito likes this.
  2. Jan 20, 2018 at 1:02 PM
    Nomad_Pilot
    Clay
    Ft Collins
    Yeah that's hog blood on the bed.
  3. Jan 20, 2018 at 5:46 PM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    @Bell214b is that the original flatbed or the access cab one? Either way thing is bad ass dude!
    PintSize likes this.
  4. Jan 20, 2018 at 5:59 PM
    hunter357mag
    hunter357mag Well-Known Member
    Bruce
    Minnesota
    2011 Black RC 4WD
    3" vertical ascension.....wheels.....tires......stuff
    62C71AE2-B056-4EAF-8E8D-AB4A47375B48.jpg The carbon fiber should add 2.3 HP.....also removed my tonneau and added new foam to reseal the edges. Ran a bead of silicone on the front pad, hopefully done with water leaks.
    Hardscrabble and tacoburrito like this.
  5. Jan 20, 2018 at 6:16 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Hope everyone has a good weekend
  6. Jan 20, 2018 at 6:19 PM
    Nomad_Pilot
    Clay
    Ft Collins
    It's the new one I biult, 7 feet long instead of 6, still a single cab frame.received_182852568968490.jpg
  7. Jan 20, 2018 at 6:21 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
  8. Jan 21, 2018 at 3:16 PM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Chevy 63s. 15" icons. 4.5 bumpstops. 315/75 maxxis bighorns. Camburg 1.25" UCAs. Shitty OME coilovers and wheelers superbumps. 4.88s. Welded rear. Cheap. Simple. And works.
  9. Jan 21, 2018 at 6:30 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Those cows look very impressed with the flex. Awesome truck!
  10. Jan 21, 2018 at 10:01 PM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    I’m just now noticing the cows :rofl:
    Hardscrabble[QUOTED] likes this.
  11. Jan 21, 2018 at 10:55 PM
    sloth671
    sloth671 Well-Known Member
    GuaM
    2014 Reg Cab 4x4
    king 2.5, icon, 17" Ray10, & 285 stt pro's
    The glass is killin it :cool:....did it come with the flare mode or thats the stock flares mounted?
  12. Jan 22, 2018 at 10:47 AM
    TJLILMAN
    TJLILMAN Well-Known Member
    Colorado Springs
    '08 Prerunner
    Couple of drawings i thought you guys might like :thumbsup:
  13. Jan 22, 2018 at 10:53 AM
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    Where did you get that roof rack?
  14. Jan 23, 2018 at 9:24 PM
    cwyse1
    cwyse1 Member
    San Luis Obispo, CA
    2011 Regular Cab Tacoma 4x4
    Looking to buy a stock exhaust if anyone in Cali has one laying around. Shoot me a message.
  15. Jan 26, 2018 at 3:41 AM
    Nomad_Pilot
    Clay
    Ft Collins
    Hey guys. I am not really one of those guys that mods my truck for power, I just take my time and know that offroad I can go where most people can't. But I recently put an afe pro dry filter on my truck. I cant believe how much better the throttle response and acceleration is. So how much better do the LCE headers make it? If the air filter is a 25% improvement, figuratively speaking, about what percent would yall say the header improve the overall driving experience?
  16. Jan 26, 2018 at 7:33 AM
    Nomad_Pilot
    Clay
    Ft Collins
    And also there is a very strange clanking sound coming from my truck when I clutch it and role to a stop. Just a sound, cant feel it in the floorboard yet. It could be a universal joint, but somehow I don't think it is gonna be that simple. Sound like it might be in the tailshaft houseing of transfer case
  17. Jan 26, 2018 at 7:34 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    i have the DT header and love it really helps out going up hill
  18. Jan 26, 2018 at 7:40 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    Header Style: 4:2:1 Tri-Y Header
    Material:Steel
    Finish: Silver Ceramic Coated
    Primary Tube Diameter:1-1/2"
    Primary Tube Gauge:14 Gauge
    Collector Attachment: 3 Bolt Flange
    Collector Diameter: 2-1/4"
    Tuned: No
    Flange Thickness:3/8"
    Bolts and/or Studs Included: Yes
    Gaskets Included: Re-use factory gaskets
    Quantity: Sold as a Complete Kit
    CARB E.O. #: D-540-6
    Warranty:Limited Lifetime to original purchaser
    2005-2016 Toyota 2.7L Tacoma / 4Runner / Prado / Hilux Tri-Y Header
    This tri-y header kit is an easy installation and will really wake up the motor on your Toyota. Tri-Y, or 4 into 2 into 1, style headers by design will increase the power of your motor across the widest RPM band possible, that is the beauty of the design, that is why they are the best street header available.
    05kytaco and Toyko Joe like this.
  19. Jan 26, 2018 at 7:41 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  20. Jan 26, 2018 at 7:47 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Those are some solid numbers! :thumbsup:
