The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Sep 12, 2018 at 1:35 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    In my 2014, the inside marker lights DO come on when the switch is on DRL. That's how I run most all the time.
  2. Sep 12, 2018 at 2:01 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    My inside ambers come on when in drl position, they won’t come on until the parking brake is released tho
  3. Sep 12, 2018 at 2:31 PM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
    10-4 thanks everyone!
  4. Sep 12, 2018 at 2:34 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    single cab v6 ????????? Toyota never made that from factory
    Blais03 and LiveFast75214 like this.
  5. Sep 12, 2018 at 2:40 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    so want to do this soon !!!!
  6. Sep 13, 2018 at 1:40 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Damn I always forget about this thread! Hi guys :wave:
  7. Sep 17, 2018 at 12:34 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Haven’t posted here in a while, man y’all keep on modding and are looking nice.
    I bought a boat, some of my focus lately. Fishing is importanter.
  8. Sep 17, 2018 at 3:14 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You do know what the "R" in DRL stands for right? :D
  9. Sep 17, 2018 at 9:22 PM
    PintSize
    Texas
    :rofl::rofl:
  10. Sep 18, 2018 at 4:31 PM
    Trosey
    Trosey Well-Known Member
    Here is my 2013 Regular Cab 4x4 5 speed.
    Suspension is all stock but im looking to lift soon!
    The rear is sagging due to roughly 600 pounds of camping gear in the bed.
  11. Sep 19, 2018 at 2:53 AM
    PintSize
    Texas
    Nice. I recall the days of bro lean before I lifted my truck. What are you planning to lift with?
  12. Sep 19, 2018 at 2:09 PM
    Trosey
    I am thinking bilstein 5100s paired with either OME 884 or 885 coils up front. In the rear I want to do OME MD Dakars. I am staying away from the nitro OME shocks because Id like to avoid the dreaded clunk.
    I want to stay between 2.5 and 3 inches up front. Which coil will give the best ride quality on road(this is a daily driver)? or are they the same since they are the same spring rate?
    A front bumper/winch combo is in the plans for the distant future, but most likely not for another year.
    Im not opposed to running aftermarket UCAs, but would likely stay stock if I could get away with it with the 884s.
  13. Sep 19, 2018 at 4:10 PM
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    I went with 5100's and 883's (didn't want a serious lift), and wheelers 3 piece AAL in the rear with 5100's. So far I love it.
    I was within spec for alignment with factory UCAs, but I think with the 884s I would have been too much.
    Here's a link to headstrong offroads chart for lift based on OME springs.
    https://www.google.com/url?sa=t&sou...Vaw3OJjcwk0pGug90vhYnDP0e&cshid=1537398181513
    PintSize and Trosey[QUOTED] like this.
  14. Sep 19, 2018 at 8:20 PM
    PintSize
    Texas
    I have 5100s / 884s up front with no spacer for lean. 885s on a 2nd gen RC needs UCAs. I think my front lift is about 2.5”. I put 5125s in the rear with a progressive AAL from Headstrong Offroad. When I had stock tires on that lift I did have driveline vibes big time, it’s amost gone away now that I am running 255s. No clue why but less burnt u joints. Dakar’s might give you vibes you don’t want, keep that in mind. If I were to put them in I might remove one of the leafs.
    Trosey[QUOTED] likes this.
  15. Sep 19, 2018 at 8:38 PM
    Trosey
    Thanks for the info, how is the carrying capacity with the add a leaf? Any pics?
    PintSize[QUOTED] likes this.
  16. Sep 19, 2018 at 8:44 PM
    PintSize
    Texas
  17. Sep 20, 2018 at 5:40 PM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    I never did find the answer as to whether our trucks have TRAC.
    Who here has done the yellow wire mod and/or has activated TRAC?
    My YWM did nothing, I could have one wheel in the air and spin for days with no brake or throttle management from the truck.
    I also have no TRAC light on my 2011, just AUTO LSD and the truck with squiggly lines behind it (VSC).
    Depoxy likes this.
  18. Sep 20, 2018 at 5:53 PM
    toysrgood
    SC
    2011 4x4 Reg Cab
    I don't even have a spot for the light...
  19. Sep 20, 2018 at 6:26 PM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    I'm pretty sure mine does. It cuts power if I spin the tires in the rain, and hitting the vlsd button prevents this in the sand. I haven't done the ywm though
  20. Sep 20, 2018 at 6:46 PM
    toysrgood
    SC
    2011 4x4 Reg Cab
    Well I get the power cut too if I goose it in dirt. That is the VSC kicking in.
    TRAC is typically only able to be activated in 2/4hi, and the YWM allows it to be used in 4lo and provides a LSD type effect to all 4 wheels.
    https://www.tacomaworld.com/threads...rols-trac-auto-lsd-a-trac-rear-locker.212057/
