The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Mar 22, 2019 at 5:38 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    The pinion gets oil by sling effect, not oil bath method, should be fine
    bijick[QUOTED] likes this.
  2. Mar 22, 2019 at 7:57 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Thanks for the info, come to think of it, when I was replacing my pinion flange, when I removed the old one there was some oil seepage and that was up in the air. Probably am being a little over cautious.
  3. Mar 23, 2019 at 2:48 PM
    Nomad_Pilot
    Clay
    Ft Collins
    Where do I get shims?
  4. Mar 23, 2019 at 3:13 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Nomad_Pilot[QUOTED] likes this.
  5. Mar 23, 2019 at 3:18 PM
    Nomad_Pilot
    Clay
    Ft Collins
    PintSize likes this.
  6. Mar 23, 2019 at 3:20 PM
    08RC
    08RC Well-Known Member
    If you are using a lift block you can buy blocks tapered already. My 1" has a 3 degree taper and can be installed in both sides in less than 5 minutes with a bottle jack and an impact gun .
  7. Mar 23, 2019 at 3:37 PM
    bijick
    E
    Stl
    For a single cab, I would get 885’s, I jumped the gun and put 886’s on mine when I bought my arb bumper and it was fucking horrible. I don’t have a winch but 100#s wasn’t going to change much
  8. Mar 23, 2019 at 6:09 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I got 884’s with my lift. I should have gone 885’s and they gave me maybe a little over an inch. Someday I’ll add a steel bumper and I’ll probably just be back to stock then.
  9. Mar 23, 2019 at 8:38 PM
    06RegCab1
    06RegCab1 Well-Known Member
    Wyatt
    Maui Hawaii
    2006 Regular Cab, 2.7 5 speed mt, 4x4
    Raptor lined basalt gray CBI off road moab 2.0 bumper steel CBI off road ifs skid steel Home made high clearance rear bumper McNeil racing +2" fiber glass fenders Cali Raised LED fog's (flood, amber) Arb air locker, 5.29’s Alpharex headlights 17" Stealth Custom Series Ray 10 35x12.50r17 MTZ’s King 2.5" extended travel coil-overs 650lbs springs AccuTune valving Total Chaos UCA's King 2.5" RR rear shocks Icon RXT Leafs Down south motorsports extended brake lines MagnaFlow Catalytic Converter MBRP Cat Back Exhaust 2.5" axle dumped LCE Heavy Flywheel URD ST shifter AJT design 5spd shift knob Sundown Audio SA 6.5 sub Audio control 4 channel Skyhigh car audio 6.5’s and 1” tweeters Lots of second skin sound deadoner
    Finally camped at a new spot, there are definitely some perks to living in HI, I forgot a tent, no shoes. No slippers (flip flops to mainlanders) and no jacket. Just laid a sleeping bag in my bed and I was good to go, never dropped below 70° and we found a spot behind a hill in the trees out of the wind
  10. Mar 26, 2019 at 3:43 PM
    bijick
    E
    Stl
    Double cardan shaft fixed the vibration problem, the truck also drives and accelerated like a finely tuned god damned sewing machine too. I legitimately could not be happier with the results.
  11. Mar 28, 2019 at 5:12 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I think mine are Trail Gear sliders but they were on the truck when I got it so I'm not 100% sure. They measure out to 58" which is what the Trail Gear are. Here's the passenger side looking from the rear.
    Scooter WCT likes this.
  12. Mar 29, 2019 at 8:11 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    The passenger side is pretty tight and it looks like there is about a 1/2" between the slider and the cab mount. It also looks like they had to beat the pinch weld a bit to clear the slider. It's mounted as far back as possible or the mounting flange would need to be trimmed to go back more since it's up against the crossmember. The driver's side has plenty of clearance all around. It could be where that front slider mounted was welded on the passenger side was a little farther back than it should have been.
  13. Mar 29, 2019 at 8:20 AM
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Running 884s on 5100s and stock UCAs. Synthetic winch and aluminum bumper. Lost about 1/8” of lift.
    You might be able to run 885s with that ARB bumper but might need new UCAs.
  14. Mar 31, 2019 at 12:30 PM
    Ihearttaco
    Ihearttaco New Member
    2013 red Tacoma (standard)
    Couple sick stickers...
    What lift, wheels and tires you running... love it!
  15. Apr 1, 2019 at 6:45 AM
    13yota
    13yota Well-Known Member
    Colorado
    2013 2.7 single cab 4x4
  16. Apr 1, 2019 at 7:46 AM
    JesseB
    JesseB Well-Known Member
    Jesse
    07 Reg Cab 4x4 4-banger
    skids and sliders 35s locked 4.88's
    The Slee mount will not work. I bought one and had to return it. I put mine on the driver's side up by the firewall. I can take pics later, if you want.
  17. Apr 1, 2019 at 10:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    My headlights are starting to do the clear coat peel looking almost cloudy crap sooooo...........doing some baking on 2 other sets I have to make a clear lens set. Taking the bezel from the retrofit ones with super yellow blinker lens and white side marker and unpainted parking bezel and putting them into my other black'd out halogen set. Tightened up the projector to reflector bowl to end the annoying jiggle hitting bumps that made me take them off to begin with - that and no 55w brights since brights on those = aiming the 35w low beam higher. Have all fresh ballasts/harness/ds2 bulbs for those as well since they didn't stay on truck long. That set will end up with black bezel with light yellow blinker lens/amber side reflector/black parking light bezel. Most likely will just swap in the halogens with clear side marker and super yellow blinker lens set with the philips xtremevision H4's. I have HID fogs so I like having 35w low and 55w brights just being halogen. Lots of time on my hands to get tedious with lights and there are side mirror blinkers to wire, route new CB antenna wire, replace whole front end since all parts on hand - Moog LCAs/SPC UCAs/bamatoy1997 new hubs and bearings/better coverage wheelwell splash guards from vendor here/new alignment adjusters for LCAs etc..............house projects are wrapping up so time for more truck love, lol.......................
  18. Apr 1, 2019 at 10:35 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    wait, that's white..........needs to go on my truck, lol....................the world ran out of silver paint
  19. Apr 1, 2019 at 10:48 AM
    13yota
    Colorado
  20. Apr 1, 2019 at 11:39 AM
    JesseB
    Jesse
