The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Nov 23, 2019 at 7:17 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    It is nice to camp with, but I like the look of the same height ones better. This is my setup at work last month
    Nickkos taco and DR_BETELGEUSE like this.
  2. Nov 23, 2019 at 8:14 AM
    onesojourner
    onesojourner Well-Known Member
    The Ozarks
    Nice setup. I would love to be able to set up right on my bed platform. I am folded in half with my cab high.
    ryfox0276[QUOTED] likes this.
  3. Nov 24, 2019 at 4:02 AM
    DR_BETELGEUSE
    DR_BETELGEUSE Member
    Parker
    Central Pennsylvania
    07 Tacoma 2.7 single cab
    Hello everyone. Here's my not so pretty Tacoma.
    2007 2wd base. It's all stock just a good commuter.
    320k miles. It was backed into slowly by a flatbed straight truck in the front that bent the passenger fender pulling the headlight down. 150 bucks later it had a new fender and headlight assemblies. (headlights were foggy and wanted clear ones. All I had to do was pull a little bit by hand on some of the mounting brackets for the front of the fender mounting. Wasn't tricky and if I didn't see the truck get backed into as slowly as it was, I'd have never bought it from the previous owner. I could paint the fender but for as cheap as I paid for the truck and to fix it, it doesn't seem valid enough hahah.
  4. Nov 24, 2019 at 1:55 PM
    06RegCab1
    06RegCab1 Well-Known Member
    Wyatt
    Maui Hawaii
    2006 Regular Cab, 2.7 5 speed mt, 4x4
    Raptor lined basalt gray CBI off road moab 2.0 bumper steel CBI off road ifs skid steel Home made high clearance rear bumper McNeil racing +2" fiber glass fenders Cali Raised LED fog's (flood, amber) Arb air locker, 5.29’s Alpharex headlights 17" Stealth Custom Series Ray 10 35x12.50r17 MTZ’s King 2.5" extended travel coil-overs 650lbs springs AccuTune valving Total Chaos UCA's King 2.5" RR rear shocks Icon RXT Leafs Down south motorsports extended brake lines MagnaFlow Catalytic Converter MBRP Cat Back Exhaust 2.5" axle dumped LCE Heavy Flywheel URD ST shifter AJT design 5spd shift knob Sundown Audio SA 6.5 sub Audio control 4 channel Skyhigh car audio 6.5’s and 1” tweeters Lots of second skin sound deadoner
    Buy once cry once. Get the adjusters so you wont regret not having them. My brother has fox 2.5's with the DSC adjusters and it's great to have
    onesojourner[QUOTED] likes this.
  5. Nov 24, 2019 at 5:17 PM
    DR_BETELGEUSE
    Parker
    Maybe in the spring time when it's a good weather for it.
    jeff b[QUOTED] likes this.
  6. Nov 24, 2019 at 5:20 PM
    DR_BETELGEUSE
    Parker
    I have an ugly high rise leer topper that's aluminum. It's ugly but makes for camping very well when I have it on.
  7. Nov 25, 2019 at 2:59 PM
    eperez
    eperez New Member
    Tacoma 1997 2.7L single cab
    2inches lift kit. Aftermarket rims. Camper shell
    Hi there! New around here. Just wanted to say hello and introduce my Tacomita!!
    Ritchie, KanakaRebel, jeff b and 12 others like this.
  8. Nov 25, 2019 at 8:59 PM
    06RegCab1
    Wyatt
    Maui Hawaii
    Such a rewarding little install. Ditched the H1 halogen bulbs, and upgraded to morimoto 2 stroke 2.0 LED's designed for projector housings. The difference is insane. (Also I'm a huge fan of wiring as clean as possible, this is not an example of that.)
  9. Nov 26, 2019 at 4:50 AM
    onesojourner
    The Ozarks
    We need to get you together with someone with the ultimate h4 upgrade and see how they compare.
    whatstcp and MSN88longbed like this.
  10. Nov 26, 2019 at 4:28 PM
    06RegCab1
    Wyatt
    Maui Hawaii
    These are just some h1's in crappy projector housings used in these tacomabeast headlights. Figured I'd make the best of it, so far I'm very pleased
    whatstcp likes this.
  11. Nov 26, 2019 at 4:39 PM
    onesojourner
    The Ozarks
    The cutoff looks pretty good considering they are leds.
    06RegCab1 likes this.
  12. Nov 26, 2019 at 5:51 PM
    06RegCab1
    Wyatt
    Maui Hawaii
    While driving these are waaaaay brighter than the halogens. The cut off is as good as I can get it. I have front glass so it messes up the headlights lineup and I'm too lazy to try mess with the glass anymore
  13. Nov 29, 2019 at 10:17 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
  14. Nov 30, 2019 at 10:13 AM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Did some off-pavement driving and camping
  15. Dec 1, 2019 at 1:45 PM
    06RegCab1
    Wyatt
    Maui Hawaii
    Well I've had my hands full the weekend with a few projects, hard wired the blinkers in added a lil 5 Amp fuse, added some caliraised LED reverse lights, added some boat holders for my 0c1 canoe had to make 1" spacers to get the boat to clear and started to design a power distribution panel/relay panel to get wires off my battery.
  16. Dec 1, 2019 at 9:54 PM
    '14RC
    '14RC WA State
    Seattle
    Just to update, I swapped my suspension as noted in post #1048 here. Looking for completely stock center-hub to fender measurements so I can check my numbers against it. Anybody have those?
  17. Dec 2, 2019 at 10:07 AM
    06RegCab1
    Wyatt
    Maui Hawaii
    I'm so excited to see how it looks. I've been wanting to do a plus 3.5 camburg kit with fox dsc's
  18. Dec 2, 2019 at 1:07 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Out of curiosity, did a Carfax for my '97 (avatar pic):
    1997 Reg Cab 2.7 5MT 4WD, bought new in AZ for $15.6, only option was a "Cold Weather Package" which was heavy-duty windshield wiper motor and the ridged windshield trim that shunted water over the roof instead of to the side windows. No AC, no radio.
    Sold it in CO back in 2012 for $6800, 104k miles. 2nd owner sold it 2013 118k miles. 3rd owner shows it registered in Steamboat Springs 2013. Carfax shows 140k miles on 10/11/2019, still in CO.
    I was surprised there wasn't much action when I sold it in 2012 with that nice Leer 122 shell on it. No factory AC and white shell I guess was a show stopper.
  19. Dec 5, 2019 at 10:44 AM
    96degreesindashayd
    96degreesindashayd IG: @96degreesindashayd
    Shaydon
    Kaua’i, Hawai’i
    95.5 Tacoma SX 2.7L TRD Supercharged Single Cab
    17” Trail Edition wheels Toytec Boss 3” TC UCAs TRD Supercharger SplitSecond FTC1 AFE Dry Pro CAI LCE Short Throw
    Must have room for the wa’a :thumbsup:
    06RegCab1[QUOTED] likes this.
  20. Dec 8, 2019 at 1:41 PM
    DNAVES
    DNAVES Active Member
    Abraham
    95' 2.7L 4x4
    95' 2.7L Geared up for Upper Peninsula MI backpacking/surfing trip
