The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Feb 18, 2020 at 9:15 PM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    Got my snorkel on this weekend to feed my 2.7 a bit cleaner air.
    A goodie showed up that's going on this weekend.
  2. Feb 18, 2020 at 9:32 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    Alright so I know nothing about OV Tune. From what I understand it’s a tuning chip? What’s the benefit for our 2.7 NA?
  3. Feb 19, 2020 at 2:50 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I think most the benefit will be for those who have boosted, the ability to tune without having to buy a piggy-back ECM. I’m not so sure there will be great benefits for normally aspirated trucks, it’s not like the autos were plagued like the 3rd Gen guys. I’m not so sure there’s that much more hp to gain from our engine without boost, maybe fuel economy?
    Bloodytaco208 and whatstcp like this.
  4. Feb 19, 2020 at 6:43 AM
    Taco505
    Alex
    New Mexico
    For sure I’ve really only seen the 3.5 guys using it to help with the shifting “issues” but interesting none the less I’ll have to keep my ears open.
    That's understandable I bet that's probably the best application.
    whatstcp[QUOTED] likes this.
  5. Feb 19, 2020 at 9:02 AM
    JoBroTACO
    JoBroTACO Jobrotaco IG
    Joey
    Yuma AZ
    2013 TACO 4x4 4 cyl 5spd
    All pro Bumper and Armor SPC Control Arms King stock OEM RR X 4 Ironman 4X4 leafs Superbumps front #1500 sumosprings rear Sway bar delete Larger than average balls Lower than average intelligence
    If it's the heavy one its does I have one on mine best 2.7L mod ever
    05Taco4x4 and whatstcp[QUOTED] like this.
  6. Feb 19, 2020 at 9:05 AM
    JoBroTACO
    Joey
    Yuma AZ
    Yea I did the LCE heavy flywheel and LCE pro clutch awesome combo. I still want to regear but it helped out alot at low rpms.
    05Taco4x4 and whatstcp like this.
  7. Mar 5, 2020 at 10:04 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    whos running 4.88 with 33 on a auto? do you like it or is it to much?
  8. Mar 5, 2020 at 12:59 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Anybody ever had a Deaver J66 leaf packs on their RC?
  9. Mar 5, 2020 at 7:10 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I recently found my add a leaf is broken. From my research if you can swing the price, looking for 1.5 inches, and aren't carrying heavy loads this is one of the better choices.
  10. Mar 6, 2020 at 6:41 AM
    bawth
    bawth Active Member
    Brendan
    Maine
    2013 4x4 Regular Cab 5MT
    Billie 5100’s Wheelers 1.5” AAL Lightforce 240’s
    Took Rocko on a shakedown run up a local cell maintenance trail after installed some billies and an add a leaf last week. It’s crazy how capable these trucks are with a slight lift and 32’s.
  11. Mar 6, 2020 at 8:09 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    It's crazy how capable these vehicles are stock
    whatstcp and MSN88longbed like this.
  12. Mar 9, 2020 at 7:15 PM
    '14RC
    '14RC WA State
    Seattle
    I picked up a low mileage pair of j66 this weekend. No complaints, still kept some lift with the shell on the back. Haven't tried loading them up heavy yet, but I took the truck through some paces on and off road and they are a big step up from the AAL setup I had before it!
  13. Mar 9, 2020 at 8:48 PM
    Taco505
    Alex
    New Mexico
    What size tires are you running and what strut/coil set up do you have?
    I’m kind of in a similar situation I have the 3rd gen leafs/shocks in the rear but with the weight of the FlipPac & hitch about 400lbs constant load I’m getting some negative arch. I just ordered the MD Dakar pack which should be here tomorrow. Anyway I’m thinkin it might look a bit goofy with my tires (stock size) in the rear if the leafs don’t settle in with the weight.
  14. Mar 9, 2020 at 11:32 PM
    '14RC
    '14RC WA State
    Seattle
    265/75/16, 5100's, and Dobinson coils. these coils are actually spec'd for a Toyota Fortuner in the Dobinson catalog. they work well on this truck tho. Fortuner shares the 2.7L engine. I explained the trouble I had finding a lift coil that would also have a compliant spring rate to a Dobinson rep and these are what he recommended.
    Yeahh, tires can make or break the look. Nothing wrong with 265's but Im bumping up to 255/85 next time to fill out the wheel wells better. Good luck on your Dakar pack, sounds like the medium duty would be a good choice for you.
  15. Mar 10, 2020 at 1:56 PM
    Taco505
    Alex
    New Mexico
    Interesting I didn't know that, but I'll have to look into that setup seems like a good option. Are you planning on a front bumper/winch? I'm sure it'll be a huge step up from what I have now but you're right on track with 255/85 my buddy had one in his garage I put next to my current setup for reference and I think that'll do the trick with filling out the wheel wells.
  16. Mar 10, 2020 at 2:28 PM
    '14RC
    '14RC WA State
    Seattle
    No I won't be adding any weight which is why it was hard to find a lift coil that wouldn't ride like a horse with wooden legs, lol. These have a 475 lb/in spring rate, and the next closest was like 550 lb/in from OME.
    I could still see the benefit of adding some weight to the front to make the Bilstein 5100 feel a little softer but I can't justify the price of a bumper/winch just to maybe get a softer ride.
    Anyways the Dobinsons coils and Deaver J66 has been the closest to stock feeling I have found yet, but I haven't tied the high-end KINGS, ADS etc rebuildable shocks. I'm sure I could get more dialed in if I was able to change internal valving to my liking.
  17. Mar 10, 2020 at 2:33 PM
    ryfox0276
    Montana
    2013 RC 4x4
    What are you guys running for 255/85s? I am looking for new tires in the future, want 33s and love the skinnies on my reg cab (have 235/85s now). Options seem to be extremely limited in this size and don't want to run a MT
  18. Mar 10, 2020 at 2:35 PM
    '14RC
    '14RC WA State
    Seattle
    I've just about finished adding sound insulation to my RC and I might gamble with some KM3's MT cause they look awesome (and have good reviews)
    ryfox0276 likes this.
  19. Mar 11, 2020 at 7:26 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I'd love to hear details about you insulation job. i.e. how you did it and how it turned out.
    Cheers
  20. Mar 11, 2020 at 7:28 AM
    Taco505
    Alex
    New Mexico
    I second that I've been thinking about going through that process but as much of a procrastinator I am it'll probably take me a year haha.
