The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Nov 29, 2020 at 2:54 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    It works, it's cheaper and I won't see a mileage increase running a higher octane.
    I looked in the manual when I bought this truck to see what to put in it. My last car took 91 so that's what I used.
  2. Nov 29, 2020 at 3:10 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Nov 29, 2020 at 4:56 AM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    The AALs aren't in yet. This is just with the front lifted on the 3rd notch on the 5100s. It's almost level. The rear is about 3/4 inch higher but I tend to notice it almost looking like the rear is lower than it is. I'm hoping the AAL will fix that.
  4. Nov 30, 2020 at 6:33 AM
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
  5. Nov 30, 2020 at 9:18 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'd say gas companies pretty much misinformed people of "Premium" fuels with their TV commercials, they must have had to settle somewhere down the line because they don't market it the way they use to. I'm quite sure I heard the word "power" in them.
    Octane rating is RESISTANCE to combustion, if that's something you feel your 2.7L needs then have at it haha
  6. Nov 30, 2020 at 2:50 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Almost caught it at 40k.
  7. Dec 2, 2020 at 12:59 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
  8. Dec 2, 2020 at 1:00 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    Anyone running 33/12.5r15?
  9. Dec 2, 2020 at 5:26 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I'm close at 305/65/17 which is around 33/12/17 so a little narrower. I still rub on the cab mount at full lock so I would imagine the 12.5 would rub a little more with 17 x 8.5 wheels with -10 offset or more negative. I think @06RegCab1 is running the 33x12.5 in either 16 or 17. You can't run the 33/12.5/15 because 15" wheels won't clear the calipers, you need 16 or 17" wheels.
  10. Dec 2, 2020 at 5:52 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He's a 5 lug which have the smaller calipers
    dillonk1602 and ryfox0276 like this.
  11. Dec 2, 2020 at 7:14 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    Yeah I’m running the new general grabber tire the ATX on my methods 15 inch rim double standard plus total chaos long travel so I should be OK on the rubbing part regeared for 88
  12. Dec 2, 2020 at 7:41 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Ahhh, I didn't realize the 5 lug setup used smaller calipers and smaller than 16" wheels. But the width of the tire will still depend on the wheel width and offset to see if it pushes the tire out too far and therefore rub on the cab mount or tuck the tire in too far with too much backspacing and rub on the inside. If you're sticking out more than this, I think you will rub the mount. I have the SPC UCA's at psotion C which pushes the wheel farther forward in the wheelwell and still get some rub on the mount at full lock.
  13. Dec 3, 2020 at 6:21 PM
    BabyTaco
    BabyTaco [OP] Well-Known Member
    Wyoming
    2011 RC Tacoma
    Treating ol’ baby T to a few upgrades.
  14. Dec 3, 2020 at 6:33 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Honestly...it was a bit of an impulse purchase, so not sure haha. Probably under the hood like most guys do.
    Dalandser likes this.
  15. Dec 6, 2020 at 12:17 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  16. Dec 6, 2020 at 2:00 AM
    CROM123
    Garland
    Virginia
    That single cab is bad ass !!!
  17. Dec 8, 2020 at 4:56 PM
    Nigel4x4
    Nigel4x4 Active Member
    Boulder
    09 RC 4x4
    Bilstein 5100 front and rear; Softopper; Duratracs
    CROM123, 69 Jim and ryfox0276 like this.
  18. Dec 8, 2020 at 5:43 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    1st yr of that body, low mileage, 4x4 auto only way to get center console and buckets in single cab, shell..........overpriced but not sure how crazy. If it's your thing then there it is. Can't buy a new one like that so it's kinda relative. I'd throw 20 at that before 50k for a new TRD Pro......way before. Needs to leave WY before rust happens tho..............
    CROM123 and 69 Jim like this.
  19. Dec 8, 2020 at 7:03 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  20. Dec 8, 2020 at 7:06 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Love those tires man, great choice :thumbsup:
    CROM123 and dillonk1602[QUOTED] like this.
