The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Nov 23, 2021 at 10:51 PM
    ethanfiamingo
    ethanfiamingo Well-Known Member
    Ethan
    2011 Regular Cab 4wd 5sp
  2. Nov 23, 2021 at 11:03 PM
    apbright
    apbright Well-Known Member
    Aaron
    2007 Silver Tacoma Base
    what lift size and wheel/tire size is that? love this look
  3. Nov 23, 2021 at 11:08 PM
    ethanfiamingo
    Ethan
    Thanks - ome 2884 / stock leaf with some deaver aals.
    Probably settled at around 1.5-2 inch lift because the drawers are like 150lbs
    4runner trail 17" 265/70/17 no spacers
    thinking about doing 255/80/17 next?
    Hardscrabble and WasatchDweller like this.
  4. Nov 24, 2021 at 5:22 AM
    Breck1
    Breck1 Well-Known Member
    Lake Tahoe CA
    2011 Single Cab Tacoma
    Home made rack? How is it attached looks like it’s sitting right on the shell? I Like how long it is …
  5. Nov 24, 2021 at 10:08 PM
    WasatchDweller
    WasatchDweller Well-Known Member
    Anthony
    2010 Regular Cab 5MT 4WD
    Beautiful truck! I definitely love the 4runner wheels. That lift looks great. Glad to see the results I was looking for with the OME 884's.
    Any other suspension upgrades? Upper control arms?
  6. Nov 25, 2021 at 3:36 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I have a 2012 and it already has a metal pipe. Do you know what year Toyota changed over to the metal pipe? Maybe for the 2.5 gen body style, 2012+?
  7. Nov 25, 2021 at 7:21 PM
    ethanfiamingo
    Ethan
    Thanks! yea it’s a custom rack, mostly 8020, I cnc’d the corner brackets so I could angle the front and rear bars. The length is so that I could have a shell and can rack all in one becuase I couldn’t find anything long enough for a RC.
    I installed some low pro rails on the shell top, the rack sits only about .75in off the shell top.
    Thanks friend, yea 4Runner wheels were chosen because I prefer a “factory” look and the offset is perfect for no spacers flush look.
    Just super bumps, u bolt flip. No control arms because it’s a low lift, alignment is spot on but might do jbas to improve caster angle as I do get some slight bump steer.
  8. Dec 2, 2021 at 12:27 PM
    KanakaRebel
    KanakaRebel Well-Known Member
    Kauai, HI
    2009 Tacoma 4x4 Single Cab
    That I have no idea. I wouldn’t be surprised if they did change it for the 2.5 body. My mechanic said he did 3 changeovers the same week as he did mine, all 2nd gens with 180k+ miles.
  9. Dec 2, 2021 at 3:32 PM
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
    Ok,
    We have a 15 & 07 both with 2TR’s. Where’s this coolant leak you’re taking about? Photos of the pipe would help!
    Thanks in advance…
  10. Dec 3, 2021 at 3:07 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is a picture during replacement.
  11. Dec 3, 2021 at 11:30 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Hey all, I'm about due to change out the fluid in my transmission. Last time I used Redline MT90 and just haven't been very happy with it. Really preferred the fluid Toyota put in it from factory. I can't seem to find a good source of Toyota gear oil, and nearest dealership is over 200 miles away. Suggestions?
  12. Dec 3, 2021 at 2:29 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    That's a great "explanation".
    Thank you.
  13. Dec 3, 2021 at 4:08 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ummm yeah, 195k on my 08......goes to look at line even tho no coolant loss. Thanks for heads up. I have flushnfill kit on my heater hose so it's simple to flush, drain and refill with fresh juice.
    MSN88longbed likes this.
  14. Dec 9, 2021 at 5:40 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    2011 MT, when shifting during a WOT acceleration, has anyone else experienced a complete loss of power?
    From 1st to 2nd (or occasionally 2nd to 3rd), at about 5,000 rpm, obviously letting off throttle to shift, once into 2nd and back on the throttle, the engine doesn't even attempt to accelerate and its like the computer has cut all power.
    This isn't a hard shift, its a regular shift, just with more acceleration and spirit. The truck does not like it for some reason. No odd sounds, lights, loss of traction or anything breaking. It just cuts power.
  15. Dec 9, 2021 at 9:29 AM
    WasatchDweller
    Anthony
    Sounds like you're bangin redline and hitting fuel cut. My 2020 Tacoma did it (auto) and my current 2010 5mt does it. It's normal.
  16. Dec 9, 2021 at 10:30 AM
    toysrgood
    SC
    2011 4x4 Reg Cab
    No, not redline. But the feeling is the same. Power just cuts out after the shift. If it were redline, then power would cut out before the shift.
  17. Dec 9, 2021 at 11:36 AM
    WasatchDweller
    Anthony
    I've had that happen to my 2010 as well. Hit redline, shifted to 2nd, and there was no power initially. Sent me through the dash lol.
    Really, if there isn't any CELs or any issues otherwise, I wouldn't worry. It's Toyotas safeguard for the engine. Are you hooning the truck or something?
  18. Dec 9, 2021 at 12:28 PM
    toysrgood
    SC
    2011 4x4 Reg Cab
    It isn't redline...
    It is obnoxious when trying to get up to 60mph on a busy road and your vehicle stops accelerating. Little engine, big tires, need to accelerate fast... Sometimes there really isn't any way to avoid high rpm shifts in our little trucks. I'm not worried that something is wrong, I am wondering if other people are experiencing the same thing and how they avoid triggering the nanny computer interventions.
  19. Dec 9, 2021 at 1:04 PM
    WasatchDweller
    Anthony
    Alright fair, yes you're not redlining. But I am saying that I have experienced this by hitting redline and I've experienced power loss. I guess that's all I'm trying to say. Now, you're not redlining the truck and I acknowledge that but you're high in the RPMs. It could still be the same fuel cut, I don't know. But this sounds exactly like fuel cut when hitting redline. Toyotas don't bounce off redline, they just shut down. At least in my experience. Sorry had to clarify what I was trying to say.
    It does suck that we have to wrap these trucks out to get up to speed. This truck has taught me to slow down and allow more room to merge. I try and not go over 4500 anymore, 4000 if I have to go up an incline. I'm only on 31's.
  20. Dec 9, 2021 at 1:10 PM
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    What didn't you like about the MT-90?
